Offline Gert-Jan
#1 Posted : 13 October 2006 22:22:13(UTC)
Gert-Jan
The lamp for the light on the back on my 4411 Gedeckter Güterwagen is broke after 10 years of service.
Now I have to replace it and as usual first times are the hardest.
Any clue on how to replace it? Since I am quite 'clumsy' on such matters I am afraid to break it the wrong way....
Do I need to take of the whole brown upper body? Thus handeling the clamps on both ends right under the couplings?
Or can I take out the slider and the bulb with it? Thus kinda like the 7323 lighting?
Mosty era III DB.
Offline Sander van Wijk
#2 Posted : 13 October 2006 22:26:51(UTC)
Sander van Wijk
Hi Gert-Jan,
Yes, to open the 4411 and replace the bulb you'll need to handle with the clamps on both ends. Remove the coupler first to have a clear vision on what you're doing. It can help to use a pincet. Usually they're pretty sturdy so you don't have to be too handy to get it done without breaking something. wink
The bulb is as far as I can remember indeed the same one as in the 7323 kit.
Sander
Offline Hemmerich
#3 Posted : 13 October 2006 23:05:58(UTC)
Hemmerich
Hi Gert-Jan,
just proceed as stated by Sander.
1. Remove the couplings: (be careful with the screwdriver not to break off the shunting step!)
2. Clip off the body (as said - VERY carefully; again, a screwdriver might help in lifting the body):
3. Replace the bajonet bulb (#600150; as you can see it cannot NOT be replaced by taking out the contact shoe):
4. Clip everything together - done!
Offline MärCo
#4 Posted : 13 October 2006 23:39:52(UTC)
MärCo
And if you have opened 4411, you might want to do this —>
https://www.marklin-user...59&SearchTerms=66045
Absolutly AFB-NOHAB fan ;-)
Offline Gert-Jan
#5 Posted : 14 October 2006 00:15:47(UTC)
Gert-Jan
[size=1" face="Verdana" id="quote]quote:Originally posted by MärCo
<br />And if you have opened 4411, you might want to do this —&gt;
Thank you all for the advise...clear pictures Lutz!
I hope it will open without breaking off [:I]
Actually, I did search for '4411' on the forum but got no hits...but putting a light-switch decoder in would be cewl!
But I think I will stick to fitting lamps for now biggrin
Mosty era III DB.
This page was generated in 0.241 seconds.
