Offline laalves
#1 Posted : 08 September 2004 01:02:24(UTC)
laalves
Hi big scalers, I'm out of my usual part of the forum and with an unusual subject.
I decided to buy this super piece of modelling to vary a bit of what I do in terms of plastic kits modelling, i.e., 1/48 and 1/32 scale aeroplanes.
Since 1/32 is what 1 Gauge is and this Leopold canon is 1/35, I was wondering if I should keep my options open for one day, and put this monster under tow of a 1 gauge loco, in a possible-future 1 gauge layout in my terrace.
First question: has anyone tried or though about it?
Second: what EXACTLY are the dimensions of 1 gauge "gauge"? I mean, what are the distances between the inside-back of the wheels (or axle length) and track gauge?
If 1 gauge is not very much different from this model's gauge, I could convert it's gauge and display it in a 1 gauge track piece and keep it ready for one day run it in a 1 gauge modellers meeting or something like that.
Best,
Luis
Offline 7gauges
#2 Posted : 08 September 2004 06:36:04(UTC)
7gauges
I've seen that kit as well - check this website out:
http://www.48specialmode...6makingof.html#The%20Kit
I'd reaaly like tp try it out, but don't have the patience or skill to build it properly.
Offline laalves
#3 Posted : 08 September 2004 13:43:22(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by 7gauges
<br />I've seen that kit as well - check this website out:
Been there last night checking it out.
About my questions...? Anyone...?
Luis
Offline 7gauges
#4 Posted : 08 September 2004 17:41:18(UTC)
7gauges
45mm is the gauge - the wheels on the Trumpeter kit are 44mm and the Dragon kit 43mm. The Dragon kit is much less expensive, not as detailed (apparently) but much easier to build.
With 12 axles, I doubt you could have this car run through even a 2 metre radius curve in 1 gauge (certainly not through marklins 1020mm or 1174 Radii) .... but I guess running it up and down straight track would be OK .
The appropriate loco is a class 52 steam engine or possibly a V188 diesel, plus several box cars and flat cars as well as 1 or 2 passengers cars.
I have a complete (all cars) Leopold set in HO converted to Marklin from a cheap Lima model...very nice, I still need to get the turned brass gun barrel to replace the crappy Lima gun.
Offline laalves
#5 Posted : 08 September 2004 21:21:59(UTC)
laalves
<br />45mm is the gauge - the wheels on the Trumpeter kit are 44mm and the Dragon kit 43mm. The Dragon kit is much less expensive, not as detailed (apparently) but much easier to build.
Great info, thanks! I happen to have one of those Lima sets too! But I haven't done the conversion yet. I have had a life-long passion for th K5 gun (well I like the humangus Dora, but that is not practical....)
BTW, the 52 or V188 sound like mainline locos. What about manouvering locos? Would the V36 be apropriate? I imagine that it wouldn't be practical to maneuver the gun a few meters back and forth to get a sight with a 52 or even a V188.
Luis
Offline 7gauges
#6 Posted : 09 September 2004 07:17:10(UTC)
7gauges
Because of the shear mass of this thing and the associated train, they would have used the v188 or the br52 series to haul the guns. Perhaps they did use a v32 as well - though it doesn't seem powerful enough to do the job.
The aiming of the weapon was certainly not done by the locos - in and of themselves ... in fact I believe the weapon wasn't actually on the railline when it fired. The massive recoil would have destroyed the railbed - or that's what I take from the actual pictures I've seen.
Oddly enough I believe the gun had limited manouvering capabilities on two axles on either end ... I may be mistaken on this ... but I do recall reading something to tha effect.
Offline laalves
#7 Posted : 09 September 2004 14:21:55(UTC)
laalves
Actually, it could be fired in two ways AFAIK. In a whole supporting turntable, and in the rails. The picture in the Trumpeter box is the first one, but that's not what it's in the box. In the box comes a rail cross with a small turntable in it. Check that at http://www.48specialmode...r-e.html#Diorama%20preps
It was for this aiming situation that I wondered if a shunter loco would be used. I talked about the small V36 because I can get a resin/white metal 1/35 kit for 125€..... or a BR75 steamer for the same price. CMK makes a magnificent BR52 steamer in resin for 450€ but that's waaaaaaaaay off of what I want to spend. The K5 itself cost me 79€ so....
Luis
Offline laalves
#8 Posted : 14 September 2004 05:08:18(UTC)
laalves
7gauges,
Here's what I found on V36 and Leopolds:
http://www.aopt91.dsl.pi...uns/German/K5-calais.htm
They were used to pull Leopold guns in and out of tunnels/shelters.
BTW, also found out that the V188 was a purpose built machine for the Dora 800mm giant gun. There were two of those guns and two V188 were needed for each of them. Apparently, no more V188s were built during WWII. This way it seems that V188 wouldn't be easily found towing Leopolds, which seems to contradict Lima.
