Offline Jim Thompson
#1 Posted : 15 April 2008 17:46:09(UTC)
Jim Thompson
I was reading another thread, and a question occurred to me that I was unable to search correctly (remember I am pretty useless at all this wild and crazy technology), so if this has been discussed, please feel free to tell me where to go biggrin... - i.e., which previous thread.
"<u>White</u> LED" vs "-<u>Yellow</u>?- LED" in models confused (keep reading, stay with me - Cool)
Perhaps I am a victim of seeing too (way too) many early photos (both real and transferred to the 'net) and, to me, so many headlamps (oncoming direction) of the loks appear WAY more "Yellow" than "White". Only the much newer ones look "White".
Now maybe I do not even understand the process of illumination wink (especially steam loks) but even night photos show lamps that I can not 'see' how they could show more than a few tens of metres let alone far enough to keep from hitting a loose cow at night [}:)].
So, my second question, like unto the first, would be:
At what point did "White" lights become the norm on proto versus "Yellow"? Or am I completely out-to-lunch confused Have they always been "White" (even the 1950s, 1940s, 1930s, 1920s?) - I am so befused and confuddled...
Thank you, thank you and Peace to all,
Jim (In The Dark (but not with Elvira this time) biggrin)
p.s. - This almost sounds "Prototype" but I am really wondering about the lamps in our models, honest! Cool
#2 Posted : 15 April 2008 18:15:02(UTC)
Jim,
I am no expert but here is what I think happened.
early prototypes had incandescent lamps. Their color is a bit more yellowish than daylight or modern fluorescent lights.
The models also had incandescent lamps.
When we look at such a prototype or model we do not see the light as 'yellow' but just a bright (white) light.
Yellow, Red and Green LEDs were available but they were not used extensively in models, the yellow LEDs being way too yellow.
Then 'white' LEDs were invented. They are really a blue LED with some extra chemicals to make it look like white light. The result is a blue tinge to the light.
These new white LEDs started getting used in models, but they were a little too cool - blueish. So people started producing 'warm' and 'golden' LEDs which were slightly warmer in color.
In my opinion many of these 'warm' LEDs were way too yellow and we have seen models (and the Märklin interior lights) simply being way too yellow.
http://layout.mixmox.com/1/marklin-73400
On the prototype, I suspect most headlights are still incandescent - but they are so bright that when we see them they are so blinding they seem white. (The difference between incandescent and white (sunlight) can only really be seen when seen side by side.) Interior lights in passenger cars migrated to being fluorescent - much cooler than incandescent.
so in a practical sense, for modelling, I avoid 'yellow' or 'warm' LEDs and buy white LEDs only. If they need to simulate flourescent light I use them 'as is'. If they need to look like incandescents, I put a dab of yellow acrylic paint on them and that warms them up just enough.
http://layout.mixmox.com/1/shed-light
Offline spitzenklasse
#3 Posted : 15 April 2008 18:41:51(UTC)
spitzenklasse
Good explanations. Remember ROYGBIV? The colors in white light. The biv, blue, indigo, and violet part of the spectrum can be affected by angle, intensity, even oils on the lenses. they can create a rainbow effect. That also can give a blueish cast to them. My swiis re/460 has white bulbs, not LED's, but at higher speeds, (it's a hammo) the headlights almost seem so bright they look a bit blue. The lenses are plastic, which is made from petroleum.
#4 Posted : 15 April 2008 18:59:00(UTC)
Jim Thompson
Thank you Dale and Mike! Smile
Roy G. Biv rules, dude!
Jim (In a world of his own making biggrin)
#5 Posted : 15 April 2008 20:08:30(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Jim Thompson
<br />Perhaps I am a victim of seeing too (way too) many early photos (both real and transferred to the net) and, to me, so many headlamps (oncoming direction) of the loks appear WAY more "Yellow" than "White". Only the much newer ones look "White".
Even night photos show lamps that I can not 'see' how they could show more than a few tens of metres let alone far enough to keep from hitting a loose cow at night [}:)]
Hi Jim Smile,
you're right on the money, and I'm with you with each single detail !!!
Yep - also to me most of the oldtimers lights appear "yellow", that is
Guess all the confusion came up when some MRR designers tried to work prototypically
and (during the past decade) changed loco lights from "white" to "yellow" ... wink
You're also right with the range of beams. Another point why they invented this one biggrinbiggrinbiggrin
And congratulations on your latest additions you got from the kids Smile !!!
