Offline nfotis
#1 Posted : 19 January 2008 01:33:33(UTC)
nfotis
Hello there,
I am planning a big reversing loop for our modular meetings, and I am having a 'small' problem.
First, here is the current design for the loop.
I want to make this loop capable of working with both DC/DCC and AC/AC digital (but NOT in the same time).
So, I plan on using K-track flextrack 2205 around the loop.
The question is in the switches:
I plan on using the 2272/2273 (why aren't these in the online shop of Marklin?) or the 22715/22716 and the 2275 Double slip switch on the entrance of the loop.
Do these switches work OK with DC/DCC?
An old-timer insists that at least some short switches are shorted and are nearly impossible to work with DC/DCC, but he wasn't sure about these K-track models.
If these switches don't work on DC/DCC, that is a shame - this will force us to create two different versions of the entrance modules of the loop, one for DC/DCC and one for AC operation [V] - you can see both versions in the design I attached.
Thanks in advance for your help.
Nick the Greek.
Offline kbvrod
#2 Posted : 19 January 2008 02:44:52(UTC)
kbvrod
Hi Nick,all,
The ETE modular group does this.If I remember correctly,the old(4-digit) K-track switches can be used,but needed to be modified,the new(5-digit) K-track can be used as is,as they will work with DC/DCC.
You should have alot of fun with the wiring.Cool
Dr Dirt
Offline ulf999
#3 Posted : 19 January 2008 10:41:49(UTC)
ulf999
I really like this module. turnaround + storage of sets!! 1m radius?
Offline nfotis
#4 Posted : 19 January 2008 16:59:01(UTC)
nfotis
Hello there,
@kvbrod: it seems that the only way to check it is to order these switches and see for ourselves (I would like to avoid messy cutting of rails and strange cabling).
@ulf99: I made a somewhat simplified version yesterday, removing the DKW double-slip switch (it wasn't really necessary), and added a stub-end engine terminal, which can be used inside the loop or in-line with the entrance modules
(note: each green rectangle is 0.5meters big on the side):
The most interior track has 88cm radius, the most external track has 103cm radius, as you rigtly guessed.
I am using 120cm long panels in the outside, but I may go up to 140cm outside panels. The green circle has 250cm diameter in this design (2.5 meters), if you go with 1400mm outside panels, we will get approximately a three meters outside circle.
The plan is to start with the two most exterior loops and 5 switches in total, then expand as needs arise (either adding the two extra loops inside or adding the engine terminal).
If you need a bigger version of the desing for printing, you can download it from:
http://img411.imageshack...=loopproposal3bigyf3.gif
Forgot to say, in the first design in this thread I have done a variation with the long Peco switches (show at the lower part of the image).
As you can see, the two entrance modules that implement the 'Y' junction become a bit longer.
N.F.
#5 Posted : 19 January 2008 17:05:09(UTC)
One can use DC and/or DCC on all types of M. track and switches! ;-)
Offline nfotis
#6 Posted : 19 January 2008 18:10:05(UTC)
nfotis
According to an old-timer, old switches were shorted, so you had to do serious surgery in these in order to work with DC locomotives.
We speak about K-track switches here, don't know what happens with C-track switches.
Regards from Athens,
Nick the Greek
Offline TTRExpress
#7 Posted : 19 January 2008 18:31:16(UTC)
TTRExpress
You cannot use M-track or C-track with out disconnecting the tracks from each other. DC needs the tracks to be isolated from each other. K-track flex track is ideal for DC or DCC. M-track and C-track turnouts will not work with DC or DCC without severe modification.
If you want to use DC or DCC on your layout, incorporate a loop and points from TRIX's DC line of new 2 rail C-track.
Regards (a Scottish Highlander in Wisconsin)
Offline nfotis
#8 Posted : 20 January 2008 00:00:36(UTC)
nfotis
But I thought it was obvious that I am speaking about K-track, no M-track or C-track.
The switches I mentioned are the following:
2272/2273 (why aren't these in the online shop of Marklin?) or the 22715/22716 - do these work with DC/DCC without modifications?
(I removed the 2275 Double slip switch from my design, mostly for cost reasons).
Nick the Greek.
#9 Posted : 20 January 2008 11:24:11(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by TTRExpress
<br />You cannot use M-track or C-track with out disconnecting the tracks from each other. DC needs the tracks to be isolated from each other. K-track flex track is ideal for DC or DCC. M-track and C-track turnouts will not work with DC or DCC without severe modification.
Of course they will work!!!
I use DC power in some stretches of my tracks, and I know of several who change the decoders in their locos to DCC, but keep the slider!
When will people learn to distinguise between 2-rail and 3-rail, instead of AC and DC, which has nothing to do with the number of rails...? wink
Offline nfotis
#10 Posted : 20 January 2008 16:15:03(UTC)
nfotis
Oops, I think I was misunderstood.
Let me rephrase my question:
I want to run either 2-rail or 3-rail trains (let's forget DC/DCC/AC for now).
Will 2-rail locomotives work correctly in the K-track switches I mentioned?
I want to be able in a session to 'play' with 2-rail trains, and later I want to use 3-rail trains.
Hope my question is clearer/more correct now?