Huhu, this getting off-topic... Should be RR history. Sorry webmaster...
Luis
Offline 7gauges
#9 Posted : 14 September 2004 08:59:19(UTC)
7gauges
Yes ... I kind of suspected these guns didn't move far..... i.e. out of bunkers and back in.
Although I'm not sure but there were railguns used in the siege of Sevastopol that travelled through the USSR from Germany - what engine was used is anyone's guess.
Offline laalves
#10 Posted : 14 September 2004 17:04:06(UTC)
laalves
<br />Yes ... I kind of suspected these guns didn't move far..... i.e. out of bunkers and back in.
Actually, there were plenty of railroad guns in the Sevastopol siege, including the aforementioned Dora 800 mm. This 1500 ton monster required a special double curved track, purpose built on site. The gun was carried dismantled, towed by the V188s. At the firing site it was erected, the special track were built and the aiming adjustments were by means of the V188s that towed the gun back and forth in the curved track.
In the end of the siege, the gun was returned to Krupp's proving ground, where Willi, the second 800 mm gun was (it never left) and both remained up to the end of the war. Both were destroyed by the Germans, prior to surrender.
According to what I read, an indeterminate number of 280mm K5 Leopolds, Brunos and 600 mm Mörsers were also used on that siege.
Extensive use was made of RR guns in Russia and little in the Western front. Notable exceptions are Anzio Annie (a surviving K5 in Aberdeen, USA) which actually were two, destined to Tunisia, but stayed in the Milan area until the Allies landed in Anzio; another pair of K5s at Pas de Calais, firing over the English Channel, and some Brunos and Siegfrieds, also firing over the Channel. One these survives today in the same city's museum of the Atlantic Wall.
Luis
Offline jonquinn
#11 Posted : 02 January 2005 01:27:03(UTC)
jonquinn
here is a link for a scratch built "Dora" RR gun in 1/35 scale.
http://www.aopt91.dsl.pi...ls/HO_1.35/doramodel.htm
I have the Dragon model, as well as a few freight cars which I have not built yet. Apparently the car located behind the K5 gun (breech side) was always a special refridgerated van/boxcar with a I-beam trolley/hoist extending from the end that was used to keep the shells climate controlled. I have not built it yet, but as stated above, the Dragon model is more simplified than the Trumpeter (also about $40 less). Still both reported to be very good models. The metal barrels are a must.
Offline laalves
#12 Posted : 02 January 2005 02:42:02(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by jonquinn
<br />here is a link for a scratch built "Dora" RR gun in 1/35 scale.
Mmmmmmm..... Very interesting and I didn't know about that special fridge car. Have you got any pics/photos/references about that?
I'm just doing the finishing touches on my Trumpeter version. I'll post a couple of pictures for you here.
My future intention is to make a big diorama, depicting a station, some Märklin turnouts and track, say four parallel tracks, with a few freight wagons and a lok. Now, the lok could either be a CMK BR52 (it's a beautiful resin expensive model.....) or a more modest Märklin BR80, straight from a 1 Gauge starter set.... It would be a cool way to get an excuse to try 1 Gauge....
Luis
Offline jonquinn
#13 Posted : 02 January 2005 04:17:48(UTC)
jonquinn
http://www.e94114.de/Eis...pold.htm#Eisenbahndienst
http://www.network54.com...amp;messageid=1093249959
http://www.one35th.com/model/k5/k5_frme.htm
the first links two mention the climate control car for the ammo. I thought Reynauld's at one time had a car for their military line (they do have one for their HO Dora - only $2500, which includes the Dora). Details on these trains is somewhat sketchy, but there are a few good websites - see above. The first link is all german, but I have translator software that was able to convert into passable english for me.
With some kit bashing and replacing the 1/35 Leopold wheels/axels with Marklin spares, this should work - stretch the trucks if needed. The kit plastic wheels may not take the beating either. I have heard some complaints about some if the Chinese plastic model kits having brittle plastic - not a problem for display models however. You would probably need to put in some ballast in the bottom of the gun carriage, and maybe some sheet metal under the trucks, because this thing will be top heavy and may be prone to derail/topple without.
