Offline DCCTRAIN
#1 Posted : 18 December 2007 17:05:48(UTC)
DCCTRAIN
Hello group,
I do not have any PC with floppy drive or serial port.
I have PC with XP, Locobuffer and USB to Serial convertor from ZIMO; convertor works with out any problem with ZIMO MX1, ZIMO decoder programmer, LENZ LI101F. I did not try this adapter yet with Intellibox. But I’m planning to do it soon with RR&CO.
Is there any communication software available (like ZIMO service tool or LENZ software for LI-USB) for Intellibox?
Do I have chance to upload 1.55 to Intellibox with equipment I have. Is anybody did it here? If it is possible please provide step by step instruction.
Alexander Kolesnikov
www.dcctrain.com
#2 Posted : 18 December 2007 22:31:40(UTC)
I ended up buying a USB floppy drive to get it working... There is another thread here.. Have a look at this one https://www.marklin-user...ault.aspx?g=posts&t=5032
I strongly recommend trying the USB->serial adaptor with the computer before upgrading as any communications failure could corrupt the IB code.. I had to buy two before I found one that was reliable.
I really suggest that you find a friend with an older computer that has a serial port and a floppy drive..
#3 Posted : 18 December 2007 23:57:28(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by DCCTRAIN
<br />Do I have chance to upload 1.55 to Intellibox with equipment I have.
You can boot DOS from USB memory stick or CD-R. I don't know if your USB to COM adapter will work in DOS mode.
Offline Maxi
#4 Posted : 19 December 2007 00:49:30(UTC)
Maxi
I have posted my solution in the IBX forum.
The solution will only be available on my website for a short period of time since I will be switching service providers in the new year.
Offline DCCTRAIN
#5 Posted : 19 December 2007 18:35:32(UTC)
DCCTRAIN
Thanks everybody for help.
Matthew, I'm tryng to download file, please check it, something wrong.
www.dcctrain.com
This page was generated in 0.315 seconds.
