#1 Posted : 01 August 2007 20:33:29(UTC)
CS update English manual now in pdf.biggrin
Please note it came with Germany page 1-23 and english Page 24-44.
http://maerklin-info.de/...S_60212-update_DE-EN.pdf
Offline Gert-Jan
#2 Posted : 01 August 2007 20:36:16(UTC)
Gert-Jan
<br />CS update English manual now in pdf.biggrin
Cewl...now I can be well prepared when my updated CS arrives (before X-mas)
Mosty era III DB.
#3 Posted : 01 August 2007 22:07:12(UTC)
Finally.... Smile
#4 Posted : 01 August 2007 23:25:22(UTC)
Thanks, Steven!
Offline Hemmerich
#5 Posted : 02 August 2007 00:38:27(UTC)
Hemmerich
Seems to make sense since it clearly says now "D" and "GB"; the previous single German version contained 24 pages, with pg. 24 being just the FCC compliance statement and the document ID. (same part number, just dated 05/2007).
So, now we can finally talk "technical English" here!!! Where are your questions? wink
Offline stephenbb
#6 Posted : 02 August 2007 01:15:05(UTC)
stephenbb
Thanks for this information Steven! You would think that our local dealer who I purchased the Cnetral station from would tell me about the English version.
Its great to have such a good group of Marklin friends.
Stephen(USA)
ETE,NMRA,MEA
Offline sudibarba
#7 Posted : 02 August 2007 06:29:09(UTC)
sudibarba
I note that in section 9 that it says that a rocker insulator must be installed between power circuits. M track users, I may be able to help if you can not find them. I can't supply the world but I can Help a few.
ejoerg@comcast.net
Eric
Offline Lars Westerlind
#8 Posted : 02 August 2007 11:07:18(UTC)
Lars Westerlind
Well,
as sudibarba noted, due to this description these awful rocker insulators are required unconditionally when using boosters. Does this mean that the editor is so short sighted that he/she has not taken the new boosters into account, or that there will be no new boosters, or that also these will need rocker isolators?
Other peculiarities are:
- why do they still courage using 24088 for connection; normally several power feeds are needed anyway and branching is easier without it. And they risk that someone puts in the transformer cable in it; warnings in manuals are poor protections.
- I still don't understand the meaning of this adapter cable when running the Mobile Station as throttle. The female socket could as well have been of the right kind from start. Current design does not prohibit errors, not even if throttles will be available in the future either.
- I note that the bus may not be physically branched.
- They keep 3 sockets for Mobile Station, and "encourage" the use of it saying that no damage will be caused using it, except possibly violating EMV-tests.
- Why is it so important that 3-4 aspect signals/turnout should be connected to the same decoder? My theory is that the CS does not properly shut off the decoder of the first adress; if one decoder is used it's OK to send the first command, then the second, then shut off. Strange that they still have such a bug.
So still IMHO,
a major step for mankind - back.
/Lars
Offline jannie
#9 Posted : 02 August 2007 11:11:06(UTC)
jannie
Hi all
Can any of you Boffins tel me wat a rocker insulator is, and what is it's function.
Regards Jannie.
#10 Posted : 02 August 2007 12:32:04(UTC)
Lars Westerlind
AKA ski lifter, inserted at the point of isolation. When current pickup shoe (slider/ski) reaches that point, the forward part of it is lifted to pass over, hence no contact with the new track. If there is enough speed :-( the slider proceeds and tilts over, so that only the forward part gets contact, and now with the new power district/track. In that way it's assured that the slider does not cause short circuit between the two power districts. Normal isolation is needed as well.
My distaste is caused mainly of the fact that in slow speed it's normal that the train stops with the whole slider lifted.