Offline jonquinn
#14 Posted : 02 January 2005 05:03:56(UTC)
jonquinn
http://www.waffenhq.de/panzer/k5-eisenbahn.html
here's another link about ammo storage/handling for the Leopold/K5. On the first page they have a picture of a small diesel loco pushing a K5 - it looks like a V36, or maybe a Kof? I tried to copy the photo could couldn't get it into the message box here (I can't get HTML on, which would probably help)
an except of the translated page is below:
"The ammunition supply was very costly: Each gun required one ammunition, Kartusch, and Temperierwagen. The latter was connected with the Kartuschwagen by hoses in order to bring the Kartuschen on the necessary temperature. In the fire position, bridges then became between ammunition feeder road cars and Kartusch -, as well as caisson transfers in order to transport the ammunition into the drawer hollows. The shuttle dares the ammunition then transported to the gun where a crane lifted the laden hollows on the drawer cart of the gun. On the rails of the drawer platform of the cannon, this cart then was put to the shutter where projectile and Kartusche were introduced electrically over a slipway in the tube. If one shot from a turntable, a car transported the drawer hollow on a ring track to the gun."
also, you might want to hold off on the CMK BR52 resin kit. There is a Baluard WRC-14 small diesel loco that may be the one in the photo I reference above. It is "only" $180 at Mission Models. Maybe this can be kit bashed to run on Marklin 1? I have read rumors on plastic military modeling discussion pages (Missing-Lynx) that Dragon or Trumpeter may bring out 1/35 big wartime steam loco, and if they do, it should be a fraction of the price.
You could also put some 1/35 panthers or lighter tanks on the 1 gauge SSy45 flatcars. The Tigers would need a 6 axle flat, of which there can be found some resin kits.
Offline laalves
#15 Posted : 03 January 2005 03:08:35(UTC)
laalves
Thanks for the info. And yes, I do intend to depict some tanks, probably Panzer III and/or IV, since I have painted my K5 in grey, which would make typical 1943-5 three colour Wermacht camo with panzergrau together a bit more unlikely.
Anyway, to my knowledge, Leopold itself never went to Russia, so a realistic scenery would be either Leopold going to Calais or to Anzio, where it eventually was captured, together with it's twin, Willy.
What I'm planning is a 1941 war-busy trainstation scene, with a brand new 1/32 Hasegawa Fw190 dismantled in a flat car, inbound to Abbeville (home of the JG26, the "Abbeville boys", first operators of the type, 1941), maybe even two of them, and some closed cars in one line. On another line, Leopold, maybe with one car or a small shunter loco (to my knowledge, V36 were used to pull/push K5 in/out of shelter tunnels to fire), and in another line a few 4-wheeler SSy (I believe the specific type you mentioned) with a few Panzers on them.
Around all this, several soldier figures, as well as DRG personnel.
This would be a challenge and a nice way to combine my modelling fields of interest, aeroplanes and trains. Armour is a secondary interest, but does indeed also fascinate me.
Tomorrow, I'll shoot a few pictures of my Leopold and post them here; I believe it'll be ready by then.
Luis
Offline jonquinn
#16 Posted : 15 January 2005 22:24:59(UTC)
jonquinn
any photos yet?
Offline laalves
#17 Posted : 16 January 2005 00:58:16(UTC)
laalves
Sorry, not only I didn't have the time to finish this monster, I also forgot all about the photos.
Here it is as of today:
Some paint work is still missing, such as the forward part of the canon tube, exhaust staining is still missing, dusting the lower undercarriage areas and also some rail painting on the base.
Missing from the photos: the interconnecting planking, ladders, hoses, ammo trolley, some guard chains and control mechanism lid. All still in the touch up area of my workbench.
Hope you enjoy them!
Luis
Offline jonquinn
#18 Posted : 16 January 2005 01:11:20(UTC)
jonquinn
looks like excellent workmanship and painting/weathering
#19 Posted : 16 January 2005 01:46:20(UTC)
I agree, this is great work.. I used to be plastic model builder (It still have a 1/2 finished 1/16 scale King Tiger under my bench!), but I was never able to get the weathering and the authentic look with my models. Well done. Please keep posting the pics..
Offline laalves
#20 Posted : 09 August 2005 18:04:14(UTC)
laalves
Time to update this thread with the loco I'm building to go with the K5, an armoured Wannentender resin CMK BR52.
I envy those Märklinists who can afford, both in plain €€€ and square metres, to do scale 1.....
Luis
#21 Posted : 09 August 2005 19:25:35(UTC)
You have been a member since:: 22/04/2004(UTC)
WOOOW, Luis - she's cool !!! Congratulations, excellent work [:p][:p][:p]
Offline laalves
#22 Posted : 10 August 2005 01:32:45(UTC)
laalves
<br />WOOOW, Luis - she's cool !!! Congratulations, excellent work [:p][:p][:p]
Thanks John, I'll post some more pictures as I go along. This a very beautiful piece of modelling technology, and my sample will be camouflaged in standard Wermacht colours of the epoche: panzergrey, red-brown and sand yellow.
The tender will bear an impressive heavy armour. The cabin armour is already in place, and the boiler sides will be armoured with, mind you, timber!!!!
Like this: http://www.hannants.co.uk/search/?FULL=CMKRA031
Luis
#23 Posted : 20 August 2005 13:28:18(UTC)
Woooow! Big cannon train,what lengths is the set and what make on cannon train?
Guest (9)
This page was generated in 0.651 seconds.
