Offline TimR
#1 Posted : 26 August 2007 11:49:02(UTC)
TimR
Indonesia
This is my first post. I have been reading through the forum for quite a while and had only recently restarting the hobby with Marklin HO - a recent convert from N-scale Minitrix which I stopped collecting more than 12 years ago.
I bought a 29851 starter set. While the RE460 that came with the set is incredibly smooth running and quiet, after one day of smooth operation, the Ae 6/6 got quite worse. It started to become noisy and stuttering from the speed curve of 40% onwards. I put a drop of oil as per the instruction that came with the set, and things does improve at the top end but the stuttering continued at the mid-range, and the loc remained noisy. All other functions are ok though.
Is there anything practical that I can still do or is it pretty much a warranty claim and off it goes to Germany?
TimR
Now collecting C-Sine models.
Offline DasBert33
#2 Posted : 26 August 2007 12:07:31(UTC)
DasBert33
Did you put the drop of oil on the 5 pole rotor axle? If not, that is probably the source of the noise.
Bert
#3 Posted : 26 August 2007 12:08:58(UTC)
Hi Tim, welcome to the forum. Good to see another Kiwi here.
I'd suggest you check the loco's gears and motor for any dirt / grunge, and clean if necessary. Also check the motor brushes to ensure they are not sticking - just release a bit of tension with a jeweller's screwdriver. Also, you might want to clean the slider and the wheels with some rubbing alcohol, as dirt on them will cause a bad electrical connection. Good luck!!
#4 Posted : 26 August 2007 13:20:33(UTC)
Welcome to the forum, TimR.
Offline MarioFabro
#5 Posted : 26 August 2007 18:03:37(UTC)
MarioFabro
Welcome Tim! I have the same set but both my locos are runningg flawlessly. Sometime, however, with new locos or with some that have been stored for a long time, you get some "stiking" points. I suggest to run the loco without the cover and check all running gear. However, if the problem persists you surely have to contact M* service.
#6 Posted : 26 August 2007 21:30:27(UTC)
I hope you get your Ae6/6 sorted.
Offline TimR
#7 Posted : 27 August 2007 12:17:20(UTC)
TimR
Indonesia
Thanks heaps for all your suggestions.
Have rechecked the Ae 6/6. Some of the gearings were very dry, particularly from the axle heading out of the 5-pole rotor. I had put a tiny drop of oil on the drier sections ( a bit worried that I might be putting too much).
Result: Jerkiness almost completely gone across the range. From 50% power and above the Ae 6/6 is smooth and quiet, and can now run slightly faster than the RE460 Smile It's still making some noise (though nowhere nearly as bad as before) at around 35% range. Will check out further in the next few days whether it can be improved.
The beauty of not living in Germany is that you won't know when you will get your baby back after a warranty claim. [:0] I've only just got the set after an anxious two weeks wait for the shipment to NZ.
Thanks for the welcome..
Offline al_pignolo
#8 Posted : 27 August 2007 17:07:45(UTC)
al_pignolo
[size=1" face="Verdana" id="quote]quote:Originally posted by TimR
<br />Hi
Hi. Tim. Nice to read that things go better...
I have this loco too, and I use it very much... I can tell its mechanics works ever perfectly, and has no troubles even after many hours of working. So I hope it's just a testing problem (may be also it needs a little settlement of brushes?)!
Pietro
Offline TimR
#9 Posted : 29 August 2007 12:52:23(UTC)
TimR
Indonesia
* Updated *
After carefully cleaning the gears and wheels of the loco in the past three days, I can happily say that the Ae 6/6 is now running very smoothly and quietly at any speed range. Apparantly there is quite a build up of dirt inside the loco - so will probably keep an eye on her for a while.
The Ae 6/6 is now so quiet in fact, that I now able to notice that the RE460 would benefit from some cleaning as well.
Lesson is now learnt well. Never underestimate the power of cleaning your locos![^]
Offline Martin T
#10 Posted : 06 September 2007 10:35:26(UTC)
Martin T
[Welcome to the forum, TimR. Unfortunately both the locos and the tracks need a certain amount of overhaul. Worth thinking about before buying too large layout - NOT! biggrinbiggrinbiggrinbiggrin
Regards / Martin T
This page was generated in 0.414 seconds.