/Lars
Offline Hemmerich
#11 Posted : 02 August 2007 23:02:44(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />Well,
Hi Lars,
this notice is for protection reasons as a 100% equal power balance accross all distributed booster circuits cannot be guaranteed - it is load dependent. It also has to work when still using older boosters (i.e. 6015/6017). Even if you have only a small voltage difference between two booster circuits and you bridge them for some time with a slider it may cause problems. The rockers (should) avoid these.
[size=1" face="Verdana" id="quote]quote:Other peculiarities are:
They offer both - a) using connector box (for "plug and play") and b) direct connection (for example for larger layouts). Please see 2.2.3. (pg.25 bottom and pg.26 top).
[size=1" face="Verdana" id="quote]quote:- I still don't understand the meaning of this adapter cable when running the Mobile Station as throttle. The female socket could as well have been of the right kind from start. Current design does not prohibit errors, not even if throttles will be available in the future either.
I think this has been discussed lenghty (enough) in previous threads. Instead of leaving the MS booster power output open at the 2nd connector of the box and the three CS connectors, they decided to choose the adapter cable to eliminate the booster power instead. The ECoS MS connectors are no different, so it doesn't look like a "design by accident". wink
[size=1" face="Verdana" id="quote]quote:- I note that the bus may not be physically branched.
Not yet. It might be offered at some time in the future. The ECoSlink in the architecture diagram of ESU shows this already; however, until now IMHO no devices (like the Märklin #60125 Terminal) have been specified. Until now I can for example live very well with the terminal and extension cables for my layout (I might publish its digital architecture some day).
[size=1" face="Verdana" id="quote]quote:- They keep 3 sockets for Mobile Station, and "encourage" the use of it saying that no damage will be caused using it, except possibly violating EMV-tests.
You can use these ports, but they are not "EMV guaranteed". The ECoS offers the same functionality and it works there as well.
[size=1" face="Verdana" id="quote]quote:- Why is it so important that 3-4 aspect signals/turnout should be connected to the same decoder?
Should they really? If I connect one of my 3-way signals #7241 with red/green to the last output of one decoder (with address set to 1-4) and (red/)orange to the first output of the next decoder (address 5-8) this works perfect. The only condition is that they use consecutive addresses (see also handbook section 4.3 pg. 37 top).
#12 Posted : 02 August 2007 23:21:33(UTC)
Lars Westerlind
Thanks for polite reply, Lutz!
About 3-4 aspect wirinng, I was referring to the 10.6 and 10.7 notes.
"Die beiden einzeldecoder müssen die gleiche Grunddekoderadresse besitzen". "Müssen" means "must", doesn't it? Might be that it works in other ways, but I wondered why Märklin should say like this? To say that it's because of better overview clearly is rubbish.
Kind regards,
Lars
Offline graafjp
#13 Posted : 03 August 2007 00:11:59(UTC)
graafjp
[size=1" face="Verdana" id="quote]quote:Originally posted by sudibarba
<br />I note that in section 9 that it says that a rocker insulator must be installed between power circuits. M track users, I may be able to help if you can not find them. I can't supply the world but I can Help a few.
ejoerg@comcast.net
Eric
Hi to all,
I read the new manual and as far as I understand a rocker insulator is only required between the power section of the CS and the power sections with boosters. Between booster sections only a mid-rail isolation should suffice.
So when I decide to switch to a CS at least in my setup I can avoid these dreadfull rockers. At the moment my layout is powered with 6021 for digital switching only while the tracks are powered by 2 boosters.
Jos
#14 Posted : 03 August 2007 01:04:40(UTC)
Lars Westerlind
Yes,
rocker insulators were only required between analog and digital sections in the 6021/6015/6017/Delta days. The basics of electricity has not changed, so what Märklin and Lutz tells is that the new power stages are more sensitive to back currents.
In fact your idea is my prefered, Jos. Only drawback is that a mfx lock must be placed on a "programming track" powered directly from the CS to be activated, and then can be used freely on the main track. It sounds absurd, and I tend to think it is, but if you don't like the rocker insulators, and do want a CS, it's the way to go.
