Offline uwscsi
#1 Posted : 27 March 2008 13:02:48(UTC)
uwscsi
Hello!
I have an old transformator 6177, serial 201775.
I suppose it is around 30 years old.
Anyway I had a fault on the trafo and measured it to be a broken wire in the live terminals. The problem is fixed, but I am still wondering what the part on the picture is and what the purpose of the part are.
Can anyone help me?
www.dammann.no/Trafo.JPG
Offline Guus
#2 Posted : 27 March 2008 13:15:28(UTC)
Guus
Hi Ronny,
Welcome to the forum SmileEnjoy your time here.
The part on your picture is a thermal fuse.
Kind regards
Guus
Kind regards,
Guus
Offline uwscsi
#3 Posted : 27 March 2008 13:24:39(UTC)
uwscsi
Many thanks for your quick and prompt answer.
Nice to know what I am repairing...
I haven't seen this kind of thermal protecting before :)
Anyway, It seems like the cable wired around the ceramic piece is broken.
Is it possible to obtain this kind of parts to day?
Offline charles Sharpe
#4 Posted : 27 March 2008 14:31:10(UTC)
charles Sharpe
Hello Ronny.
Welcome to the forum you will get lots of help they are all a clever bunch of guys/ gal's.
CHARLES SHARPE
#5 Posted : 27 March 2008 21:28:33(UTC)
Welcome to the forum, Ronny.
#6 Posted : 27 March 2008 23:44:10(UTC)
Velkommen til oss, Ronny
Maybe not so easy to find such a part. It may be replaced with a PTC resistor.
Your transformer is the same as 6117, 30VA, but has a different connector.
6177 was made <s>in 1968 only</s> from 1962 to 1968.
A suitable PTC could be a PolySwitch TR250-145, max. current 3,0 A or a LVR 025S, max 3,5 A.
Another is BC Components, typ 663 54913, 3,5 A. They also have a 2,2 A type, 662 53213, but maybe 2,2 A is a little bit "too quick".
They are available from ELFA. They have a shop in Oslo. See http://www.elfa.se/no/index1.html
Offline WelshMatt
#7 Posted : 28 March 2008 01:26:32(UTC)
WelshMatt
Can you buy fuse wire and rebuild it? I managed to do that with a dead laptop PC a week or so ago.
Matt from Wales.
Offline uwscsi
#8 Posted : 28 March 2008 10:55:14(UTC)
uwscsi
Thanks for your splendid feedback. I found out that we actually have different kinds of thermal fuses in our stock at the Naval base. I will most likely acquire one today and see if it solves my technical problem.
So, the trafo is actually around 40 years old... I guess most of my tracks are the same age as well... not bad :-)
Help with Marklin Transformator 6177 (General MRR)
by Lostcajun 24/12/2024 15:47:11(UTC)
This page was generated in 0.584 seconds.
