Offline Falconrep
#1 Posted : 28 October 2007 20:01:07(UTC)
Falconrep
Can a Marklin Hamo be converted to a 3 rail? I understand that I would need to add a center conductor and Isolate the wheel sets. Is thers someone that could describe how I could under take this? I have an old 8371 ICE train and I love the original way the train was designed with the covers between hte cars unlike the current designs. I've had this run on a 2 rail layout and love the way it runs, Attempts to locate a 3371 at a reasonable price have failed. So I'm down to can I convert this...maybe to digital, with MFX?
Thomas Wondrock
Offline Sander van Wijk
#2 Posted : 28 October 2007 21:11:54(UTC)
Sander van Wijk
Hi Thomas,
First, you don't need to isolate the wheel sets, what would probably best to do is to connect the wheel contacts to one another, this makes that all wheels are connected to the ground. Secondly, a pickup shoe (or two, see below) needs to be added.
Then about converting this model into digital: that's not really easy in a conventional way. I've converted the same model (but AC, non-hamo version) just recently with a great result while using HGH's PCBs, see:
https://www.marklin-user...ault.aspx?g=posts&t=5952
This set of PCBs offers a choice: using two sliders and a mechanism that always switches the one ahead on or using just one slider. The first option is probably best, as it makes that the train will stop in front of a signal, instead of passing it almost completely beforing coming to a hold. I chose to use the first option by the way.
Note that this answer only holds under the assumption that the both models don't differ much besides the electronics in the both heads (which will be replaced completely). If the middle coaches are different compared to the regular 3371, I don't know the answer. Probably HGH knows whether the assumption stated above is right, he's an expert on the 3371 (and other models)
Good luck!
Sander
Offline Hemmerich
#3 Posted : 28 October 2007 21:34:30(UTC)
Hemmerich
Hi Thomas,
there must be really some misunderstanding about converting from DC to AC - instead of isolating the wheelsets you need to solder their wires together! biggrin
In most cases (track dependent) you can even still retain the current wheels. The only thing needed is the contact shoe which is connected to the wires which where previously coming from the contacts of the insulated wheels. wink
Yes, electric wiring / switching direction is different between the DC and the AC model(s).
#4 Posted : 28 October 2007 22:58:46(UTC)
Whilst not an ICE I am in the middle of converting a 216 from Hamo to AC.
I had to change the Bogie where the Slider was fitted to an Insulated one. the Hamo Bogie had no plastic cover and the slider springs came in contact with the Wheel Axles.
This page was generated in 0.240 seconds.
