Offline trainbuff
#1 Posted : 10 October 2007 02:36:13(UTC)
trainbuff
I finally added a current conducting coupler to a 37030 BR 38. The tender coupling mechanism looks like it was made for current conducting couplers. The parts look like the couplers on a coach that takes a lighting kit. Are there parts to take advantage of this undocumented feature? Which other locs are this easy to convert (no drilling necessary)?
Here is a picture with current conductor coupler wired up. I made the piece the wire is soldered to. It goes all the way down to contact the coupler.
here is a picture of the coupler mechanism from the tender and the brass part from the 7318 lighting kit and a current conducting coupler. The angle of the brass Y shaped piece does not match the angle of the tender piece. Does Marklin make one to fit?
Another undocumented feature I found was the current conducting bar in the 7318 kit has a little clip on the bottom that can hold a small wire. Was Marklin thinking about two pole conducting?
I now have Marklin led lights in the donnerbuchsen powered by the 37030.
Offline jeehring
#2 Posted : 10 October 2007 16:34:23(UTC)
jeehring
Thank you for pictures !
I remember , one day , a friend of mine ask for same question at a German dealer.It was about coaches .
The answer was :
about plastic Y shaped piece for coaches there are about a dozen references depending the width of the "Y" , the angle and the lenght too .Depending of the coaches too . But all those for modern long coaches , you can adapt the brass Y shaped piece on it . You need a plastic Y shaped piece with a hole in it .
For me the problem was how to mount those plastic Y shaped pieces on "Gluckauf " coaches . The original plastic pieces on "Gluckauf" coaches have no hole in it , so I cannot install the brass Y shaped piece in it .
I need to buy the plastic Y shaped piece coming from the Rheingold coaches and it is so hard to find a reference .
( Gluckauf coaches ref 42281 are former Rheingold coaches , without interior lights )
I have same problem to install current conducting couplers on coaches from the set 42751 . On those coaches the plastic Y shaped piece has no hole in it . I would like to find which plastic Y piece with hole I could install on these coaches .Similar shape with hole .
About brass Y shaped piece : there is only one reference .( the one coming from the kit ) . But I believe - I'm not sure - it is suitable for most of plastic Y pieces for long coaches . Even if there is no metal plate to make contact , you can easily sold a wire . The goal is to have a nice conducting NEM pocket in which we put any conducting couplers ( one pole )
It is possible to cut "the legs" of the brass Y piece too wink wink
Offline trainbuff
#3 Posted : 11 October 2007 01:04:48(UTC)
trainbuff
Its too bad the references aren't readily available. its a nice feature and Marklin could sell us more parts to add current conduction couplers to our locs and coaches. But it was still nice to find the plastic Y with the hole in it already in the tender. That made the job much so much easier and neater. The initial plan was to drill a hole in the bottom of the tender and run a wire under the tender to a solder joint on the coupler. I'm glad I didn't have to do that. Now I can plug in any coupler I want to.
#4 Posted : 11 October 2007 04:38:26(UTC)
Hi Chris and Roland,
Thanks for the pictures. Very useful information for the future.
Offline jeehring
#5 Posted : 11 October 2007 16:33:16(UTC)
jeehring
[size=1" face="Verdana" id="quote]quote:Originally posted by trainbuff
<br />Hi,
True , the fact of the plastic part with a hole made you a lucky man .
About coaches : you can't even drill a hole because they are different shape , different design .
I hope , with patience , I manage to find some references , I need time .
I know these references do exist
FIrst : the one from Rheingold coaches .
This page was generated in 0.315 seconds.
