#1 Posted : 08 March 2010 06:09:34(UTC)
I am still thinking about 2 Pole Current Conducting Couplings. Viessmann have a Version of the Fleischmann couplings but these can be delicate to connect and can be prone to failure.
Maerklin make a 2 pole set (219447 and 219446). They are horribly expensive over 12 Euros Per piece from Lokshop and almost 15 Euros per piece from Marklin. for a 3 carriage Consist 48 Euros plus from Lokshop.
2 questions: Has anyone a Photo of the Marklin one that can be posted on the forum.
ANy other suggestions for a 2 pole CCC.
The Roco 4 Pole appears to be very bulky.
nev
Offline Tivvy
#2 Posted : 08 March 2010 12:40:25(UTC)
Tivvy
Ep IV / V Marklin Layout
Under construction.
Offline trainbuff
#3 Posted : 08 March 2010 13:57:31(UTC)
trainbuff
Here is a web page with requested pics (seven different ccc with review and pictures):
http://www.thkukuk.de/Mo...sc/Stromf.-Kupplung.html
I used miniatronics 50-001 plugs,
http://www.miniatronics....CTGY&Category_Code=4
and put the plugs are under the car where you can't see them and the wires run next to the couplers. Pro - wires very small and look like hoses between cars. Con - need to take train off track to uncouple.
Good luck.
#4 Posted : 08 March 2010 18:30:31(UTC)
Hi Nev. I have used all of them and would say that the Marklin ones are probably the best if you are prepared to pay the cost and have your coaches more or less constantly coupled. Roco are similar to Marklin but are four pole.
Viessmann can be uncoupled but electrcal contact is not always good. The standard Marklin contact couplers are OK and will fit to Marklin Coaches prepared for them but again they are not always reliable.
The Marklin two pole will require a hole to be drilled in certain coaches to allow the wires to reach the light bar although some coaches will have a space around the coupler that the wire can be threaded through.
Next time you place an order why not try two of the Marklin two pole and see what you think.
dave
#5 Posted : 08 March 2010 23:13:55(UTC)
Thanks all for the answers
This page was generated in 0.239 seconds.
