Offline James
#1 Posted : 21 January 2010 05:39:24(UTC)
James
Hello All:
I was just wondering if anybody has heard if Marklin has built the control box that was supposed to enable the older CS1 (60212) to be able to link to the newer CS2 (60213)Confused
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
#2 Posted : 21 January 2010 07:55:20(UTC)
Marklin cancelled the 60212 connect device. The connection between the CS1 and CS2 is via the ethernet cable. Your CS2 needs to have the latest version of software, currently 1.3.0 (versions below that do not work), and the CS1 needs to be at presumably v2.0.4 - the v3.0 CS1 Reloaded is not recognised by the CS2.
You can read the discussions around the v1.3.0 update and connection to the CS1 in this thread:
https://www.marklin-user...aspx?g=posts&t=15126
Offline supermoee
#3 Posted : 21 January 2010 14:33:01(UTC)
supermoee
the CS2 recognizes well the ESU software and quits with the message: not compatible. BigGrin
rgds
Stephan
Central Station 1 and 2 connections (Digital)
by James 11/02/2009 10:30:10(UTC)
This page was generated in 0.231 seconds.
