#1 Posted : 13 November 2007 13:00:23(UTC)
I want your help my friends.Is the plastic shell of the front loco
of these sets the same?I had in accident with my 3071,and i found
a front 3070 on ebay.If the plastic shell is similar i am gonna buy
it.confused
#2 Posted : 13 November 2007 18:52:54(UTC)
Go for it, Panayoti - according to KOLL's both plastic shells are identical.
Still better, the older #3070 (1965-1970) got way finer details -
lettering, chromed window frames, plus interior lights [:p][:p][:p]
#3 Posted : 13 November 2007 22:24:14(UTC)
Thank you very much John.biggrin
#4 Posted : 13 November 2007 22:39:53(UTC)
Smile
Offline Roman
#5 Posted : 14 November 2007 02:47:04(UTC)
Roman
The older 3070/4070 shells suffered either from heat(interior lighting) or poor plastic production. Many of them will be warped. They do have the nice window outlining and lights that are lacking in the 3071/4071 as mentioned before. I have the later 3071/4071 that has the deeper burgundy coloring. I'd prefer a straight body myself. Get good side pics before purchasing sight unseen. Good Luck.
#6 Posted : 14 November 2007 05:40:51(UTC)
Thank you for the nice advice.It is difficult to be sure from the
photo for the color.Maybe i have to wait to find a 3071.
Offline Roman
#7 Posted : 14 November 2007 07:14:52(UTC)
Roman
There are two shades of burgundy on that series just to add to the difficulty of finding a matching shell. The later being darker, if I remember right.
I found a source to better illustrate the two colors. It may be quite obvious after all. I don't have both myself.
http://www.bigio.net/Trieb/3071/3071.htm
#8 Posted : 14 November 2007 12:42:56(UTC)
From 1971 to 1986 the 3071 and 4071 was produced in beige/red
1978 to 1989 only it was beige/dark red.
I have one each of the 4071 and the difference is big. The dark one will have to be satisfied with a life on a workshop yard track.
I have installed the light guides from 3070/4070 in my set. Two 610080 bulb connected in series in each car gives a soft and nice light, not genrating too much heat. Add up with the interior and locomotive window set from 3471 or 39700 and a five-star motor (60904 or 60924) and you have a perfect set.
It is some info about it on my website.
#9 Posted : 14 November 2007 15:59:53(UTC)
Thank you very much Svein.
This page was generated in 0.287 seconds.
