Offline MarioFabro
#1 Posted : 31 March 2007 20:23:38(UTC)
MarioFabro
With reference to my old topic on requesting info on HAG conversions (https://www.marklin-users.net/forum/default.aspx?g=posts&t=3882), I have performed some conversions myself and have been asked about results. It was suggested to post some images and comments on this forum so.. here we go. I listed my HAG locomotives by number and not necessarily by the order I aquired them (almost all from e-bay) or upgraded them to digital.
HAG 150: BDe4/4. Originally AC Analogue, upgraded with Uhlenbrock 76200.
It works but the model is pretty old and the motor is very noisy (3 pole). I left all original components only substituted reverse mechanism with decoder. Another couple of pictures
In this third picture you can see one problem of this model. The pick-up shoe (original or changged by previous owner) is very long and it touches on one end with the locomotive plow, which is in metal and connected to the body and thus to the ground. Result, shorting at every switch. Short term solution: isolating tape at contact point. Long term solution, shorter pick-up shoe.
HAG 181: Ae 4/4. Originally DC, upgraded with Marklin 6090.
This was the first conversion. Very straight forward. Substitute the little connection plate, situated underneath the idle carriage and that connects the pick-up point with the wheels on one side, with a pick-up shoe. All other connections are ok. Then you can add the decoder (in this case a 6090). Motor is 5 pole with permanent magnet. In addition, I added the newer lightbulbls and sockets on the two ends. Here are other pictures.
HAG 182: Ae 4/4. Originally AC analogue, upgraded with Uhlenbrock 76200.
This was the first conversion of an AC Hag. Here I had to change the reversing system with the Uhlenbrock decoder. All very easy and straight forward. Motor is 5 pole. I did keep the original lights here since the decoder has not the return function for the lights (I may have to look if I can do it).
HAG 207: Re 6/6. Originally AC analogue, upgraded with Uhlenbrock 76200.
I upgraded this as described above for the 182. The problem here is that this loco has not good running characteristcs and easy de-railment. The middle bogie had a very "soft" spring and thus it would lift and get stuck under the locomotive body (this is a quite long loco and the middle bogie "shifts" left and right in tight curves). I added a stroger spring but still have some issues with the other two bogies sometime getting stuck under the body. Will have to work more to assure freedom of movement. Overall runs but right now it would receive a "static" position in my future lay-out.
HAG 211: Re 4/4 Swiss Express. Originally DC, upgraded with Marklin 6090.
Same procedure as described for the HAG 181 above. Here is another picture.
HAG 284: Re 465 SBB Zurich Nahverkher. Original digital AC, no upgrades necessary.
Finally a couple of shots of a modern HAG. I found that on the Eisenbahn-Treffpunkt SCHWEICKHARDT website (http://www.modelleisenbahn.com/) and he should still have a few. I have the Marklin cars and Fleishmann end-car for this train so I was happy to get my hands on this. No modifications required and runs flawlessly. Here is another pic.
Ok.. let me know if you enjoyed this and if it loads well on your PC (I may have left the pics too large).
Ciao and happy railroading!
Offline Guus
#2 Posted : 31 March 2007 20:53:43(UTC)
Guus
Hi Mario,
I'm a great fan of HAG,so I like your pictures very much.Seems like you did a very nice job!
Apart from the Re 6/6 ,what are the driving characteristics of the various decoder-motor combinations?
Kind regards
Guus
Kind regards,
Guus
Offline MarioFabro
#3 Posted : 31 March 2007 21:27:40(UTC)
MarioFabro
Guus,
first of all I did not "fine tune" any model or tweak with decoder set-ups. I could also concentrate on any of them to remove some flaws. Here is my personal list, from best to worst.
Re465 #284: this obviously comes factory equipped with decoder and all. Runs flawlessly over switches and all. Motor is vry quiet. Runs very well at low to high speed.
Ae 4/4 #182: with the Uhlenbrock decoder, this loco runs very well at all speeds. Motor noise is very low.
