Offline Sander van Wijk
#1 Posted : 17 June 2007 02:26:14(UTC)
Sander van Wijk
I seem to recall from the 6021 manual that a few models equipped with somewhat older decoders do not function when the 6021 is set to combined usage of the Motorola "old" and "new" format.
Examples mentioned were as far as I can remember:
1. The function decoders in the coaches of the 2681 Wilhelm Zug
2. The Tanzwagen 4998 Function decoder
3. The Kelnerwagen 4999 Function decoder
Here's my question: does anyone know - or have any experience - with the compatibility of the models (or more specifically decoders) in combination with Märklin Systems?
Thanks in advance!
Sander
Offline Hobbit
#2 Posted : 17 June 2007 08:57:47(UTC)
Hobbit
Sander, I cannot comment on Marklin Systems but I am able to operate the lights in the coaches of 2681 via F1, F2 and F3 on my 6021 in both the "universal" mode (DIP 2 on, 1,3,4 off) and the "control unit" mode (DIP 1,2,3 onm 4 off). This is contrary to the note in the manual.
There is no place like The Shire...
#3 Posted : 22 June 2007 13:00:51(UTC)
Sander van Wijk
Thanks, so the 2681 does not seem to be a problem when operating it with Systems. How about the 4998 and 4999? Does anyone have (one of) these items?
Sander
Offline Lars Westerlind
#4 Posted : 22 June 2007 13:28:41(UTC)
Lars Westerlind
AFAIK there is no problem operating the above cars (nor Messwagen) in combined mode. But those cars need to have the original Motorola signal, and I think that wasn't possible with Mobile Station. But with CS it should be possible, shouldn't it?
/Lars
Offline WelshMatt
#5 Posted : 22 June 2007 14:22:14(UTC)
WelshMatt
The Messwagen that measures speed/time/etc won't work with the MS (or presumably the CS) - it just defaults to a scale speed readout with the head lights/tail lights on. I'd therefore assume that other older coaches with function decoders will have the same problem. Pity really, I wouldn't mind a 4998/4999!
Matt from Wales.
Offline antonoyuwono
#6 Posted : 25 June 2007 15:50:59(UTC)
antonoyuwono
Hi all..
I am a new member , and my 2681 interior lights is not working with the central station..
Sander , have you succeeded in controlling 2681 with the central station?
Thanks a lot guys..
antono
#7 Posted : 25 June 2007 16:29:20(UTC)
Sander van Wijk
Hi Antono,
No, up to now, I haven't. As I do not have the 2681 nor the CS yet, I can't. If the 2681 is controllable with Systems, I'll probably buy it. If not, I'll go with the 2881, as it is cheaper. And install other function decoders. (The loco is not functional anyway, neither the Delta, nor the digital version is capable of pulling the complete concist due to a lack of pulling power)
Sander
#8 Posted : 26 June 2007 15:09:58(UTC)
antonoyuwono
Sander,
My S10 from 2681 is capable to haul the 6 wagons..no problem at all.. although it is indeed seem a bit like a heavy burden for the loco..
maybe it will be a problem if hauling the 6 wagons thru some upgrades.. , but as far as i know , it still is working fine..
the 37190 and 37192 works better though..
antono
Offline Hemmerich
#9 Posted : 26 June 2007 17:39:18(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Sander van Wijk
<br />Hi all,
Here's my question: does anyone know - or have any experience - with the compatibility of the models (or more specifically decoders) in combination with M�rklin Systems?
Thanks in advance!
Hi Sander,
these models are not included in the CS/MS loco database.
#10 Posted : 26 June 2007 22:57:19(UTC)
Lars Westerlind
But,
certainly the CS may configure a loco for Motorola old operation? Not?
Also, the old stationary crane and home built decoders use that protocol.
/Lars
Offline Hemmerich
#11 Posted : 27 June 2007 22:33:28(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />But,
/Lars
Correct. Please see also CS Handbook 3.3.2 (Decoder); when you assign a new loco manually, you can choose between "Märklin-Motorola" and "Funktionsdecoder". The latter setting is for those older decoders, i.e. with the CS you can control the cars #4998, 4999, 49960, the crane #7651 or car #58115. You're also able to select the corresponding icons for those functions.
#12 Posted : 09 July 2007 15:41:52(UTC)
Sander van Wijk
Coolness! Now the search for these items can begin... (Well, not to be too enthusiastic: the search for the 2681, for a studentproof-price)
Thanks everyone!
Sander
This page was generated in 0.666 seconds.
