Offline Brakepad
#1 Posted : 24 December 2009 10:51:46(UTC)
Brakepad
France, Metropolitan
I'd like to get myself a christmas present. I was thinking about getting the weathered Trix BR44 and convert it to 3-rail, OR getting a Märklin 39160, which is certainly more expensive, but is already converted and uses a C-sine motor.
The price difference between the trix item+conversion & the Märklin item is quite small; Thinking that the Franco-Crosti is a somewhat "different" locomotive, I'd like to get some information on this 39160, mainly in terms of reliability (have you had/heard of any problems with it?), smoothness and pulling power.
Many thanks for your feedback.
Offline tekin65
#2 Posted : 24 December 2009 11:15:37(UTC)
tekin65
Turkey
Hi brakepad,
I'd say go for Crosti!
It is a very good model with immense pulling power, it has an older fat C-sine motor.
It is also a delight to watch; an extraordinary loco, very nicely detailed.
Some detail photos of the model here: http://marklinciyiz.biz/index.p...&id=72&Itemid=61
Cem.
Now all eras but no ICE
#3 Posted : 24 December 2009 11:37:15(UTC)
Brakepad, can I tempt you somewhat?
The 22044 at 150 euro plus a Loksound at 120 euros plus postage would be about 280 euros. Does the Franco-Crosti have sound, which your Trix loco would. I haven't converted my 22044 yet, but Cem may have done his.
Edited by moderator 11 January 2011 17:00:17(UTC)  | Reason: Not specified
Offline tekin65
#4 Posted : 24 December 2009 13:39:15(UTC)
tekin65
Turkey
<br />I haven't converted my 22044 yet, but Cem may have done his.
Hi David,
I have installed the decoder and sound but no need for 3 rail conversion as of now ... I ran it on 2 rail for a few times; running very nicely but a bit of gear noise.
I plan to do some touch-ups on weathering.
You see brakepad, now you have to buy both biggrin
Cem.
#5 Posted : 24 December 2009 13:45:08(UTC)
Well........I got as far as clipping the pickup shoe on to the tender......but no decoder yet!
Offline tekin65
#6 Posted : 24 December 2009 14:50:59(UTC)
tekin65
Turkey
<br />Well........I got as far as clipping the pickup shoe on to the tender......but no decoder yet!
I really haven't checked the undersides; do you need to cut anything? Is snapping on the slider enough?
Cem.
Offline TimR
#7 Posted : 25 December 2009 04:47:16(UTC)
TimR
Indonesia
Cem.
If there are two pickup wires (like in T22148) - you'll need to cut the other pickup wire - make sure just the one wire going to the clip-on pick up. That's about it....
With the Trix you'd want to leave the DC wheels to save cost - no great disadvantage IMO; though usually DC models came with less traction tyres compared to Marklin version - T22044 came with 4 though, same as the Marklin one.
I've seen people actually replaced these with AC wheels for a more "proper" conversion.
Now collecting C-Sine models.
#8 Posted : 25 December 2009 04:57:58(UTC)
Cem.
Cem, there are 3 DC pickups. The front one is screwed on, and the other 2 are clipped on. The pickups make contact with 3 contact points mounted in the centre of the chassis. I clipped a pickup shoe over the rear contact point, there is no need to modify any thing else, as the other 2 contact points will no longer be touching anything. And as Tim suggests, I think you could leave the DC wheels on it, the track return would be going to one side only in that case.
#9 Posted : 25 December 2009 06:01:53(UTC)
BETTER idea, the Trix has 2 Pickups on each Pair of Wheels. One Positive , one Negative. Cut the red Wire and Solder to the Black Wire. Now two earths (track returns) to the wheels. Solder the red to the Central Slider.
#10 Posted : 25 December 2009 06:32:25(UTC)
Sorry Nev, not so, the 22042 and 22044 has three pickups, all of them on the positive side. Remove all three, replace the rear one with a pickup shoe, and leave the other two unconnected. As far as I can make out there is no need to remove or re wire any wires.
No need to solder the red wire to the Central Slider, it is already connected to the contact point just the same as a Marklin loco would be. Clipping the pickup shoe on means the shoe will make contact with the contact in the loco's body. No soldering required.
Offline Davy
#11 Posted : 26 December 2009 18:25:30(UTC)
Davy
The Marklin franco crosti loc. Is a very good loc with the old sinusengine, it has a better engine then the Trix br44.
I have the Franco Crosti loc and she drives very good on c, k and m-track.
M-track with a CS2.
#12 Posted : 26 December 2009 19:25:47(UTC)
Given the choice between one which is factory ready, and one which you have to convert, I would go for the factory ready one. Even more so if the cost is about the same.
Offline TroyYang
#13 Posted : 26 December 2009 23:57:49(UTC)
TroyYang
I'll take the BR42 for sure.
There is additional expense/hassle/risk in converting a Trix DC Br44 into a Marklin AC model too!