Ae 4/4 #181 and Re 4/4 #211: with 6090 decoder. I don't like their running characteristichs at low speeds (they seem to be running on and off). High speed is OK. Motor is more noisy than above. They also seem to have random problems on switches (sometime they stop, but rarely.) I need to do more tweaking
BDe 4/4 #150: this is simply very old. It runs OK at all speeds but the motor noise is very high (it's a thre pole motor)
Re 6/6 #207: as said, several problems with this loco. Three carriages and it seems that either one or the other gets stuck over switches or sharp curves. Again, I need maybe to put some spacers or make sure they are free of movement when the body is put on. Other that that, it seems to be running decently at all speeds.
Since I will not be able to run all my stock, here is what I think will go DYNAMIC on my lay-out: Re465, Ae 4/4 #182 and probably Re 4/4 Swiss Express. All the rest will probably stay STATIC on a display and such and to be run supervised (only areas where you can reach if the loco stops and such).
Offline Guus
#4 Posted : 31 March 2007 22:01:30(UTC)
Guus
Hi Mario,
Thank you for your comment on the driving characteristics of your locos.
I think it's a real pitty your Re 6/6 doesn't drive that well.Hope you'll find a solution.
My HAG Re 6/6 drives well,although I think the 360 mm radii are a bit tight for this model.
Kind regards
Guus
Kind regards,
Guus
Offline Bart
#5 Posted : 31 March 2007 22:39:54(UTC)
Bart
Many thanks Mario,
Very helpful descriptions.
I do also have the digital Re465, which actually easily gets stuck at turnouts on my K track. Decoder characteristics are fine.
I originally planned to exchange the Hag/Esu decoder for an mfx Loksound, but as can also be seen in your pictures,
the decoder has a non-standard connector. Soldering would be no problem, but I decided to leave the original
Esu in place and use the Loksound somewhere else.
I will be converting my old HAG 150 BDe4/4 with an Uhl 75200 soon, and I'll report on the noise.
Still have to decide how to convert my Re 4/4 I's (permanent magnet or 76200)
*Bart
Offline MarioFabro
#6 Posted : 01 April 2007 03:47:18(UTC)
MarioFabro
Guus, do you also have the Re 6/6 with three bogies? the normal Re 6/6 has two bogies with three axles. My Hag model has three bogies with two axles each, and this is why I wanted it, since I have already three Marklin Re 6/6. I will try to "fix" my model, it may require "shaving" the bottom of the body or put spacers so that the bogie is free to rotate and not get stuck at the end of the curve.
Offline kml
#7 Posted : 01 April 2007 09:09:47(UTC)
kml
Thanks Mario
for posting the pictures.
Will be very helpful to all members.
Much appreciated.
Offline Guus
#8 Posted : 01 April 2007 14:45:38(UTC)
Guus
[size=1" face="Verdana" id="quote]quote:originally posted by Mario:
...do you also have the Re 6/6 with three bogies? the normal Re 6/6 has two bogies with three axles. My Hag model has three bogies with two axles each, and this is why I wanted it, since I have already three Marklin Re 6/6....
Hi Mario,
Just to make sure we're talking about the same loco
A Re 6/6 has three bogies with two axles each; 6/6 in Swiss designation or Bo' Bo' Bo' in German.
As opposed to an Ae 6/6 which has two bogies with three axles;Swiss still call that 6/6 and the Germans Co'co'
Märklin only makes the Ae 6/6 model.
My Re 6/6 cargo Muri HAG Nr.203 (two engined)
Middle bogie has a pickupshoe with this model.
It is this Re 6/6 model I was talking about.It drives very well,maybe helped by the fact that the outer bogies both have an engine.
Kind regards
Guus
post scriptum:
As you may know the prefix R and A are speed designators in Swiss loc names.
Kind regards,
Guus
#9 Posted : 01 April 2007 15:01:06(UTC)
Excellent,thanks for the information and sharing the pictures.
Offline mario54i
#10 Posted : 01 April 2007 15:54:57(UTC)
mario54i
Hi Guus
Is the decoder shown in your picture an mfx decoder ? I see the 21 pin plug.
Mario
Offline Guus
#11 Posted : 01 April 2007 16:14:36(UTC)
Guus
Hi Mario (Paelo),
[size=1" face="Verdana" id="quote]quote:Is the decoder shown in your picture an mfx decoder ? I see the 21 pin plug.
It's an ESU Lokpilot V 2.0 21 pin decoder,also know as HAG 501.