Offline Hemmerich
#6 Posted : 15 April 2008 21:43:02(UTC)
Hemmerich
Just one quick addition regarding the new Märklin LED interior light kits (#73400, #73401):
#73400 is composed of (6) yellow LED's and hence best suitable for earlier epoche car illuminations, #73401 is composed of (6 warm) white LED's and thus most suitable for recent epoche car illuminations.
Note: changed phrase above.
#7 Posted : 15 April 2008 22:27:09(UTC)
<br />Just one quick correction regarding the new Märklin LED interior light kits (#73400, #73401):
what are you correcting Lutz ?
The lighting set I reviewed: 73400 http://layout.mixmox.com/1/marklin-73400
is as you say, yellow. Yellow yellow. Not warm white. Awful yellow, as in yellow LEDs.
I know of no wagon lights that were yellow. In my mind Märklin realised what a cock up it was and then brought out 73401 as a correction. When I ordered the LED lighting sets 73400 there was no mention from Märklin that the lights were yellow or that proper lights would be coming out at a later date. Pretending there is some prototype is just rubbing salt into the wound of the initial rip-off.
Offline Hemmerich
#8 Posted : 15 April 2008 22:40:59(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
Product description of #73400 says "standard"; for #73401 it says "white" - furhtermore the following: "Die Innenbeleuchtungen 73400 (gedämpftes Licht für ältere Epochen) und 73401 (weißes Licht für modernere Wagen)...". wink
http://www.maerklin.de/de/service/suche/produktsuche.html
#9 Posted : 15 April 2008 23:05:26(UTC)
I see you have now edited your post - removing the word 'correction' and substituting 'addition'.
And what the Märklin marketing material says now means nothing. They have in the meantime corrected the product.
#10 Posted : 16 April 2008 00:17:07(UTC)
Jim Thompson
John,
quote:
Originally posted by John Black:
"You're also right with the range of beams. Another point why they invented this one.."
biggrinbiggrin I done forgot about that!biggrinCool
quote:
"And congratulations on your latest additions you got from the kids"
Thanks! He is an ever so helpful engine wink[:o)]
And thanks again to Dale and to Lutz for more insightsSmileSmile! This does seem to be a wide subject. I started out thinking of only the headlight situation, and had not even considered the car-lighting aspect which is a very large facet on this diamond!
Of course, if all engines had an extra pair of eyes in addition to the driver and fireman.....biggrin
Thank you all,
Jim (A little wider focus now)
Offline Hemmerich
#11 Posted : 16 April 2008 04:13:00(UTC)
Hemmerich
I should have quoted your text.
That's why I added my "Note" intentionally. wink
[size=1" face="Verdana" id="quote]quote:And what the Märklin marketing material says now means nothing. They have in the meantime corrected the product.
It means exactly what I posted above: they offer now two different products and even explain when to use which of the two. Maybe it helps if I confirm that the white LED pcb wasn't even yet ready for introduction at the time when the first product was put to market.
The results of your "LED test" with the Ep.V S-Bahn car will surely be different with the new pcb; installing the first one in an Ep.I coach car as suggested by Märklin is quite fine too. Smile
Jim, more and more (modern) Märklin locos will be equipped now with (warm) white LED's; especially with bonded LED pcbs (BR101, 12X, 152, etc.), which is a yet unknown technology for other model railroad companies.
For 2008 models, so far the red SBB Re4/4-I and the Bellingrodt BR59 have now been delivered as well with those white LED pcb's; this is just the start. wink
#12 Posted : 16 April 2008 04:22:37(UTC)
since you have changed your posting, my question is moot - I was pointing out that you did not in fact correct anything. I was taking umbridge at the fact that you initially implied that my post or review was factually incorrect. I did not challenge the information you added.
Offline Roger E
#13 Posted : 20 April 2008 14:32:49(UTC)
Roger E
When adding lights to a couple of locs I found a great source for white LEDs that have proper color temperature and brightness for headlights. They are made by YolDal: http://www.yoldal.com/
Their Golden White LED give a light that is very close to a bright incandescent lamp, while the Sunny White LED looks more like a Xenon light. They certainly look a lot better than the yellow or blue-white LEDs found in many Locs. Their smallest LEDs are SMD 0603 which measures only 1.6 by 0.8 mm and easily fits in H0 scale headlamps (but they are a nightmare to solder). The 0603 size is also great if you want two-color lights - I have done this a few times with the two LEDs mounted in parallel in opposite directions (anti-parallel) such that the color can be selected by changing the polarity.
