Offline MartinB
#1 Posted : 13 November 2006 23:25:14(UTC)
MartinB
I am currently buidling the controldesk and I have some trouble with a particular K-track switch motor. The switch can be trown back and forth a few times without problem before it gets "stuck". The switch motor is not strong enough to thro the switch back.
Any suggestions?
Best regards MartinB
Märklin Systems
K-track and C-track
Deutsche Bundesbahn Ep.3
#2 Posted : 13 November 2006 23:44:58(UTC)
Mechanical; Check for debris between any moveable parts. Is any part damaged or bend?
Electrical; One (or two) of the coils may have burnt. Your trafo may be giving less than needed.
Offline Rowan
#3 Posted : 14 November 2006 04:58:31(UTC)
Rowan
Yeah mate ,as Henrick said check the operation of the moving parts.
Use a fine screw driver to move it manualy.Does it feel free? Need a clean? A drop of lubrication?
Is the solenoid hotter then normal after a couple of tries?
Offline al_pignolo
#4 Posted : 15 November 2006 18:58:07(UTC)
al_pignolo
If you installed the motor below the baseboard (kit #7549) check the small inge that moves the tongues: it often flexes without throwing the switch ([:(]).
#5 Posted : 19 November 2006 21:01:53(UTC)
Is is below baseboard? if so, give up, they are nothing but trouble. I have a number of turnouts mounted that way and one of my next tasks is to redo them and mount the switch motor upside down and above the baseboard. The underside of the motor which is now uppermost can be landscaped to blend it into the trackside landscape. The silly wire pin mechanism of the below baseboard mounts is hopelessly under-designed.
I also have a tip for moving the switch manually if you are unable to get to the switch from below..
http://layout.mixmox.com/1/Switch_motor_thread
Offline hmsfix
#6 Posted : 19 November 2006 23:07:53(UTC)
hmsfix
Hi Martin,
I wonder whether your turnout problem comes from the turnout motor or from the mechanism in the turnout.
You could perhaps check that by inserting another turmout motor to the respective turnout, or you could insert the turnout motor in question in another turnout.
Some time ago I've had very strange difficulties with a K turnout, too. I first suspected the 7549 turnout motor not working correctly. However, the true origin of the problem was a bent tie under the turnout tongue.
Hans Martin
Offline MartinB
#7 Posted : 19 November 2006 23:19:20(UTC)
MartinB
Thanks for all replies Smile
I have been ill since tuesday and have not been able to work on the layout. I hope to investigate the problem further during next week. I'll let you know how things work out.
Märklin Systems
K-track and C-track
#8 Posted : 20 November 2006 20:22:55(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
Good idea!
I´m not sure I can use it (need it) myself, but I very much like the "out of the box" thinkin for that solution...
Offline MartinB
#9 Posted : 24 November 2006 00:10:44(UTC)
MartinB
this evening I investigated the problem further. The turnout is placed just inside the tunell, so I had to gently remove the entrance in order to access the turnout. I first vacumed the turnout without any improvement. I removed the solenoid and tried to move the tongues back and forth. Even if it is a brand new turnout they kept moving back when I moved them in one direction. After lubricating all moving parts the situation improved drastically, and now the turnout works just fine Smile
Märklin Systems
K-track and C-track
Offline steink
#10 Posted : 24 November 2006 17:46:42(UTC)
steink
[size=1" face="Verdana" id="quote]quote:Originally posted by MartinB
<br />Hi all,
What sot of lubritation du you use?
Offline MartinB
#11 Posted : 24 November 2006 19:30:02(UTC)
MartinB
[size=1" face="Verdana" id="quote]quote:Originally posted by steink
Hi Stein,
I thought about using silicone spray or 5-56, but ended up using Märklin oil. Time will show if it was a wisw choice [:I]
Märklin Systems
K-track and C-track
Offline al_pignolo
#12 Posted : 26 November 2006 00:21:11(UTC)
al_pignolo
<br />Is is below baseboard? if so, give up, they are nothing but trouble. I have a number of turnouts mounted that way and one of my next tasks is to redo them and mount the switch motor upside down and above the baseboard. The underside of the motor which is now uppermost can be landscaped to blend it into the trackside landscape. The silly wire pin mechanism of the below baseboard mounts is hopelessly under-designed.
I totally agree with you. The below baseboard mounting kit works very badly! I was thinking about replacing it with tortoise motors. Someone has tried them?
Pietro
Offline rschaffr
#13 Posted : 26 November 2006 05:14:43(UTC)
rschaffr
Yes. They work great. I buy the Marklin underboard mounting kit and throw most of the parts away. I attach the above board parts (the little tab that clips into the switch mechanism and the box that covers the mechanism) and run the Tortoise up through the hole. Works great. Top reliability, but they are a bit noisy. They also take up a lot space underboard, so if you have a passing track below the switch you can't use them.
You do realize that you need to drive them with a constant on device such as a k84 or equivalent, not a momentary power like the k83. You also have to build a rectifier bridge since the motor is DC.
I bought another brand motor which is smaller and sounds more quiet on the test bench, but have not as yet had a chance to install it. Maybe next week. I don't recall the manufacturer and am not at home right now. I will post it when I get home.
-Ron
Offline jte
#14 Posted : 26 November 2006 11:15:35(UTC)
jte
The problem with Märklin undertable kit is the too thin wire. I did build my own turnout motors of cheap tin can motors. Manual operation is easy with mom-off-mom switches (DC), but points decoders need additional relays (á 2,-€).
So far they have been functioning trouble free (4 years now).
More info on my homepage.
Offline al_pignolo
#15 Posted : 26 November 2006 13:48:54(UTC)
al_pignolo
Thank you all for the good tips... Smile Smile Smile
rschaffr: good suggestion to keep the above parts. I know I should give to this motor continuous DC power; I think that a relay could be a good solution.
jte: your idea is GREAT [:p]! I will look at your homepage and try to build one of them!
Offline al_pignolo
#16 Posted : 11 December 2006 22:29:15(UTC)
al_pignolo
In these days I had another idea about motors: has someone tried the servos used in airplane models? They are similar to tortoises and are muche cheaper!
Offline rschaffr
#17 Posted : 11 December 2006 22:55:31(UTC)
rschaffr
Not a bad idea. Also quieter. I'll have to look into that. I have a few placed I'd like to put a Tortoise, but I don't have underboard clearance. That would solve the problem.
BTW, I installed that other type motor (can't recall the name right now) and I don't like it. It moves too fast, almost as fast as a solenoid switch. But it does ahve less "underhead" and where I used it a tortoise would not fit, so it stays.
-Ron
This page was generated in 1.214 seconds.
