Joined: 09/04/2007(UTC) Posts: 150 Location: Melbourne, Victoria
Lutz - I noted in a recent picture you posted to the Ae 6/6 thread that there was what seemed to be the edge of a Roco Sputnik displayed with the lights on.
I'm assuming this was the SBB version (46964)with interior and functioning tail light.
Lutz I'm interested in whether you have just added a slider - and if so which one and how this was attached - and whether the modifications also included replacement of the internal electronics with a suitable decoder.
There have been previous posting regarding modifying this item on the Marklin B&G group but I'm very interested in how you have approached this work before I start pulling my own one apart.
Naturally one or two of your excellent photos would be especially appreciated.
Regards |
Regards Pete
expat Kiwi - now living in Melbourne
SBB Era IV & V - Digital - CS1 - C Track |
Pete, Welcome to the Forum! I have converted two of these Roco SBB "Sputnik" models for use with TRIX Express which is 3-rail DC. The instructions for conversion to Maerklin 3-rail AC is as follows: Follow the Roco instructions for removing the roof of the wagon so that you can expose the lighting unit. You do not want to try to remove the interior of the wagon or attempt to modify the inside assembly. On the underside of the wagon, between the two axles, create a space for the Schleifer (pick-up shoe) with an Xacto or sharp hobby knife. The Märklin Schleifer (use the short pick-up shoe part no:7175) is mounted on a piece piece of printed circuit board with a small screw on the leading side. The printed circuit board is adhesively connected base of the wagon on a short plastic spacer. The electrical connection is made via a thin wire which is soldered on directly to the copper side of the printed circuit board. If you do no want to use a printed circuit board you can solder a wire directly to the Scheifer. The wire is then fed through a 2mm diameter hole bored in the floor of the wagon into the interior and attached to the lamp. The two wheel pick-ups are attached together to the other side of the lamp. http://www.stayathome.ch/basteln_diverses.htmLet us know your progress. |
Joined: 21/10/2004(UTC) Posts: 31,704 Location: United Kingdom
Welcome to the forum, Pete.  |
Joined: 09/08/2007(UTC) Posts: 67 Location: Saskatoon, Saskatchewan
Yes, welcome on board, Pete. I think you are already seeing (thanks to Maurice) what a fantastic resource this forum is.
Hi Ladislas,
Thanks for the nice words. This is a great forum with lots of folks more knowledgeable than me. |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by black_pete Naturally one or two of your excellent photos would be especially appreciated. Hi Pete, I hope I can give you a satisfying answer and that you and all others in this forum interested in that subject enjoy some (more than 2) of my pictures too.  Yes, it's one indeed one of my favorite waggons.  The one you have seen with interior light is actually the first of those nice models released by ROCO, #46960. I equipped it with one of the old sliders #7076, which just needed to be extended for about 2-3mm.  Clip off the roof first (best achieved with finger nails).  The two blue cables from the rail contacts need to be soldered together.  The (in my case black) cable from the slider goes to the now free pad on the light pcb - done! (I simply drilled a hole through the bottom into the toilet; the cable can't be seen then).  For the car with blinking rear light it's not much different, just the light/blinking electronics pcb looks different. An alternative is to use one of today's available short sliders (Märklin or ROCO) and cut/mount them for example onto the bolt #207044.  A mounting hole for the bolt (including screw thread and nut) can be drilled at the small visible mold mark shown by the arrow.  Here another picture of my little Sputnik fleet; very often their prototypes were pulled over the Gotthard, etc. in compositions of even 10+ of those waggons (most left is the above shown #47592 with blinking light - although the roof is prototypically incorrect that's not a big problem, at least for me).  Although the prototypes have mostly been taken out of service (and scrapped) it is possible to find/see some still today, like this one which I found in Basel.  Some of them even survived slightly "reused"!   Quiz: where was this picture taken?
On the right site of a Dutch container  . |
You are never too late to become a Märklin fan. |
Joined: 28/11/2007(UTC) Posts: 8,244 Location: Montreal, QC
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by Hemmerich Quiz: where was this picture taken?  I am guessing it was taken at the same place where this video was taken: http://www.re-os.nl/preview/068%20preview.wmvRegards Mike C
Zora and Mike, great - you both got 100 points! But Zora surely earns some extra credit for her wonderful answer!!!
Joined: 09/04/2006(UTC) Posts: 1,278 Location: Brisbane, Queensland
Good answer Zora!Welcome to the forum black pete; as you can see, cool forum you have found your way too! Lutz, fabulous answer.
