Offline Dave Banks
#1 Posted : 20 November 2007 07:48:39(UTC)
Dave Banks
Has any body using the Loksound Programmer 53451 with latest version V2.6.5 been able to upload a sound profile to a loco? The upload gets to the first bar & stops & tells me it that there is an error uploading the image. I have uninstalled & reinstalled. Prior to an upload it asks for a firmware update. Is this all normal or do I have a big problem. <u>Note</u>: never had any problems with the old V2.6.3.version [xx(]
D.A.Banks
Offline pa-pauls
#2 Posted : 20 November 2007 08:54:57(UTC)
pa-pauls
Hello Dave Smile
Do you mean like this : https://www.marklin-user...ault.aspx?g=posts&t=8365 confused
Maybe you have same problem confused[:I]
Pål Paulsen
Offline Sander van Wijk
#3 Posted : 20 November 2007 10:05:27(UTC)
Sander van Wijk
Hi Dave,
Seems like you're experiencing a similar problem as I have. Which firmware version does your programmer have?
Sander
Offline Dave Banks
#4 Posted : 20 November 2007 13:12:50(UTC)
Dave Banks
Hello Pal & Sander,many thanks for prompt reply.The firmware is LokProgrammer Firmware 0.0.1447. I have two hard drives, one has the latest version V2.6.5 & the other the V2.6.3. I can operate with no problem on the older version, so I can only come to the conclusion that the V2.6.5 version is corrupt & I hope that ESU sort it out quick smart. It is tarnishing their reputation as I know a few of the Marklin Users-net readers were contemplating buying one & I still despite this small hick-up encourage them to do so. Another alarming incident that I noticed happened in the process of the upload to the first notch when it won't go any further & by that I mean the first 45 seconds, I observed on getting the programmer to read the decoder, my original version that was on the loco before was wiped & another profile was in its place ( not the one I wanted) & that you could operate the loco on address 03. Have any of you had that happen before?
D.A.Banks
#5 Posted : 20 November 2007 13:27:37(UTC)
Sander van Wijk
Hi Dave,
It might be that you jump to conclusions somewhat too easily, as V2.6.5. in combination with firmware 0.0.1444 works fine. The problem is probably a little bit more complex. (See my new post in the other thread)
However, of course I also hope the problem will be solved shortly... wink
Sander
Offline Dave Banks
#6 Posted : 20 November 2007 13:57:21(UTC)
Dave Banks
Sander, the problem is the r8b.dll. I cannot move the file to My documents as the r8b.dll.is missing. this might be a part of the problem.
D.A.Banks
This page was generated in 0.270 seconds.
