Offline dbmike
#1 Posted : 08 October 2006 05:18:43(UTC)
dbmike
Ok, I got the new to my line 3048 class 01 pacific running like a champ, all cleaned up and smooth running, the smoke generator works, barely, so I think a new replacement one is in need here, Does anybody have a spare to sell or a good source of older parts in the USA? Thanks Mike T
Due to budget shortfall, the light at the end of the tunnel has been turned off....mgmt.
Offline Markus Schild
#2 Posted : 08 October 2006 11:46:36(UTC)
Markus Schild
the smoke-generator for 3048/3047.. is still available from Marklin. The spare-part-number is 600250, the original name in German "RAUCHPATRONE".
Markus
Offline Vardex
#3 Posted : 08 October 2006 13:06:55(UTC)
Vardex
A 7226 is the same,this will also fit.
Bart
#4 Posted : 08 October 2006 13:25:12(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Vardex
<br />A 7226 is the same,this will also fit.
Bart
He is right,it will fit in it.
#5 Posted : 08 October 2006 21:34:13(UTC)
if its digital, and depending on what sort of decoder you have, you may want to consider inserting a relay for the smoke unit. See
http://layout.mixmox.com...stalling_digital_decoder
for pictures showing how In stalled a relay in my 3048 for the (analog) smoke generator...
Offline Vardex
#6 Posted : 08 October 2006 23:13:57(UTC)
Vardex
When you order #215620 you will get the wire to clean the needle that is in the smoke generator! Maybe it will smoke like new then. Price according to M is 0,74E,
#600270 is a new needle (Also 0,74E).
Bart
Offline dbmike
#7 Posted : 08 October 2006 23:47:31(UTC)
dbmike
Thanks for the suggestions, I might try running a real fine wire down the pipe to see if that helps. It is an old analog loco, this layout will not have digital on it, so neither will the locomotives. Thanks Mike
Offline dbmike
#8 Posted : 09 October 2006 21:37:40(UTC)
dbmike
I got it working better now, I stripped a real thin piece of solid wire and probed it down the pipe in the middle, then filled up the generator with fluid and let her run for a good hour, works great now, but this cheapo smoke fluid, made for lionel size trains really smells bad! Need to find some good scented smoke fluid, preferably that smells like coal smoke! Cheers Mike
This page was generated in 0.415 seconds.
