Offline Jeremy Palmer
#1 Posted : 28 February 2008 16:58:40(UTC)
Jeremy Palmer
Barbados
Hi Everyone,
Sarting to look at display cases for some of locc/wagons etc. Any
feelings on rails or no rails? I remember reading a comment that
traction rings might go flat, grateful for any feedback/thoughts.
Jeremy.
Jeremy.
Offline viragoLDR
#2 Posted : 28 February 2008 17:03:47(UTC)
viragoLDR
Personally I think tracks looks better. Especially for a display case it's important that things look good.
It might mess up the traction tires, but then again, so does driving a train, or even keeping a train stored in a box. Traction tires are generally also fairly easy to replace.
- Martijn
Offline rschaffr
#3 Posted : 28 February 2008 17:07:08(UTC)
rschaffr
I put rails in mine. Since I didn't have to worry about powering them, I used cheap(er) Atlas code100 flex track to put them on. A heck of a lot cheaper than Marklin track.
[image]http://www.sem-co.com/~rschaffr/trains/images/dispcase2.jpg[/image]
However, some cases come with HO scale grooves routed in the shelves. That would work too.
-Ron
Offline ulf999
#4 Posted : 28 February 2008 19:31:52(UTC)
ulf999
I use cheap roco code100 flex in my display cases. Easier the 'align' the cars...
Offline Armando
#5 Posted : 28 February 2008 19:44:49(UTC)
Armando
This is an interesting topic.
Can anyone recommend a display case manufacturer in the USA?
I would prefer to have track inside. It would make the models look more realistic.
Thanks!
Armando García
Offline rschaffr
#6 Posted : 28 February 2008 20:40:00(UTC)
rschaffr
Armando: This is where I got mine. It is near York, PA.
http://www.customdisplaycases.com/train_cases.htm
-Ron
Offline stenscience
#7 Posted : 28 February 2008 22:13:24(UTC)
stenscience
I don't have a display case-I use a standard wall shelf. I use track; I agree that it looks better and helps keep things in line.
#8 Posted : 28 February 2008 22:18:39(UTC)
I have most of marklin on Peco tracks in the display case.
Offline stephenbb
#9 Posted : 29 February 2008 00:29:19(UTC)
stephenbb
The display cases I have have rails on every level. I have switched from M track which I had a lot of to K track it makes all the trains look better.
I hope all is well in Barbados. Sorry I didn't respond to your email. We have been traveling in So. America.
Stephen(USA)
ETE,NMRA,MEA
Offline Armando
#10 Posted : 29 February 2008 02:27:09(UTC)
Armando
quote:Originally posted by rschaffr
<br />Armando: This is where I got mine. It is near York, PA.
[size=3]Thank you, Ron. Are you 100% happy with it? Did you order it with back mirror or without?
Armando García
Offline rschaffr
#11 Posted : 29 February 2008 03:14:50(UTC)
rschaffr
Armando: Yes, I got the mirrored back. I am very happy with it. The one piece door is a little unwieldy, but I don't open it that often and with a one piece front you don't have a vertical line down the middle you would have with a two piece door.
I went the the plant and picked mine up, but they do ship.
-Ron
#12 Posted : 29 February 2008 04:30:23(UTC)
I use all my old straight M-track in my display case.
I like having the old M-track under the older M-track era trains.
My display cabinet: http://layout.mixmox.com/1/train_display
I would like to find a cheap source and could settle for routed grooves in lieu of track
Offline Armando
#13 Posted : 29 February 2008 06:17:02(UTC)
Armando
Thank you, Ron.
If your train room is not in the basement, could the sun light or glare (even if not direct) eventually damage the models exposed in a display case? How could this be prevented? Do these cases come with some sort UV-treated glass?
Armando García
Offline al_pignolo
#14 Posted : 29 February 2008 11:13:09(UTC)
al_pignolo
It seems most people uses rails.
I don't, because my case has shelves made by glass. These are beautiful because you reduce shadows, but for the same reason you don't have to use rails.
Pietro
#15 Posted : 29 February 2008 12:25:21(UTC)
I don't have any display cases, but a member at our local Marklin club has a case similar to Ron's, except the side of the case opens and a whole train can be removed, still mounted on its rails. The train can be taken to a special siding on his layout, connected to the layout, and the train can be driven off without having to re rail anything. Putting the train back in the display case is a matter of driving the train back on the siding, then removing the base with train, and placing it back in the display case.
Rather ingenious I thought (then I saw the recent pictures of the helix, with trains able to be driven off the helix straight into the display case).
#16 Posted : 29 February 2008 12:49:36(UTC)
I do not have rails in my display case.i beleive it is not necessary.
Offline rschaffr
#17 Posted : 29 February 2008 14:15:59(UTC)
rschaffr
[size=1" face="Verdana" id="quote]quote:Originally posted by Armando
<br />Thank you, Ron.
Armando:
The case is made of acrylic and is not UV filtered. This is not an issue for me since it is in the basement, but would be a concern if it were in direct sunlight. I have it lit with a three element traklite with compact fluorescent bulbs.
-Ron
Offline Bob R
#18 Posted : 03 March 2008 01:07:45(UTC)
Bob R
Ron,
Very nice case. I have been looking for something similar. The one you have posted, is it the 72" one?
Bob
Offline rschaffr
#19 Posted : 03 March 2008 01:26:48(UTC)
rschaffr
Yes, it is. That is the length I wanted and they are hard to find. I was about ready to build my own when I found this place.
-Ron
This page was generated in 0.509 seconds.
