Offline gachar001
#1 Posted : 10 June 2008 17:56:58(UTC)
gachar001
India
The smoke on my BR50 from the starter set 29821 does not work. When I turn on the smoke, the smoke generator gets hot like it is supposed to but no smoke. If I add a drop of Seuthe fluid on top of the center rod inside the smoke generator, it gets converted to smoke.
I have tried different quantities of smoke fluid in the generator but no luck. I have noticed that the center rod is a little bent and may be touching the side of the smoke generator. I have tried straightening it a little.
I don't know what the make and model of the smoke generator is since it was already in the loco when I bought it.
Thanks.
Gautham
Atlanta, GA USA
Offline elinkjoe
#2 Posted : 10 June 2008 18:31:51(UTC)
elinkjoe
Greetings from Atlanta! I have had this with some of my smoke generators. I had to double check that it was actually in contact with the heating element.
They also seem to have gotten clogged sometimes. For this I let them soak with a full load of oil for half and hour and then started them up and they worked. I have been told they can be cleaned, and they are very delicate. I have never tried that. Good luck. J
elinkjoe
Offline gachar001
#3 Posted : 10 June 2008 22:52:08(UTC)
gachar001
India
[size=1" face="Verdana" id="quote]quote:Originally posted by elinkjoe
<br />Greetings from Atlanta! I have had this with some of my smoke generators. I had to double check that it was actually in contact with the heating element.
Finally get to meet someone else from Atlanta on this forum.
I will try the soaking trick. I know that the contacts are ok since it is heating up correctly.
Gautham
Atlanta, GA USA
Offline rschaffr
#4 Posted : 10 June 2008 23:08:00(UTC)
rschaffr
Some of the Seuthe kits come with a fine wire for clearing the smoke tube in the unit. I have several but have yet to have an occasion to use one.
-Ron
Offline trainbuff
#5 Posted : 11 June 2008 04:18:22(UTC)
trainbuff
I had to reply to this thread being in Atlanta too! I also let it soak but with the smoker turned on. Eventually the BR38 will smoke.
Offline al_pignolo
#6 Posted : 12 June 2008 16:43:17(UTC)
al_pignolo
<br />Some of the Seuthe kits come with a fine wire for clearing the smoke tube in the unit. I have several but have yet to have an occasion to use one.
If you have not the cleaning wire, you can use the wires of electronic components: they have the same diameter.
Pietro
This page was generated in 0.267 seconds.
