Offline cjh26
#1 Posted : 27 February 2007 03:22:30(UTC)
cjh26
I really like the Lange Heinrich set how well will double heading work since the locs are not tied together to a common decoder
Carl
#2 Posted : 27 February 2007 04:45:53(UTC)
With the CS Create a Consist.
N
#3 Posted : 27 February 2007 09:12:55(UTC)
Under MS control this would be a problem given the mfx decoder in the 44.
Either 6021 (native motorola using the same address) or CS (Consist) are options.
The Motorola solution restricts the number of functions that can be controlled however the CS has other stupid restrictions about the use of functions for the non-leading loco.
An IB offers better (less restrictive) control of the functions of both locos in consist mode and is able to control 9 of the 12 fuctions using the motorla 2nd address.
Also of general concern to anyone wanting to run a consist is the use of dead sections and/or braking sections. In these cases surgery to remove one pickup shoe is desireable if not required.
#4 Posted : 27 February 2007 13:38:44(UTC)
<br />CS has other stupid restrictions about the use of functions for the non-leading loco
Didn't know this, Peter - please tell me more ...
Offline cjh26
#5 Posted : 27 February 2007 13:49:30(UTC)
cjh26
Thanks all. I am interested in the
CS Option of creating a consist.
Carl
#6 Posted : 27 February 2007 15:37:08(UTC)
CS can do double heading as well.
I have test double heading with 37841 and 37884 and run very wellSmile
Offline cjh26
#7 Posted : 27 February 2007 15:44:21(UTC)
cjh26
Thanks, I like the set wish they weathered the engines
carl
Carl
Offline pmgsr
#8 Posted : 27 February 2007 16:01:08(UTC)
pmgsr
[size=1" face="Verdana" id="quote]quote:Also of general concern to anyone wanting to run a consist is the use of dead sections and/or breaking sections. In these cases surgery to remove one pickup shoe is desireable if not required.
Hi clapcott,
What do you mean by "breaking sections"? Are you refering to the problem of having two pickup shoes with circuit tracks / reeds or there is something i didn't fully understood? [:I]
Pedro Rosa.
Linda-a-Velha / Lisbon, Portugal.
My Layout (Marklin, C-Track, Digital)
#9 Posted : 28 February 2007 18:33:28(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by cjh26
<br />Thanks, I like the set wish they weathered the engines
carl
Yeah,So am I.
Offline Charlie
#10 Posted : 28 February 2007 18:45:43(UTC)
Charlie
Interesting...on the braking section, one locomotive would get the signal to brake, while the other had not entered the section yet, and would push full steam ahead?
Charlie
#11 Posted : 28 February 2007 21:17:03(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by pmgsr
[size=1" face="Verdana" id="quote]quote:Also of general concern to anyone wanting to run a consist is the use of dead sections and/or braking sections. In these cases surgery to remove one pickup shoe is desireable if not required.
Hi clapcott,
Aside from the spelling mistake ...
there are 2 issues.
The principle is based on the behavior of most modern decoders to slow-to-stop when they detect a negative DC voltage on the track - The deceleration is set in the decoder.
So the first issue - just as with a dead section - is that one loco is driving and the other one is stopping. either way one will end up spinning its wheels or drawing excessive current.
Because the track voltage is different the sections must be isolated. This includes isolation from the loco shoe/pickup shorting the two sections as it passes over. the witches-hat can work here, however the marklin solution is to have a transition track that switches from one feed(main line) to the other (bracking) when the locos(s)/train is on it. This must be done with the contact or circuit track or reed switch etc. As above this transition track must be long enough for both (or all) locos in the consist so they switch at the same time and do not drive against each other. When the train leaves the stop section the transition track should not be 'reset' to the main line until the train (all pickups) is fully clear of it.
#12 Posted : 28 February 2007 21:23:12(UTC)
Basically you cannot work the functions of the 2nd, 3rd .. locomotive/coach independantly of the 1st.
Offline Hemmerich
#13 Posted : 01 March 2007 10:58:48(UTC)
Hemmerich
Sorry to correct you - but your statement isn't correct. I do this all the time (mostly in conjunction with my MS's); for example turning the lights of the middle loco in a MT off.
If I'm not completely wrong, some enhancements for MT operation will also be included in the next CS update.
#14 Posted : 01 March 2007 20:22:46(UTC)
Yes I did say 'basically' and you identify one 'restrictive' work around.
In your case is this middle locomotive Motorola or mfx ? Do the lights turn on again when you contol the train using the consist object?
#15 Posted : 01 March 2007 23:18:46(UTC)
Thanks, Peter
Offline Hemmerich
#16 Posted : 02 March 2007 17:27:00(UTC)
Hemmerich
Hi Peter,
you said "basically you cannot work the functions of the 2nd, 3rd loco independantly of the 1st" and my statement is "basically you can (also) do this".
Very simple:
1. place "loco1" to the left side controls of your CS.
2. call up a consist (or create a new one) on the right side controls.
3. add "loco1" to the consist list
-&gt; you can now run all trains in that consist list together AND you can still control speed, direction and functions of "loco1" with the left side controls of your CS, even while you drive at the same time with the consist by the right side controls.
And Yes, if you turn on/off the lights of your consist it will also turn on/off those of "loco1" (since it is part of the consist), but you can as well still turn those of "loco1" off/on or whatever else you like to do with that loco, independent from the consist.
And no - this functionality has nothing to do with mfx. It will work as described above with any loco/its decoder.
Offline Davy
#17 Posted : 02 March 2007 17:49:41(UTC)
Davy
<br />Under MS control this would be a problem given the mfx decoder in the 44.
You make one mistake a mfx loc with MS has no number 44. So when the speed of both mfx locs is the same. You could drive both of them with a MS. Problem is starting en stopping of the two locs. But a slave MS can be a big help with this.
The address 44 is only for motorola controllers.
M-track with a CS2.
Offline Hemmerich
#18 Posted : 02 March 2007 19:00:00(UTC)
Hemmerich
As Davy stated, the MS situation with 2 "long Heinrich" or any other locos equipped with mfx decoders would be similar to the DB Cargo V100 double set (#37726).
The best and sensible solution besides using 2 MS's is to use/buy a CS and run them as consists.
#19 Posted : 02 March 2007 19:52:32(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Davy
<br />You make one mistake a mfx loc with MS has no number 44. So when the speed of both mfx locs is the same. You could drive both of them with a MS. Problem is starting en stopping of the two locs. But a slave MS can be a big help with this.
If you have a booster between MS and track then you can use address 44 for both locos and control them with the MS (because the mfx feedback gets lost in the booster).
Guest (6)
This page was generated in 0.535 seconds.
