Offline Darren W
#1 Posted : 18 January 2010 21:22:59(UTC)
Darren W
Just a simple question I am hoping someone can clear up for me. What is the difference betweeen the 6015 and 6017 boosters?Confused
Darren
#2 Posted : 18 January 2010 21:37:42(UTC)
You connect the booster cable upside down (I think)...
And you have 4 DIP switches on the back...
#3 Posted : 18 January 2010 22:35:16(UTC)
There is 4 DIP switch in red square on right side of 6017 but 6015 do not have the DIP switch.
Here is the picture of upside/down of cable.
Offline Darren W
#4 Posted : 18 January 2010 23:29:32(UTC)
Darren W
So what is the DIP switch on the 6017 used for?Confused
Darren
#5 Posted : 18 January 2010 23:47:48(UTC)
It adjusts the sensitivity of the shortcut detection (switches 1 and 2) and can be used to reduce the track power (switch 4).
Switch 3 is unused.
Offline graafjp
#6 Posted : 18 January 2010 23:49:00(UTC)
graafjp
Dip switch 1: Lowering the level of low voltage identification at which the booster shuts down due to undervoltage cause by overload. When this dip switch is on the booster shuts of later so it can deliver a bit more 'peak' power.
Dip switch 2: Rise time for overload protection so booster does not shut down by very short overcurrent conditions.
Dip switch 3: not used
Dip switch 4: Lower track output voltage to about 12-14 volts.
Jos
Offline LionelMPC
#7 Posted : 19 January 2010 02:20:13(UTC)
LionelMPC
I was also wondering about this, thanks!
-James
This page was generated in 0.541 seconds.
