Offline Voller
#1 Posted : 27 July 2007 21:48:53(UTC)
Voller
I want to solder some powersupply-wires to a few pieces of k-track to improve the trains performance on the track, but I'm not sure where to solder. I'm using the standard Märklin color-code for wires. Red is for the studs in the centre of the track, brown for the rail itself.
I can se four places to solder, as seen on the image below. Where to attach the red wire, and where to put the brown? And should I put two reds and two browns on the track (since there are four places to solder)?
As you might hear, I'm used to c-track...
Best regards, Voller.
http://modeltog.voller.dk
Offline rschaffr
#2 Posted : 27 July 2007 22:10:27(UTC)
rschaffr
Voller:
I solder the track studs contact at 5.
[image]http://www.sem-co.com/~rschaffr/trains/users-net/k-track.jpg[/image]
I use .08 black wire so it doesn't stand out.
I solder the ground/earth/mass circuit to both rail joiners to get both tracks connected.
-Ron
#3 Posted : 27 July 2007 23:11:34(UTC)
Hi Voller,
See the pictures at http://layout.mixmox.com/1/laying-track
Red to the underside and brown to the running rails. To solder the brown to the running rails you should slide on a rail connector, crimp it and then solder to that.
Offline rschaffr
#4 Posted : 27 July 2007 23:23:37(UTC)
rschaffr
Personally, I think soldering all sections of rail together is overkill, but to each his own. I may want to someday rip up the layout and reuse the track. Plus, I have had a few instances where I had to replace a switch that failed. It was hard enough to clear the track around it to remove it without dealing with solder joints.
-Ron
#5 Posted : 27 July 2007 23:55:07(UTC)
I only solder a few lengths together that share power feeds. Then there is an unsoldered joint to the next set which are soldered. This would allow me to remove a meter or so of track at a time if I had to. It has not happened yet.
This page was generated in 0.252 seconds.
