Offline rugauger
#1 Posted : 21 November 2006 11:18:14(UTC)
rugauger
I have an Uhlenbrock 76900 function decoder in my 4077 Steuerwagen (cab control car). f0 switches between white light and red lights depending on direction of travel. f1 switches the baggage compartment lighting. [:p]
Whenever I put my 3072 with HAMO and ESU Lokpilot v2.0 on the track and drive it, the UB decoder starts going funny: the baggage compartment light starts going on-off-on-off, and the decoder won't respond to any commands from the 6021. I have to press Stop+Go on the 6021 to get it working again. But as soon as the 3072 starts going, it's the same all over.
For info, the 3072 is fitted with the capacitor between the brushes as well as the coils between each brush and each motor feed. Also, the problem only occurs with this particular loco! Other locos leave the UB decoder alone.
Any help appreciated!
Richard
Offline Sander van Wijk
#2 Posted : 21 November 2006 13:55:07(UTC)
Sander van Wijk
Interesting, I've had exactly the same problem with a Fleischmann (AC) train equipped with a Lokpilot V3.0 and a 76900 function decoder. After adjusting some values of the 76900 the problem did not occur often anymore. (However, it is not completely gone) I don't know exactly which values I've changed unfortunately, but among them was the value to set the automatic system detection of the 76900. I've programmed it to work only with Motorola. Probably that solved it. Anyway, I'm very interested in other ideas for solving this.
Sander
Offline Lars Westerlind
#3 Posted : 21 November 2006 14:19:38(UTC)
Lars Westerlind
What adresses do you use? Possibly a change of the 76900 adress could help?
/Lars
Offline pa-pauls
#4 Posted : 21 November 2006 15:27:23(UTC)
pa-pauls
Yes, agree with Lars,
Try and change adress on the function decoder 76900,,,
Maybe also change adress on the 3072 loco if it doesn't help,,,
What is the analog CV on the loco decoder set to ?
Disable it if the adress change doesn't help,,,
Pål Paulsen
#5 Posted : 21 November 2006 20:22:26(UTC)
Sander van Wijk
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />What adresses do you use? Possibly a change of the 76900 adress could help?
/Lars
In my case :
- both decoders were set on adress 29. (Purely because they have to "cooperate" in the functioning of one train.
- The analog CV has been set so that analog is not supported.
Sander
Offline rugauger
#6 Posted : 21 November 2006 20:25:58(UTC)
rugauger
Friends
As always, I'm indebted to you for your help - thankyou.
I also thought of changing the automatic system detection on the 76900 after I had made the post - this will be my next step. It is not the address because I have since tried another vehicle that also has a 76900 (with a different address, of course), and that has the same problem.
So I will change the auto-detection mode and see how I get on; I'll keep you posted...
Thanks again guys
Richard
Offline rugauger
#7 Posted : 21 November 2006 21:27:01(UTC)
rugauger
Hello again
Well, changing the 76900 to "Motora only" made no difference. So I'll try and fiddle with the Lokpilot instead...
Richard
Offline pa-pauls
#8 Posted : 21 November 2006 22:56:04(UTC)
pa-pauls
Yes Richard,
As I did say : What is the analog CV on the loco decoder set to ?
Pål Paulsen
Offline rugauger
#9 Posted : 22 November 2006 00:37:24(UTC)
rugauger
Pal - do you mean CV50 - analog mode? It was set to 3 (default, meaning both AC analog and DC analog = on). I changed it to 0 (no analog mode), but it didn't change anything. As a matter of fact, neither did any of the other 5,000,000 CVs that I tried... [}:)][:(!][:(!]
I even tried the decoder in a different loco (oh the beauty of NEM plugs!), but still the same. [:(]
I've sent an email to ESU support.
EDIT: I just had another look at the two chokes between the motor wires and the brushes. According to the colour code, they are 1.9uH (the Marklin standard value, I think). However, on the ESU web site, they recommend 3.9uH. Uhlenbrock even recommen 10uH for their decoders. Would/could that make a difference, you think?
Richard
This page was generated in 0.268 seconds.