/Lars
Offline Hemmerich
#15 Posted : 03 August 2007 01:30:00(UTC)
Hemmerich
<br />Thanks for polite reply, Lutz!
"Die beiden einzeldecoder m�ssen die gleiche Grunddekoderadresse besitzen". "M�ssen" means "must", doesn't it? Might be that it works in other ways, but I wondered why M�rklin should say like this? To say that it's because of better overview clearly is rubbish.
Kind regards,
Lars
Hi Lars,
thanks for your reply.
10.6 is IMHO just a recommendation; if you decide to do it different - no problem. I must admit: in history long, long time ago when I was still controlling my switches solely with keyboards #7072, I used to connect my 3-way signals and switches as well to only one keyboard. It was just a habit, likely due to a better overview and I knew that it basically didn't matter where I connected my nice little banana plugs.
For 10.7: those two single switch decoders #6073 and #74460 have a different addressing scheme than the k83/k84's.
Offline sudibarba
#16 Posted : 03 August 2007 22:23:25(UTC)
sudibarba
[size=1" face="Verdana" id="quote]quote:Originally posted by graafjp
ejoerg@comcast.net
Eric
Hi to all,
Hmmm, I read it that you need rockers between any separate power circuit wheather or not it is a CS circuit to booster circuit or a booster circuit to booster circuit. I don't know, but this seems to be what Lutz is saying previously.
Eric
Offline sudibarba
#17 Posted : 04 August 2007 05:14:19(UTC)
sudibarba
I will send an email to Dr. Tom Catherall At tom@ marklinmarklin.com.
He is our USA representative for all things digital and see what he says.
#18 Posted : 04 August 2007 10:27:49(UTC)
Lars Westerlind
Do so, and tell his answers. I see two possibilites:
1. CS and the new booster have technically weaker power stages than 6021/6015/6017.
2. Märklin want to change policity, in order to minimize warranty repairs.
If 1., grafiip has the correct interpretation, even if Märklin don't want to tell that the old equipment is more sturdy.
2. is also possible, it seems likely or at least possible to me that they do get some boosters and 6021 for repair due to destroyed power transistors; in cost reduction times it's better to get the customer to pay, isn't it?
/Lars
Offline graafjp
#19 Posted : 04 August 2007 18:33:58(UTC)
graafjp
<br />I will send an email to Dr. Tom Catherall At tom@ marklinmarklin.com.
Hi subibarba,
It's interesting to see what answer you get from Tom Catherall.
As I reread the dutch manual I still see that between 60172 booster sections only a mid-rail isolation is needed. So I'm eagerly awaiting the reply from Marklin Usa.
It also says to see the installation instructions of the 60172 booster. Let's hope this confirms what is in the CS manual.
Unfortunately in the ECOSboost FAQ they mention to use rocker-isolations between two booster sections. [:(!]
Jos
#20 Posted : 05 August 2007 00:58:29(UTC)
re pg27 s88s:
I note the reference to the support of 32 units. On the face of this this implies 512 sensors. However I am aware of non-Marklin units that have only 8 ports rather than 16.
pg34 appears to confirm this with the ability to select 8/16 port modes.
So. Is this an inherited/typo (from ESU and the non-Marklin world)? or does Marklin have a 8 port s88? or has the number of sensors really been increased to 512?
#21 Posted : 05 August 2007 03:18:26(UTC)
IF you want to download an English Only Manual you can do do from:
www.toottoot.co.nz.
Nev
Offline sudibarba
#22 Posted : 10 August 2007 05:15:01(UTC)
sudibarba
ejoerg@comcast.net
Eric
Hi to all,
Eric
I have received no reply yet - I will keep trying.
Eric
Offline sudibarba
#23 Posted : 11 August 2007 01:22:38(UTC)
sudibarba
Tom replied from his Blackberry. Exact quote: "Anytime you have power from different transformers,use rockers".
Eric
This page was generated in 1.271 seconds.