Troy
San Francisco, USA
Offline Davy
#14 Posted : 27 December 2009 00:09:19(UTC)
Davy
Picture of the franco crosti.
UserPostedImage UserPostedImage
M-track with a CS2.
#15 Posted : 27 December 2009 00:18:40(UTC)
I also have the Franco-Crosti. Runs very well with the original big C-sine motor. Sounds a bit "electric" at speed step 1 though, as all the old big C-sines do...
Offline Brakepad
#16 Posted : 27 December 2009 00:20:33(UTC)
Brakepad
Cem.
Thanks for all your replies and the nice pictures, guys.
Cem, I'd take both, unfortunately my budget does not agree with me, and neither does the FD... biggrin
Offline applor
#17 Posted : 27 December 2009 05:43:17(UTC)
applor
I have converted the Trix BR44 to AC.
It is extremely easy, all you need to buy extra is the pickup shoe.
I used the existing DC connections on the wheels as extra earths.
I have the 39161 as well, its very nice just no sound.
#18 Posted : 27 December 2009 07:06:22(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by applor
<br />I have converted the Trix BR44 to AC.
That was my conclusion regarding converting the Trix locos. Replace the rear pickup with a pickup shoe, remove the other 2 pickups, and plug in a decoder.
#19 Posted : 27 December 2009 12:47:32(UTC)
Applor, did you fit a decoder to your Trix Br44?
Offline Brakepad
#20 Posted : 27 December 2009 14:48:24(UTC)
Brakepad
Finally purchased the Franco-Crosti on an eBay auction. Now I have to wait for some time until it arrives...
Offline tekin65
#21 Posted : 27 December 2009 18:34:02(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by Brakepad
<br />Finally purchased the Franco-Crosti on an eBay auction. Now I have to wait for some time until it arrives...
Congratulations brakepad, you'll like it.
Cem.
Offline TimR
#22 Posted : 27 December 2009 18:49:14(UTC)
TimR
Indonesia
Didn't really think that you could go wrong with either choice Smile.
Large Sinus steamer vs reasonably priced weathered steamer.
#23 Posted : 04 January 2010 12:25:14(UTC)
Well done Brakepad, I hope you enjoy your new loco.
Since we talked a bit about converting the Trix locos to AC in this thread, I thought I would post some photos.
The first photo shows the 3 contact points under the loco. The 2 contacts on the tender had clip on DC pickups, and the front DC pickup was held by a screw. The photo shows all pickups removed
The 2nd photo shows an AC pickup shoe clipped on to the tender over the front contact.
Because I do not have decoders for these locos yet, I thought I would try an experiment. The locos come with a small circuit board plugged into the decoder socket which allows conventional DC running. I thought I would try running 3 rail DC on Marklin track, with the loco powered via the pickup shoe. I connected a 12v DC power supply to the Marklin track and put the loco on the track. The loco ran very nicely down the track, and I was able to reverse the loco by reversing the connections on the power supply. So I expect all that needs to be done for AC running is to plug a MM/mfx decoder into the 21pin socket.
Edited by moderator 11 January 2011 16:55:24(UTC)  | Reason: Not specified
Offline tekin65
#24 Posted : 04 January 2010 12:37:10(UTC)
tekin65
Turkey
David hi,
Thanks for the photos and the info.
I wonder if it would be equally easy to convert by installing the pick-up shoe to the loco?
Cem.
Offline epierre
#25 Posted : 04 January 2010 16:07:09(UTC)
epierre
I had the gray and the black Franco Costi, sold the black to keep the insider version.
Excellent lok, although no sound.
Offline tekin65
#26 Posted : 04 January 2010 16:11:46(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by epierre
<br />sold the black to keep the insider version.
I think black one IS the Insider model, gray one is MHI.
Cem.
#27 Posted : 04 January 2010 23:36:03(UTC)
<br />David hi,
Cem.
I think so Cem, all that appears to be needed is a pickup shoe and a Marklin compatible 21pin decoder.
You can use the same pickup shoe as from 37889 Br44 - part no 206370. It clips on underneath the loco.
Offline GSRR
#28 Posted : 21 May 2010 15:52:16(UTC)
GSRR
I found this concerning the AC conversion of a Trix 22043 or 22044. It is in German however.
http://www.dreileiter-ma...0Umbau%20BR44%20Trix.pdf
Thomas
#29 Posted : 22 May 2010 02:20:38(UTC)
Thanks Thomas.
Offline applor
#30 Posted : 22 May 2010 09:43:39(UTC)
applor
Yeah its running a loksound MFX. Its pretty cool and I love the weathered look.
My BR44 has a very noisey motor though, I don't know why and I can't seem to fix it.
Offline GSRR
#31 Posted : 22 May 2010 14:40:13(UTC)
GSRR
Bigdaddynz wrote:
Thanks Thomas.
Sure Dave. Wish I could read German, looks helpful. Tried Google translate but it does not like .pdf Came out a mess.
Thomas
This page was generated in 0.940 seconds.
