Joined: 23/11/2007(UTC) Posts: 1,828 Location: Sydney, Australia
Some model trains would have trouble with a curve like that!
There's a tram turning circle like that in (or near) Karlsplatz in Munich, so that's what it might be. In fact there must be quite a few in Munich because all the trams only have driver cabins at one end and doors on one side. The same applies to a number of other German cities. |
Gary Z Scale "Never let the prototype get in the way of a good layout" |
I now suspect that the train visible on the right of the picture is probably actually a tram... in fact now that I follow the tracks I see where they join the road system....
When we lived in Munich our apartment was at Machtelfinger Platz - the end of the line for Tram 16 which stopped running a couple of weeks after we moved in. |
Joined: 08/12/2004(UTC) Posts: 4,430 Location: Attiki Athens Greece
With a similar curve to the other side of track you have a heart.
Joined: 19/10/2001(UTC) Posts: 2,379 Location: Lindome, Sweden
Yes, and the tracks are separated from the other tracks as well. /Lars
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind <br />Yes, and the tracks are separated from the other tracks as well. /Lars
The catenary masts are much lighter too. And to echo Dale's comment, it definitely looks like one of those multiple articulated trams on the right of the photo. |
Joined: 08/11/2005(UTC) Posts: 3,528 Location: Mullerup, 4200 Slagelse
Quote:[size=1" face="Verdana" id="quote]quote:Some model trains would have trouble with a curve like that! Gottardo? [}:)]  ( No, no, don't start here. [}:)] ) Per. |
If you can dream it, you can do it! I, the copyright holder of this work, hereby release it into the public domain. This applies worldwide. In case this is not legally possible: I grant anyone the right to use this work for any purpose, without any conditions, unless such conditions are required by law.  |
Joined: 21/10/2004(UTC) Posts: 31,697 Location: United Kingdom
I think the tram railcar for used city area. |
Joined: 16/08/2006(UTC) Posts: 5,382 Location: Akershus, Norway
The turning radius of the street cars can be rather small.
Just outside Oslo, at Jar station (combined station for subway and tram) it is a U-shaped track with only approx. 35 meters diameter (radius = 17,5 meters). That gives a H0 radius of just 20 cm.
At Google Earth you find it 59 deg 55' 30.27" N and 10 deg 37' 02.42" E. The streetcar returns direction Oslo while the subway, now on the surface, continues westwards. |
Best regards Svein, Norway grumpy old sod
Joined: 14/01/2006(UTC) Posts: 1,802 Location: Wurttemberg
Hi, Yes, this is for turning railcars. It is near the DURLACH - station. But there is something special with this: On this line two-system trains are used which run with 750V DC downtown and 15000 V 16.67 Hz AC on the main -lines. The turn is only used by single-system trains which only can run with 800 V DC. The upper two lines on the picture are 750 V - DC, the other rails are own by the DB. About 3 kms east of this point the train changes the electric-system and both lines are connected. (Grötzingen Bahnhof). The system is very extensive. More than 400kms of rails. In German: http://de.wikipedia.org/wiki/Stadtbahn_KarlsruheIn English: http://web.presby.edu/~jtbell/transit/Karlsruhe/Markus
Thanks Markus, for both the posted information and the link. If I ever get back to Germany I'll be sure to have a look at he system. |
The pictures is fake...! Somebody is folling against you...  Goofy |
H0 DCC = Digital Command Control
Very good site with pictures, Markus.  |
Joined: 23/03/2005(UTC) Posts: 2,497 Location: Denmark
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy <br />The pictures is fake...! Your post is way too late for that statement to make any sense  |
Regards, Benny - Outsider and MFDWPL  |
Nice slim turnouts at the lower tracks.
Joined: 15/03/2003(UTC) Posts: 9,603 Location: Australia
Adrian Australia flag by abFlags.com |