I also find it kind of strange, and annoying, that Märklin don’t install decent lights in their locs. My last purchase was the new V60 (37655) that came out last year. This still use light bulbs with quite long light guides. The lights only give a faint glow, particularly the top front light, and do not at all look like “headlights”. In time I guess I will replace them with individual LEDs and get a decent headlight beam.
-Roger
#14 Posted : 20 April 2008 17:29:39(UTC)
Jim Thompson
Roger,
Excellent link! [:p] A well done site! Thanks!
Peace and Long Life,
Jim Smile
#15 Posted : 20 April 2008 22:02:47(UTC)
Takk for linken, Roger
Are these available in Europe or Norway, or do you get them directly from Yoldal?
Offline Roger E
#16 Posted : 20 April 2008 23:02:37(UTC)
Roger E
I got the LEDs from LED-Shop24 in Germany: http://www.led-shop24.de/
Seems like a reliable company - responded quickly on e-mail and shipped next day when I ordered.
Offline Hemmerich
#17 Posted : 22 April 2008 23:31:47(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Roger E
<br />I got the LEDs from LED-Shop24 in Germany: http://www.led-shop24.de/
Yes; my same experience. wink
Offline Hemmerich
#18 Posted : 22 April 2008 23:39:25(UTC)
Hemmerich
You haven't yet "experienced" ROCO locos. biggrin
[size=1" face="Verdana" id="quote]quote:My last purchase was the new V60 (37655) that came out last year. This still use light bulbs with quite long light guides.
Although this model was introduced last year, it's basic construction - especially for the lights was about 40 years ago. New constructions usually also have "current light technology, including warm white LED's. wink
#19 Posted : 23 April 2008 01:13:50(UTC)
Jim Thompson
Thanks for the insights and info!
I have an early 1970's 3095 BR74 analogue beauty which (if I am reading my materials correctly) has 3 60010 bulbs which so far are working (35 years is not bad life). However, at some point, they will end with a wimper.
Not to be too rivet-counter, but I think that the golden white would be a better replacement (if they would fit) than the sunny white. My reasoning being the Epoch(s) in which the BR74 ran was before the advent of the Xenon lamp.
Am I correct in this presumption? Or am I out in the ozone somewhere?biggrin
Thanks as ever,
Peace,
p.s. I hope I did not jinx the bulbs by asking this question biggrin
Offline Martin T
#20 Posted : 24 April 2008 00:43:22(UTC)
Martin T
I found it real hard to buy decently priced warm white LEDs in the market. They are all like 3-5 Euros each (5-10 USD ea). It's also a struggle before you actually find the right colour tone that looks good when you snap your photos too. Don`t want the headlights of the loco look blue, yellow, or green even. Antoher problem is that most vendor sell poorly selected LEDs, which means that some is good white, but other are blueish white, in the same bag, on the same P/N. If you still like to tint them, it possible by tinting the LED by painting the lens with thin thin layer of yellow paint.
You also need a protection doide and a serial resistor to protect the LED from voltaghe spikes and get the specified supply voltage to it.
After some serious seacrching I bought one pack of 3mm LEDs, which is 500pcs to bring price down and to be sure to get consistensy in the colour tone. I can tell that I have a few left on my shelf, biggrinafter I retrofitted all of my locos and built an excess of 50 yardlights. Please drop my an E-mail if you are intressted in white LEDs and/or how to integrate them into locos and other illumination on the layout. Im more than happy to assist with the experience I got along the road.
Regards from Martin in Sweden
Regards / Martin T
#21 Posted : 24 April 2008 01:16:42(UTC)
Jim Thompson
Martin,
Thank you for your gracious offer Smile. I will need all the help I can get!wink I thought there might be more to it than just "solder and go".
Peace,
Offline Redd
#22 Posted : 24 April 2008 04:32:02(UTC)
Redd
At what point did "White" lights become the norm on proto versus "Yellow"? Or am I completely out-to-lunch Have they always been "White" (even the 1950s, 1940s, 1930s, 1920s?) - I am so befused and confuddled...
Ah, hush ye now, pore tyke - 'tis not so tough! The change came when "sealed beam halogen" lumps (er, lamps) took over from the "replaceable bulbs" in oxidised reflectors. First, the new halogen gas filling lent a distinctly purplish look to the new lights and gave real power of projection to them (as in "lumens"). The beam, being sealed because the filament had no separate bulb and to contain the halogen gas (well, what did you think here? stick a bare filament in a reflector, and it goes "PHOo-0OT" with GREee-at vigor!), did not allow the reflectors to oxidise. No more finding that there was no bridge whilst going into the rriverr at the self-same instant! How novel! Especially the part where you, the engineer, finds the back of your head suddenly supporting ten passenger cars full of slightly disgruntled passengers!
