Joined: 23/03/2005(UTC) Posts: 2,497 Location: Denmark
quote:
Originally posted by sjlauritsen
...4. Does the model have short coupler kinematics? Not just the short coupler, but the kinematics as well.
quote:
Originally posted by Thomas Duengefeld
..... Never understood the difference in this coupling kinematics.
quote:
Originally posted by Sander van Wijk
...These full kinematics come at the advantage that the coupler slightly moves inward when centered, resulting in a smaller clearance between the buffers without causing troubles in curves, ideally, that is.
Reading the topic "Ludmilla" just above I might have found an explanation to a "problem" (disadvantage rather) I noticed, when I had my Swiss passenger train running with 3-4 or 5 wagons. The last wagon(s) in the consist were running at an uneven speed when within and exiting curves - most noticable with the last wagon. The loco was pulling at a constant speed.
Could that not be the result of these yielding couplers?
Once you have noticed, it keeps catching your eye and it does not look very natural.
Has anybody else noticed something similar?
Regards, Benny - Outsider and MFDWPL  |
Joined: 14/03/2005(UTC) Posts: 15,870 Location: Gibraltar, Europe
I've noticed it too, Benny, and I also find it annoying. The longer the train, the worse it gets.
You can hear it too. As the train comes off a curve, you get like an oscillating sound, until it settles down on the straight.
It doesn't happen with the normal couplers.
Ray |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
Joined: 16/08/2006(UTC) Posts: 5,382 Location: Akershus, Norway
I have noticed the same, Benny.
As the car length (coupler to coupler) actally increases in the curves, the rear end of the train has to slow down when the train enters a curve.
It is very noticable if you hook up a measuring car (I have the 49960 Messwagen) at the rear end of the train. When the front end of the train exits the curve, and the couplers starts to straiten up, the rear end accelerates as the cars get shorter again.
If the Messwagen runs directly behind the locomotive, the phenomena is almost eliminated.
As Ray says, the longer the train is (more couplers), the more noticable. |
Best regards Svein, Norway grumpy old sod
Joined: 19/11/2007(UTC) Posts: 2,835 Location: Northern California,
Benny and Ray, I see that with my long freight which has 24 cars. It starts to be noticable at the #10 to 12 car. Then more so at the end of the train. It's the old hurry up and wait syndrome. Actually, it's also quite noticable on the straights too. I don't notice it with the passenger trains with 5 or 6 cars.
When riding the rails, as a young man, I've experienced the same effect on the real thing when riding near the end of a long freight. Riding in car #78 will give you just that feeling.
And I've felt that also in the caboose on an 8 car tourist RR where I was the brakeman. Of course those couplers were very old and loose. There's always some stretching and contracting on a long train just as with a model.
Cheers, Bob |
Robert's trains insured by Colt 45--Marklin Club of NorCal, Founder and Sole Member--- Robert's photos may be used as public domain-all copyrights waved "All tyranny needs to gain a foothold is for people of good conscience to remain silent"-T.Jefferson
Joined: 20/04/2003(UTC) Posts: 2,248 Location: Amsterdam, Netherlands; Göteborg, Sverige,
Hi all, This is, indeed, a commonly noticed phenomenon, most people do not like it very much... obviously. Couplers are unfortunately a huge compromise in MRR, no doubt about that. AFAIK the only way to reduce the effect is by using wider curves (read, better to scale curves) or otherwise transition curves. An outstanding explanation of transition curves can be found in this topic here: https://www.marklin-user...chTerms=transition,curve |
Sander
--- Era I(b): K.Bay.Sts.B. and K.W.St.E. |
NB: Perhaps it would be better to rename this topic into something like "Coupler kinematics effects" or something instead of "Ludmilla - 2" as it virtually has nothing to do with this Ludmilla. I do not know whether you could actually make those changes, but it would significantly enhance the possibility of successfully using the search of this forum in the longer run. |
Sander
Thanks for your replies. I followed Sander's suggestion of renaming the topic. |
Joined: 18/08/2007(UTC) Posts: 1,081 Location: Denmark
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Caplin <br />Thanks for your replies. I followed Sander's suggestion of renaming the topic.