Kind regards
Guus
Kind regards,
Guus
Offline metpo
#12 Posted : 02 April 2007 10:22:52(UTC)
metpo
Thansk for posting pics MArio...allways good that there are HAG-fans!!
Hag is nice..good that you have the BDE: really original model..
Your BDE train looks really much older than mine...
I will maybe in the future also digitalise my AC HAG locs...
Offline Guus
#13 Posted : 27 June 2007 18:44:44(UTC)
Guus
Hi Mario,hi all,
Some weeks ago I purchased an old HAG Re 6/6 (HAG # 207 Balerna) at a modelrailroad fair.The loco was an AC analog model with an old type of electronic reversing unit.
I decided to convert this loco to digital with a Lokpilot V3 decoder.So the motor needed to be changed into a DC version as well.
I've posted some pictures of the process:
Old AC motor with field coil.
Motor after conversion with HAG permanent magnet.
HAG's 21 pin adapter.
Original reversing unit
Lokpilot installed
Hope you don't mind the wire clutter [:I]
The loc runs very well with the ESU recommended CV's, which were easily altered thanks to my trusted old Märklin 6021.
The only thing that wasn't correct right away, was the light switching.The lights lit up opposite the direction of the loc.
Since the magnet of HAG's locos are easily removed, a simple 180° turn of the magnet was all that was needed to cure the problem.
Kind regards
Guus
Kind regards,
Guus
Offline ulf999
#14 Posted : 27 June 2007 20:43:47(UTC)
ulf999
A job well done! I'm reading and learning Smile
Offline Caplin
#15 Posted : 27 June 2007 21:15:17(UTC)
Caplin
Hi Guus
Great buy and conversion and very instructive pictures too. Thanks for sharing.
Benny - Outsider and MFDWPL
Offline Bart
#16 Posted : 28 June 2007 03:27:19(UTC)
Bart
Very well done, Guus.Cool
I'll be visiting the HAG factory shop next week, and I'll get permanent magnets and other parts for a few conversions
*Bart
Offline Guus
#17 Posted : 28 June 2007 11:49:36(UTC)
Guus
Thank you gentlemen.
Don't know whether you've been there before Bart,but I want to say that it's been a very pleasant experience for me last time I was there.
Beware,the factory shop is closed on fridays.
Kind regards
Guus
Kind regards,
Guus
#18 Posted : 28 June 2007 13:58:23(UTC)
Bart : If you are visiting the HAG shop could you ask them when their EW1 coaches will again be available. I have tried mailing them but they never reply.
Many thanks
David
Offline Bart
#19 Posted : 29 June 2007 00:44:01(UTC)
Bart
Yes, I've been there - It's amazing to see where all this great stuff comes from: like an old school building in a farmers' village.
The shop is 2 m sq in the basement, with a window to order.
David - do you mean the green SBB 480 series?
*Bart
#20 Posted : 29 June 2007 00:58:29(UTC)
Hi Bart. Any SBB EW1. eg 51052 52004 etc. (HAG'S newest set of numbers)
I was told that there was a fault in their coach production and no more would be available this year. Looking at their website this does appear to be the case.
Thanks Bart
David
Offline Guus
#21 Posted : 29 June 2007 01:14:13(UTC)
Guus
[size=1" face="Verdana" id="quote]quote:originally posted by Bart:
Yes, I've been there - It's amazing to see where all this great stuff comes from:...
That's what I thought too.It reminds me of the farms here in Holland where they sell their own dairy products.
Seeing all that and meeting the friendly staff I couldn't help but feel a great sympathy for the HAG company.
Here are some pictures taken at last year's Christmas sale:
Entrance of the shop,with Mr. Gahler himself cooking a nice Bratwurst for his customers
The shop is behind the dumpster
Kind regards
Guus
Kind regards,
Guus
Offline Katchina
#22 Posted : 29 June 2007 11:24:31(UTC)
Katchina
Man this workshop/factory makes it seem like HAG (which I had never heard about) is all about locomotive craftmanship ! This looks realllly nice ! Seeing the models, they seem to be of very high quality as well.
If one cannot visit their factory, where would one buy their products at a fair price, either online or in Belgium (or Northern France and Paris, Aachen, Koln) ? I was thinking about buying myself a crocodile to celebrate my 30th birthday next December, but maybe another Swiss beauty would be nice !
This page was generated in 0.816 seconds.