The old bulbs were a jaundiced yellow due to a weakness of beam; lucky, as you said, to find a cow on the tracks moments before the cow's soul went to hin-doo heaven (my assessment of the logistics!). Methinks that's how "fast food" was discovered (must've happened to a Scotch engineer named MacDonald).
So now, this is why "golden yellow" LEDs are appropriate in locos from the replaceable-bulB aera, and white LEDs (a little purple paint over the business end of those puppies would be guad!) is the choice for loks from the sealed-beam halogen aera. Mind you, to be prototypically correct, you must keep a gaggle of HO-sized cows handy by the trackside at the river if you drive an 01 lok over that bridge anytime soon!
Anyway, these are the only plausible conclusions I have been able to reach as I observe the bright bloo-ish white headlamps on my nieuw Re 482 011-4 "CARGEAUX" (sounds French, eh?) Swiss ellok switch ends whilst circulating happily to-and-fro on my meter-long layout consisting of an ENTIRE length of Marklin flex-track (oh, come now! NO one spells that "MAERKLIN" anymore! My keyboard has no umlauts - does YOURS?). Or, as Jakov Smirnoff would've said: "Wotta GREAT layout"!
Thank you for your rapt attention to this superbly grave matter, lest we return to the cry of the engineers of yore: HOLY COW!!!
The scenery never changes if you're not the lead dog.
Offline Mikael
#23 Posted : 24 April 2008 11:00:54(UTC)
Mikael
[size=1" face="Verdana" id="quote]quote:Originally posted by Martin T
<br />It's also a struggle before you actually find the right colour tone that looks good when you snap your photos too.
I've shown this photo before, but this seems like a good opportunity to get it out in the light again:
Here you can see yellow leds (front right), a cold-white led (cabin of the lok to the left), and finally the same cold-white leds with an orange filter in front of them (in the back).
Here is a closeup of another train, where I am installing these orange filters:
The trick is that these cold-white leds can be found somewhat cheaper than golden white ones. And even using a filter on sunny white leds gives a nice old yellowish white glow, which is perfect for the headlights on old steamers.
#24 Posted : 24 April 2008 16:54:15(UTC)
Jim Thompson
Redd (Yoda? Smile),
(Too many quotes to quote)
Puzzled I was, yea, tho', now I begin to "see the light" ("Those who walked in darkness have seen a great light...")Cool Your historical tale is marvelous! From the cockles of me heart, I thank ye! (Luke! Go toward the Light Side!)
Mikael,
[size=1" face="Verdana" id="quote]quote:a good opportunity to get it out in the light again
biggrin
I love it! A great solution! Somehow [B)] I missed your picture before, so I am glad you re-posted it! Thanks Smile
Peace and all that,
Jim (Quothe the Raven...)
Offline DamonKelly
#25 Posted : 24 April 2008 16:55:28(UTC)
DamonKelly
I don't know if this has been mentioned before, but there exists a "transparent paint" by (I think) Tamiya, which is used for model car tail-lights and indicators.
It comes in (at minimum) yellow and red. You paint it on the inside of the clear plastic tail-light and indicator pieces of those kit model cars -- the high quality ones...
Perhaps with suitable thinning, the yellow transparent paint might be suitable to tone down the "bright white" LEDs?
Damon
#26 Posted : 24 April 2008 17:34:50(UTC)
Jim Thompson
Redd,
I was so engrossed in your story that I forgot to say:
"Welcome to the Forum!" [:I]SmileSmile
Damon,
Wow! Yet another option! This is just fantastic [:p]
#27 Posted : 24 April 2008 23:20:44(UTC)
Yep - welcome here, Redd Smile
#28 Posted : 24 April 2008 23:27:57(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Redd
<br />The old bulbs were a jaundiced yellow due to a weakness of beam; lucky, as you said, to find a cow on the tracks moments before the cow's soul went to hin-doo heaven (my assessment of the logistics!). Me thinks that's how "fast food" was discovered (must've happened to a Scotch engineer named MacDonald).
#29 Posted : 25 April 2008 19:40:18(UTC)
Welcome to the forum, Redd.
This page was generated in 0.693 seconds.
