Offline chris.busby
#1 Posted : 23 June 2002 22:23:04(UTC)
chris.busby
I have dismantled the old 111 chassis with it's mechanical reversing unit and fitted the motor parts out of a 60901 set.
I have also added the decoder having knocked up a tin plastic bracket to hold it where the reversing unit was.
Only problem left? Lights....
The supplied bulbs (600150) ground through the chassis and I am not sure if the decoder likes this - I have always used the orange wire.
Is it safe to ground through the chassis or do I need to knock up a couple of fibre boards to hold 610080 bulbs, something that is not a problem but is more complex.
Any help appreciated, many thanks
Chris Busby
UK based Marklin starter
Chris Busby
UK Marklin Digital layout builder and collector.
#2 Posted : 24 June 2002 00:25:04(UTC)
I'd go for the 610080 bulbs with the orange wire to decoder ground instead of chassis ground. A bit more work, but worth it since otherwise you'll get the famous flickering lights that was a nuisance with the older 6090-set.
Offline perz
#3 Posted : 24 June 2002 12:46:30(UTC)
perz
Grounding through the chassis does not harm the decoder, but as the Webmaster points out, it causes an annoying flicker.
This page was generated in 0.436 seconds.
