Offline tworail
#1 Posted : 18 December 2009 18:22:23(UTC)
tworail
What are the options for using some ballast around the M tracks? I have seen quite a few good examples from members here through their pictures, but I have not seen the material in any shop or online before.
I bought some woodland scenics two different colors but both do not really match, and would need some weathering to fit in better.
Offline tekin65
#2 Posted : 18 December 2009 20:49:39(UTC)
tekin65
Turkey
I have used aquarium sand. I'll try to find the right colour if you wish. They are cheap like 1 Euro per 250 grams (or more - in wieght that is).
Cem.
Now all eras but no ICE
Offline tworail
#3 Posted : 18 December 2009 23:11:53(UTC)
tworail
Ah, that is what it is :) I noticed it on your old M track layout and some others around here but could not figure out exactly what it was.
Thanks Cem :)
Offline perz
#4 Posted : 19 December 2009 01:12:37(UTC)
perz
I have used sand mixed with a little bit of medium ground black pepper.
Offline Martin T
#5 Posted : 21 December 2009 17:08:10(UTC)
Martin T
I guess it most depends on how you are manging your trackbed. If you use the M-track "as is" or rather said "Exposed", then I would go for Perz recommendation of sand + pepper. The other solution is to cover the sidings of the M-track more (in styrofoam etc) and also add ballast between the rails. I do the latter and found that Woodland Scenic Medium Buff works for the outside and Fine Buff between the rails.
This is the result: UserPostedImage
More pictures is found on http://www.xn--mrklintg-...alleri/05-06_galleri.htm
Regards / Martin
Regards / Martin T
Offline Ian555
#6 Posted : 21 December 2009 20:19:56(UTC)
Ian555
Hi Martin,
That looks very good on M track,thanks for the photo's.
Have a Merry Xmas.
Ian.
Offline Martin T
#7 Posted : 21 December 2009 23:33:55(UTC)
Martin T
Thx Ian!
I shot a revealing photo tonight from "the ugly angle" to show what it really looks like. Enjoy!
Regards / Martin T
Offline Davy
#8 Posted : 22 December 2009 00:56:25(UTC)
Davy
I use Busch 7126.
UserPostedImage UserPostedImage
M-track with a CS2.
Offline Ian555
#9 Posted : 22 December 2009 07:19:17(UTC)
Ian555
Hi Martin,
Enjoyed the "ugly angle" photo,the finish looks very good.
Had a look thro' your site,lots of interesting information.
Have a Merry Xmas.
Ian.
This page was generated in 0.619 seconds.
