#1 Posted : 13 July 2007 21:52:26(UTC)
Dear members...!
As you know yourself,i´m using era 1 models.
I have an question to you:
What type of trackballast should i used to replacement them on the track...?
Shall i use sand like from Faller...?
Or should i use Woodland Sceinic trackballast like "buff" or "brown" medium...?
I´m not so sure how it was under era 1,because there is no colourpictures from era 1 which i can see it...!
I wonder if there was only sand on the track,but are not sure about colourtype of the sand too...?
Goofy confused
#2 Posted : 13 July 2007 23:30:27(UTC)
Busch 7069 will match C track if that is what you want.
David
#3 Posted : 13 July 2007 23:48:54(UTC)
I agreed with David.
You try use busch 7069.See ballast sample picture on
http://www.busch-model.c...og/d/artikel/7069-h0.htm
Make sure carefully on working turnouts.
Offline stephenbb
#4 Posted : 13 July 2007 23:52:25(UTC)
stephenbb
The best ballest i have found is very fine kitty litter. It holds well and the color is great if you want to add some brown color to it mix with coffee grounds.
Stephen(USA)
ETE,NMRA,MEA
Offline Basil
#5 Posted : 14 July 2007 10:33:44(UTC)
Basil
Look at Faller it`s producing ballast for c-track code 171695.
Basil
Offline MärCo
#6 Posted : 14 July 2007 11:48:54(UTC)
MärCo
In Era 1, or the pioneer days of railways, in The Netherlands tracks were laid direct in sand. To model that correctly, you have to buy K tracks and put it on a sand base. Sand was also laid over the sleepers, so only the rails were visable.
Look to this picture of a train at Baarn (nearby Hilversum, around 1890). No ballast is used, only sand.
Another picture at Wassenaar (nearby The Hague, 1907)
So using C tracks and ballast would not be correct.
Absolutly AFB-NOHAB fan ;-)
#7 Posted : 14 July 2007 14:53:13(UTC)
Waowww...! [:p]
Fantastic pictures...! [:p]
I did bought today 3 differents ballast and they are:
Woodland Sceinec B72 fine brown
B73 fine buff
B80 medium buff
B72 and B73 which are fine,looks like more sandtype.
I shall work at home by placement ballast and dirty too after that with colourpowder like earthdust or little more dirtdust.
You will seen the pictures soon from me,by to see the results in differents way.
Have an nice weekend,fellows...! biggrin
Offline Rinus
#8 Posted : 14 July 2007 23:46:21(UTC)
Rinus
Sand? [:0] I wonder what rain would did with the trackballast these days?!
I was wondering, did the coal left a distinctive mark on the trackballast, like the catenary does nowadays?
#9 Posted : 14 July 2007 23:48:14(UTC)
Very nice pictures!
Offline MärCo
#10 Posted : 15 July 2007 01:11:51(UTC)
MärCo
[size=1" face="Verdana" id="quote]quote:Originally posted by Evil R
<br />Sand? [:0] I wonder what rain would did with the trackballast these days?!
Much problems had to be solved in Era 1. Brunel laid the tracks on sleepers in the same direction as the rails, Stephenson prefered rocks. Today we use concrete and ballast. Don't forget much solutions had to be invented in Era 1, and the railways were very young.
#11 Posted : 15 July 2007 14:35:03(UTC)
I have done some work by placement ballast at the track and the results did become very differents...! Smile
First i did painted rust at the sides of the rails,then i did laid ballast and did put Sceinic cement to spray on it.
Under the night,Sceinic cements that stands of woodglue and water did dried so ballast did become hardened.
Finally,i did dirty ballast by using colour powder that was ogrebrown,kind of earthdirt.
The results...?
AMAZING...! biggrin[:p]
The best ballast was Buff fine,that fits good as era 1 type...!
Perfect...! [:p]
Under trainstation stop,i shall dirty little some of black colourpowder where steamlocomotiv are mostly stop on the area of track.
I will take pictures on my results with the track later,so you will see the results...! biggrin
Goofy Cool
#12 Posted : 16 July 2007 02:27:17(UTC)
Good Work Goofy. Look Forward to seeing photos.
N
This page was generated in 0.852 seconds.