Ha! LOL! I noticed a Ludmilla - 2 thread, but when I came back to look for it - it was gone. Now I know why. :-) Back on track: Thank you guys! I thought I was the only one seeing this problem. I don't now if it has anything to do with the couplers. It could be but I have investigated this quite a lot and I only have this problem with passenger coaches. Now that this topic has come up again I will have another look. |
In my experience it is worse when the coaches have a spring to pull the coupler pocket straight which also compensates for play in it. Now as train length increases so does the gap between coaches.
I wouldn't be without them though. Body mounted couplers like these solve so many problems and they look a lot better than non-close coupled stock. |
Matt from Wales.
When you pay Range Rover prices, don't accept Lada quality |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by RayPayas <br />I've noticed it too, Benny, and I also find it annoying. The longer the train, the worse it gets.
What is an "normal" couplers...? Couplers is not an living person...! You must only writing "standard" couplers. Goofy  |
H0 DCC = Digital Command Control
Goofy,
I'm glad you feel qualified to criticise other members choice of words in English. Your confidence is a credit to you.
For your information, the word normal can apply to inanimate objects as well as to living persons. In the way I used it, it means "not special" or "not improved". It was my way of saying "couplers without the close coupling kinematics".
I'm sure everyone knew what I meant, including you.
Ray |
Personally I would rather have the effect caused by close couplers than the huge gap between buffers. But not everyone thinks this way.
I now consider close couplers to be the norm (or normal) rather than the relex couplers.
For every step forward, sometimes there is half a step back.
John,
I agree that now it is more normal to get a close coupler than a Relex. Even the Hobby loks come with close couplers.
Unfortunately, the habits of 50 years can't be eliminated in the last 5 or 6, so for me, "normal" still means "Relex".
Having said that, Goofy's choice of "Standard" for a Relex coupler is also suspect. If most models now come with close couplers, then surely these are now the "standard" type?
Maybe we should specify "Relex" or NEM 360.
PS, Don't get me wrong, I also prefer to see close coupled trains, though I find it more important for passenger coaches than freight wagons. |
Hi Ray,
Marklin actually started producing close coupled stock in 1985.
A long time ago indeed!
Wow, doesn't time fly!  |
The maddening part is when manufacturers "sort of" close couple models. There are a fair number of British OO models where they've fitted an NEM pocket or even a proper mechanism, but ruined the overall effect by putting the thing in the wrong place so you can't use standard close couplers.
That Liliput SBB restaurant car I posted in the coaches thread had a similar problem - the buffers and close coupling mount were too long, so the HO scale people still had a 4ft jump between coaches. I solved it, but if they were to simply tool shorter buffers and a new close coupler arm I wouldn't have needed to take a file and clippers to the model. It just baffles me in all these cases why they can't put the effort in. It takes no more time and money to get it right while designing the model than it does to make a half-hearted kludge which simply makes them look clueless. |
Matt from Wales.
I prefer "standard" for the "normal" or oldest coupler and "close" for the newer one (only 23 years old  ) |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by intruder As Ray says, the longer the train is (more couplers), the more noticable.
Interessting! I run very long trains (I think up to 4 meter long trains are long) -and havent noticed the effect. -At least not in the vissible areas of my layout. So I think that the radius of the curve is decisive too! And... If the train can be eased into the curve (read: soft transition curves) the effect will be further minimized. |
That makes sense, Henrik.
The smaller the radius, the longer out on the V-shaped mechanism the coupler is moving, making the coupler to coupler distance longer. |
Hello guys.
First of all my opinion on the coupler naming convention. I don't like to discus what is already a fact. The Märklin close coupler is named "close coupler" by Märklin. And ya good olde coupler is named Relex. So I think we should name them close coupler (CC for short) and Relex. :-)
Now. I would like to know if any of you experience this kinematics effect with the C-Sine driven models?
Yesterday I tested a bunch of doppelstock passenger cars with a hobby-lok. And whoop there the effect was. Then I tested it with a 5-pole Roco engine. And the effect was gone! Now I'm pretty sure it has something to do with the engine pulling the wagons and not necessarily the close coupler kinematics (CCK).
What do you think?
/Søren |
Hi Søren,
How long was your train.
I don't notice the effect on trains about 1 meter long, definatelty notice it on trains over 2 meters long
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by mmrcnzjohn <br /> I don't notice the effect on trains about 1 meter long, definatelty notice it on trains over 2 meters long
Hey John. The train was about one meter long. Best regards Søren |