N.Fotis
Offline TTRExpress
#11 Posted : 21 January 2008 18:38:46(UTC)
TTRExpress
Nick,
I do not think any of us here are confused between AC or DC or even 2-rail or 3-rail!!
K-track points may work for DC operation, however, as others have stated only with modification and wiring. If you are really want hassle free operation of your Maerklin AC and 2-rail DC/DCC you could use TRIX Express 3-rail DC points. The track profile height is about 1.00 mm higher than K-track so you would have to file down the rails at the contact points between the K-and TRIX track. The nice thing about TRIX Express track is that the 3-rails are electrically isolated from each other so one can easily run AC and DC locomotives on it with no troubles!! You can even run Digital and Analogue on it with no troubles and no fancy wiring!! Since TRIX does not make this wonderful track system any more you can easily find what you need on E-bay. If you decide to use TRIX Express points I would use the newer nickel-silver or Super-track ones that have TRIX Express Nos. 53-4363-00, 53-4362-00, 53-4361-00.
Offline nfotis
#12 Posted : 21 January 2008 23:56:05(UTC)
nfotis
Hmmm, the Trix Express range doesn't have long turnouts, right?
(The 22715/22716 K-track turnouts are rather 'medium' size, compared to the long Peco switches, for example).
Still, I haven't seen someone stating unambiguously that the 22715/22716 switches will run 2-rail DC trains without messing with these.
Any documentation/links? (I will search with Google too).
I am surprised that nobody has tried this combination (I will try to discern in the ETE site if they have something to say on this).
Either I will have to buy one of these switches, or use the Peco loooong turnouts and make a nice (but tiring) conversion demonstrated to me with steel wire in lieu or these damn pukos...
N.F
EDIT. Found this one from ETE: http://www.ete.org/modspecs2.htm#SWITCHES
So, they categorically say these switches work without modification with DC trains...
Offline TTRExpress
#13 Posted : 22 January 2008 00:21:49(UTC)
TTRExpress
Nick,
You are correct, TRIX Express does not have long turnouts. They did make a curved turnout (Bogenweiche). The ETE website does state that the K-track 22715/22716 turnouts will work with both AC and DC. You may want to contact one of the ETE members who has wired these turnouts for their modules. You could send Kurt Miska (khmiska@umich.edu) an E-mail and ask him if he has instructions or knows of another ETE member who does.
Seems like you will still need to do some modification.
Let us know what you find out.
Offline nfotis
#14 Posted : 31 March 2008 23:21:10(UTC)
nfotis
Hello there,
just received my order of Marklin switches from Lokshop - I had ordered 22715 and 22716
(it took more than one month, because they hadn't in stock Woodland Scenics ballast...)
Here is a close-up of one switch
Note that the manual hand throw mechanism can be positioned on the other side of the switch
(yes, these are mine thumbs...)
Here is a side view of the switch.
It looks passable (nearly like a Peco medium switch, excluding the very thick rails)
And now for the shocker - look at these damned pukos head-on [xx(]
Oh well.
Painting and ballasting is 'de rigeur' for this thing, in order to make that less conspicuous.
With a digital multimeter, I checked the polarity in the parts of the switch
(I colorized the various part of it).
Straight position:
Diverging position:
As you can see, the pukos are always 'on', and the frog is insulated
(this may cause problems with small shunters moving at slow speeds, which take power from 1 or 2 axles).
At any rate, these switches look to be very compatible with 2-rail operation
(insert sigh of relief).
N.Fotis
#15 Posted : 31 March 2008 23:31:59(UTC)
Seems like some misunderstandings were present here, you simply want to be able to run 2-rail DC (no pukos used, no shorts between rails) and "normal" Märklin-style (at least for us...) on the same tracks. Kevin did this on his K-track ETE modules as I believe, so he knows what works...
Offline nfotis
#16 Posted : 01 April 2008 00:38:13(UTC)
nfotis
Hello there,
Unfortunately, I have no prior experience with Marklin switches in 2-rail operation, and I was hearing lots of conflicting information until I stumbled upon the ETF pages.
All this FUD (fear, uncertainty and doubt) stuff made me very wary, as you can imagine...
At any rate, I expect to use Peco switches in the future for 3-rail operation, as I detailed in another thread...
Except if Marklin suddently decides to launch a 'finescale' line of track/switches (fat chance...)
N.F.
#17 Posted : 01 April 2008 00:51:33(UTC)
Peco with Erbert studs should be the best of both worlds indeed... Especially for the "DC:ers" who are a bit picky on rail profile sizes... wink
Offline nfotis
#18 Posted : 01 April 2008 01:14:57(UTC)
nfotis
The Ebert studs are for code 100 tracks only, if I remember correctly.
And these aren't looking much better than the think bronze wire I showed in the Peco thread
(note: the Peco rails in 'that other thread' are code 75!).
N.Fotis
Offline kbvrod
#19 Posted : 01 April 2008 07:02:02(UTC)
kbvrod
As I stated before K-track is already capable of both AC/DC .The reason it was chosen for the ETE modules was so that the group could run any of the 4(AC analogue/AC digital/DC analogue/DCC) since we have members who's loks could be run on any system.
Dr Dirt.
This page was generated in 0.553 seconds.
