Offline renevoorburg
#1 Posted : 11 August 2008 23:48:55(UTC)
renevoorburg
For a bridge I would like so use rails without the rail bed C-Track uses. Since my layout uses C-Track and I don't want to change that I need a transition from C-Track to K. However, I can't uses the transition track piece Märklin has since that is a straight part and on one side I don't have space for that.
Would it be a tough job to connect C-Track properly (without derailing, esthetically pleasing) to K-Track without the official transition piece?
Thanks, René
Offline perz
#2 Posted : 12 August 2008 00:47:18(UTC)
perz
It is definitely doable, although it requires some amount of work. We did it on our company layout https://www.marklin-users.net/fo...ault.aspx?g=posts&t=8681.
We carefully cut off about 2 cm of the ballast at the end of the C-track and mounted a few ties from a scrapped DC rail there instead. We then mounted the K-track on it with some spare rail joiners. We glued the rail joiners with epoxy to make sure that the upper surfaces of the rails stay level. This is a precaution since C and K rails have different height.
We needed to have 2 cm of the C-track going out over our bridge. If you don't need that it might be sufficient to just remove a little bit of the C-track ballast at the end, and then you might not need to add new ties in that end.
Unfortunately I don't have any pictures of exactly that place on the layout, but it looks quite good and works very well without any derailments. The photo I have of the bridge is from the other end, where an transition section could be used.
#3 Posted : 12 August 2008 23:13:39(UTC)
renevoorburg
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
<br />It is definitely doable, although it requires some amount of work.
Thanks Per!
But maybe to be realistic K-Track is not needed at all. I did some research and look at what I found:
So I just need to cover the ties, and cut away some of the balast bed to reduce height and make the ballast bed invisible.
I'll keep you posted!
René
Online mvd71
#4 Posted : 22 August 2008 14:05:04(UTC)
Good idea,
alternatively, you could simply bulid your entire layout from K track.
Offline Macfire
#5 Posted : 22 August 2008 14:28:02(UTC)
Macfire
quote:Originally posted by mvd71
<br />Good idea,
[size=2]RIGHT ON BROTHER biggrin biggrin biggrin
Lord Macca
#6 Posted : 12 October 2008 16:00:08(UTC)
renevoorburg
I bought a kit from Auhagen to build a bridge with. I assumed I wouldn't need K-Track because there would be no 'see-through' parts. However, even with as much of the balast bed removed as possible, C-Track would give an ugly result.
So I decided to use K-Track after all. Here is how I connected C-Track with K-track (a flex rail):
With a dremel-like tool I cut away one part of the C-Track, this as to remove the C-connectors. Now with K-Track rail joiners I was able to connect the rails. Unfortunately K-Track has slightly higher rails. So I had to lower the profile of the K-Track somewhat at the position of the rail joiners. Of course, I did this by removing just a bit at the bottom side of the K-Track rails, not the top! This made it possible to make quite a level connection. I fixed the connection with a drop of superglue applied to the joiners. Further, with a piece of wire soldered to both center rails I assured an electical connection.
Here are some pictures:
René
Offline mmervine
#7 Posted : 12 October 2008 18:27:23(UTC)
mmervine
Great job! Which Auhagen bridge did you use?
#8 Posted : 12 October 2008 22:58:33(UTC)
renevoorburg
[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine
<br />Great job! Which Auhagen bridge did you use?
I posted some more info in my "me and my layout" thread, see https://www.marklin-users.net/fo...ault.aspx?g=posts&t=8263.
Cheers, René
Online mvd71
#9 Posted : 13 October 2008 07:45:49(UTC)
Very good Rene,
It's always nice to see someone with an an eye for detail on track work.Smile
Cheers....
Mike.
#10 Posted : 13 October 2008 11:24:45(UTC)
Great solution René.
This page was generated in 0.561 seconds.
