Offline jeehring
#1 Posted : 26 April 2006 21:56:02(UTC)
jeehring
helping some friends I need to remember how to change the address of non Marklin programmable decoder with the MS
I konw that it has been discussed already
Anyone to recall me which topic please?
thank you per advance!
Offline franciscohg
#2 Posted : 27 April 2006 00:27:19(UTC)
franciscohg
Chile
if i remember well, it was using the feuerwher set in the databank, and then you were able to acces the cv on ESU decoders.
There was a different procedure for TAMs, and i used a different one for Profilok, not able to access CV, only change the adress.
Offline Sander van Wijk
#3 Posted : 27 April 2006 02:11:32(UTC)
Sander van Wijk
It's possible to use the database instance for the 36330 as a starting point for programming ESU decoders with MS.
The TAMS (LDW-1) procedure is indeed different and described here:
https://www.marklin-user...ault.aspx?g=posts&t=3252
Sander
Offline Hemmerich
#4 Posted : 27 April 2006 02:34:17(UTC)
Hemmerich
Views messages in topic : 2,734
[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring
First Question: What is the decoder type/manufacturer?
You will likely not be able to properly program any Uhlenbrock, Lenz, Tams or Kühn decoder, including their derivates sold by Viessmann, Conrad, ROCO, etc.
You will not have any problems programming any MM compatible ESU LS/LP decoder.
Offline efel
#5 Posted : 27 April 2006 09:55:26(UTC)
efel
For Uhlenbrock decoders, here below the procedure given by UHL:
"in order to chance CV 1 to an other value you have to call the loco under the address which the loco actual has ( in your address 3 )
Then press 5 times the "change driection" button. Then the rearlights of the loco will flash slow 4 times.
Then call loco adress 1. Then press 1 time the "change driection" button. Then the rearlights of the loco will flash slow 4 times.
Then call the loco adress you want to use for the loco.Then press 1 time the "change driection" button. Then the rearlights of the loco will flash fast 4 times.
If that is all you want to programm finish.
Then call the loco adress 80.Then press 1 time the "change driection" button.
You are finished.
Attention
All the loco adresses you need for this programming ( address 3,1,the new loco address, 80 ) must be installed into the loco memory of the mobile station."
It is not as staightforward as with 6021, but it' works!
Fred
Offline jeehring
#6 Posted : 06 May 2006 01:28:04(UTC)
jeehring
Thank you all indeed!
One was fighting with an ESU decoder . It happens on a discussion, some people said all decoders are easy to programm with MS. Others said it's not. Depending on which brand.
So Hemmerich, it's obviuously possible with ESU & Tams. Efel gave us a way with Uhlenbrocks.
It seems Lenz didn't give any information on how to programm Lenz motorola decoders.
But did these people have tried with the procedure Marklin has given on the instructions manual, I'm not sure, yet.
#7 Posted : 06 May 2006 02:25:45(UTC)
The Lenz motorola decoders LE900 & LE930 are described on this site.... wink
If anyone knows how to program the 930 with the MS, tell us... Or maybe I will have a go at it later on... Shouldn't be too difficult...
https://www.marklin-user...igital/DIlenz900man.html
https://www.marklin-user...igital/DILenz930man.html
This page was generated in 0.356 seconds.
