Offline MichaelParsche
#1 Posted : 15 January 2010 02:46:36(UTC)
MichaelParsche
What is the best method of cleaning C Track?
Michael Parsche
#2 Posted : 15 January 2010 11:20:14(UTC)
Hi, Michael!
I presume we're talking about Märklin C Track (not Trix C Track).
I only use non-abrasive track cleaning. I'm afraid that abrasive track cleaning will lead to rough rails where the dirt sticks even better.
See also here:
https://www.marklin-user...&m=124217#post124217
https://www.marklin-user...ts&m=99535#post99535
Offline jørnet
#3 Posted : 15 January 2010 11:57:14(UTC)
jørnet
I use common white paper folded 2-3 times. I only use each side a few strokes.
Now and then clean the tracks using a vacuum cleaner extended with a thin (8 mm) plastic tube.
I just need space, money and time - That's all
#4 Posted : 15 January 2010 13:56:23(UTC)
I use a paper kitchen towel, folded over a few times, and run it along the track until I stop getting black "streaks" in the paper.
This works very well on plain track, but in turnouts the tissue gets caught on the raised "pukos" and tears up if you're not careful. The blades are also difficult to clean.
One negative effect of this method - I keep knocking my Preisers off the platforms and their track-side places. Very tiresome to keep gluing them back.
What do you do when you have Catenary? I don't yet, but I'm dreading it!Crying
Offline Ranjit
#5 Posted : 15 January 2010 14:42:23(UTC)
Ranjit
Hi Michael,
Have you considered track cleanng cars?
Ranjit
#Get Vaccinated
Offline davemr
#6 Posted : 15 January 2010 15:25:43(UTC)
davemr
Views messages in topic : 983
Roco rubber and run locos on a regular basis. No need to spend a lot of cash on special cars.
davemr
Offline Tex
#7 Posted : 16 January 2010 05:11:55(UTC)
Tex
The rail should be cleaned not abraded. I have used soft eracer " pink pearl " followed by metal polish. The one I use is Flitz Polish, information at www.flitz.com. Most of by test cleaning was on older recycled M track but works just as well on C track. When my layout is fully operational , I expect that little cleaning will be needed.
#8 Posted : 16 January 2010 12:44:48(UTC)
H0 wrote:
Hi, Michael!
What´s difference...??? Confused
Modelrailway hobbyist are using trackcleaner to all type of tracks.
I myself are using either chemical gasolin or contact cleaner PRF 6-68. ThumpUp
They are harmless against rustfree steel or nickelsilver! ThumpUp
P.S.
Don´t have power on the track,when you are cleaning on the track with chemical gasolin!!!
#9 Posted : 16 January 2010 12:50:32(UTC)
Viessmann has an special worktoy to cleaning tracks,when you have catenary or not.
It´s an blue colour viparm,which you can bend it in any position of cleaning tracks!
ThumpUp
Offline davemr
#10 Posted : 16 January 2010 14:01:11(UTC)
davemr
Ray. I just ask my Preisers to take a couple of steps back when i run the rubber over the track.
If you run locos regularly then I find I only need to clean if I have been working on the layout or scenery etc. Small hand held car vaccum is good for moving dust or bits of scatter that have come loose.
davemr
#11 Posted : 16 January 2010 22:13:46(UTC)
The center rail studs. Flapper
LOL
#12 Posted : 17 January 2010 11:55:00(UTC)
I use a few folds of shopping docket paper, which is glossy.
Unlike paper towels, tissue etc, it has high strength, and easily glides over track without catching.
Discard when too black.
#13 Posted : 17 January 2010 11:59:07(UTC)
LOL
And so what...??? Confused
Blink
Offline dennis
#14 Posted : 17 January 2010 12:07:18(UTC)
dennis
I use a cotton whith alcohol to clean
my K Track
#15 Posted : 18 January 2010 00:39:06(UTC)
Centre rail studs can be harmful for fingers, sheets of paper, and other cleaning material.
And centre rail can even get rusty.
Cleaning C track? (General MRR)
by Joseph Meiring 13/07/2011 22:20:50(UTC)
Cleaning C track (H0-scale)
by Bill 04/03/2002 19:57:46(UTC)
This page was generated in 0.458 seconds.
