Offline black_pete
#1 Posted : 04 June 2008 15:55:08(UTC)
black_pete
Lutz - I noted in a recent picture you posted to the Ae 6/6 thread that there was what seemed to be the edge of a Roco Sputnik displayed with the lights on.
I'm assuming this was the SBB version (46964)with interior and functioning tail light.
Lutz I'm interested in whether you have just added a slider - and if so which one and how this was attached - and whether the modifications also included replacement of the internal electronics with a suitable decoder.
There have been previous posting regarding modifying this item on the Marklin B&G group but I'm very interested in how you have approached this work before I start pulling my own one apart.
Naturally one or two of your excellent photos would be especially appreciated.
Pete
expat Kiwi - now living in Melbourne
SBB Era IV & V - Digital - CS1 - C Track
Offline TTRExpress
#2 Posted : 04 June 2008 22:38:49(UTC)
TTRExpress
Pete,
Welcome to the Forum!
I have converted two of these Roco SBB "Sputnik" models for use with TRIX Express which is 3-rail DC. The instructions for conversion to Maerklin 3-rail AC is as follows:
Follow the Roco instructions for removing the roof of the wagon so that you can expose the lighting unit. You do not want to try to remove the interior of the wagon or attempt to modify the inside assembly.
On the underside of the wagon, between the two axles, create a space for the Schleifer (pick-up shoe) with an Xacto or sharp hobby knife. The Märklin Schleifer (use the short pick-up shoe part no:7175) is mounted on a piece piece of printed circuit board with a small screw on the leading side. The printed circuit board is adhesively connected base of the wagon on a short plastic spacer. The electrical connection is made via a thin wire which is soldered on directly to the copper side of the printed circuit board. If you do no want to use a printed circuit board you can solder a wire directly to the Scheifer. The wire is then fed through a 2mm diameter hole bored in the floor of the wagon into the interior and attached to the lamp. The two wheel pick-ups are attached together to the other side of the lamp.
http://www.stayathome.ch/basteln_diverses.htm
Let us know your progress.
#3 Posted : 04 June 2008 23:19:04(UTC)
Welcome to the forum, Pete.Smile
Offline Ladislas
#4 Posted : 05 June 2008 00:28:03(UTC)
Ladislas
Yes, welcome on board, Pete. I think you are already seeing (thanks to Maurice) what a fantastic resource this forum is.
Offline TTRExpress
#5 Posted : 05 June 2008 05:54:51(UTC)
TTRExpress
Hi Ladislas,
Thanks for the nice words. This is a great forum with lots of folks more knowledgeable than me.
Offline Hemmerich
#6 Posted : 06 June 2008 23:12:00(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by black_pete
Hi Pete,
I hope I can give you a satisfying answer and that you and all others in this forum interested in that subject enjoy some (more than 2) of my pictures too. wink
Yes, it's one indeed one of my favorite waggons. wink
The one you have seen with interior light is actually the first of those nice models released by ROCO, #46960. I equipped it with one of the old sliders #7076, which just needed to be extended for about 2-3mm.
Clip off the roof first (best achieved with finger nails).
The two blue cables from the rail contacts need to be soldered together.
The (in my case black) cable from the slider goes to the now free pad on the light pcb - done! (I simply drilled a hole through the bottom into the toilet; the cable can't be seen then).
For the car with blinking rear light it's not much different, just the light/blinking electronics pcb looks different. An alternative is to use one of today's available short sliders (Märklin or ROCO) and cut/mount them for example onto the bolt #207044.
A mounting hole for the bolt (including screw thread and nut) can be drilled at the small visible mold mark shown by the arrow.
Here another picture of my little Sputnik fleet; very often their prototypes were pulled over the Gotthard, etc. in compositions of even 10+ of those waggons (most left is the above shown #47592 with blinking light - although the roof is prototypically incorrect that's not a big problem, at least for me).
Although the prototypes have mostly been taken out of service (and scrapped) it is possible to find/see some still today, like this one which I found in Basel.
Some of them even survived slightly "reused"! biggrin
Quiz: where was this picture taken? Smile
Offline Zora la rousse
#7 Posted : 06 June 2008 23:24:53(UTC)
Zora la rousse
On the right site of a Dutch container wink.
#8 Posted : 07 June 2008 03:25:47(UTC)
I am guessing it was taken at the same place where this video was taken:
http://www.re-os.nl/preview/068%20preview.wmv
Offline Hemmerich
#9 Posted : 08 June 2008 19:45:57(UTC)
Hemmerich
Zora and Mike,
great - you both got 100 points! But Zora surely earns some extra credit for her wonderful answer!!! Smile
#10 Posted : 08 June 2008 21:46:33(UTC)
Good pictures, Lutz.
Offline Rowan
#11 Posted : 09 June 2008 03:15:53(UTC)
Rowan
Good answer Zora!Welcome to the forum black pete; as you can see, cool forum you have found your way too!
Lutz, fabulous answer.
Smile
This page was generated in 0.806 seconds.
