2 Pages<12
Offline hmsfix
#51 Posted : 17 April 2006 00:38:43(UTC)
hmsfix
[size=1" face="Verdana" id="quote]quote:Originally posted by Martin T
Solved (by 95%): It's important to maintain perfect power supply in the area around the brake section. If you get a voltage drop of a few volts as a result of long tracks, this type of capasitorless brakecircuit (almost...) may not be able to produce sufficient negative DC-voltage.
Still my BR86 converted to digital maintaining the disk collector motor replacing the coil with Hamo magnet, will still not brake.
Also tried with a converted 3366, in which I kept old type lamps (bright & current consuming). It doesn't brake if the lamps are on. Same with the steamloco from the Mega-start kit with a 7226 smoke generator installed. No brake when the smoke is enabled. Current consumption seems to be a factor here.
Tried to increase capacitor from 1uF to 47uF and decrease resistor to 1k. Resistor change gave positive effect, but the slower (and larger) capacitor gave negative effect. So it seems that the capacitor main mission in this circuit is to suppress the spike that anyway goes through the Schottky diode. Secondly keep the negative energy up enough to maintain negative polarity through the positive halfwave periode.
Question: How fast are your oscilloscopes? 5MHz, 100MHz, 1GHz? It would be of great interest to see only the spike part using a shorter samplerate, like 5us, 1us, or even 200ns to see how far it really gets up and what slewrate it has. Obviously 4ns switch diode is not fast enough to cut the spike completely.
Hi Martin,
many thanks for posting your observation, I'll see what I can do. I am using a 100 MHz oscilloscope, so the signal plots should be reliable.
Perhaps you can solve your problem if you drastically decrease the resistor to 100 Ohms. A capacitor of 47 uF should be o.k.
As it seems some loks and decoders need more current in the brake section than others, so a smaller resistor may help. I'll check that when I'll back at home next week.
It's definitely a good idea to have a short connections to the power supply. It is not only the voltage drop from the ohmic resistance of long track sections, but also the inductivity of the center rail which may cause a severe signal deformation and confuse the decoder.
Hans Martin
Offline Martin T
#52 Posted : 18 April 2006 00:25:53(UTC)
Martin T
Hello Hans Martin!
Thanks! Well, I lowered the resistor to 820 Ohms and that seems to take away 99% of the probz with old power consuming converted locos. I would think that anyone should be "home safe" using a 680 Ohms resistor.
Concerning the capacistor, there seems to be no reason to go above 1uF really. The T=R*C resulting is more than enough discharge time and energy. It's better to stay with a fast metallic film capasitor, than going towards a larger (and much slower) electrolytic. I tried just to replace the 1uF metallic film capasitor with 1uF electrolythic prooving that the responsiveness was really required to get a safe break sequence.
However, the flickering lights is unsolved, as well as the little buzz, but I'm not so interested in those problems, since I'm just aiming for the functionality.
Regards / Martin T
Offline rob77
#53 Posted : 10 May 2006 16:25:52(UTC)
rob77
Hi all together from a new forum member
Question: Why doesn't the switching presented by jte require a transition section? Isn't there any danger to get short circuit by the locos slider passing from the "normal" section into the braking section?
Thanks!
Rob
Offline Martin T
#54 Posted : 11 May 2006 16:33:13(UTC)
Martin T
There will be no short-circuit since there is no full wave rectifying in this circuit. The fast diodes just let the negative halfwave side go through. The RC-link will in fact add a certain amount of negative voltage even in the positive half wave periode, but the serie resistor will limit that current to only a few mA. I'm now using this circuit in 15 positions all over my layout in combination with 12 different locos, so no worries!
Regards / Martin T
Offline hmsfix
#55 Posted : 21 May 2006 20:41:16(UTC)
hmsfix
Hi friends,
Today I did some further work with the brake modules discussed here. Allthough I have it in use for quite some time now, and it works well with various FX, MFX, and ESU Lokpilot decoders, I have now encountered a problem. The problem occurs only for passenger trains with coach lighting, pulled by locos with MFX/ESU decoders.
The symptoms are as follows: when the MFX loco enters the brake section of a halt signal it first starts braking and reduces its speed. However, as soon as the ski contact of the first coach enters the brake section, too, something unexpected happens: the lok will no longer keep on braking, but go on with regular speed until it stops abruptly in the stop section.
After the previous discussion the reason for this problem is quite obvious: when the lighting of the passenger car takes its current from the brake section voltage breaks down in the time intervals where the diode is closed, as the RC bridge can't supply the 120 mA for the lighting. As a consequence the MFX decoder forgets brake modus and makes the lok proceed with regular speed.
I have tried to reduce the resistor and to increase the capacitor of the RC bridge. But I don't think that this can be recommended as a solution because the idling current of the brake module is drastically increased.
So if you encounter the same problem as me, here is a circuit proposal that should help (didn't try it yet, but have only little doubt about it):
The idea is simple: divide the brake section in a number of shorter ones. Each section has its own Schottky diode (actually you need 2 diodes per section now), and its own RC bridge. The length of each section should be shorter than the distance between the ski contacts of the lok and the first passenger coach, i.e. probably 1 or 2 tracks of type 2200 or 24172/24188.
As you see you can still handle the complete sequence of brake sections with a single 7039/7040/7041 signal.
Another possibility is to install current conductive couplers between the passenger cars and put the ski contact to the car at the end of the consist, so it will never get in conflict with the brake section. Not always possible, of course. Therefore, any other solutions for the problem are wellcome.
Hans Martin
Offline jte
#56 Posted : 22 May 2006 14:06:12(UTC)
jte
The coach lighting is a problem for all systems without transition sections. A rocker isolator (Gleiswippe) could maybe used, but it has other drawbacks (not reliable at slow speeds).
I have chosen not to use coach lighting, but maybe a battery driven power solution were possible (Why waiste expensive digital current?).
The solution with several brake sections sounds fully working to me.
juha
Offline hmsfix
#57 Posted : 27 May 2006 00:14:14(UTC)
hmsfix
Hi friends,
Here comes another circuit idea which makes it possible to use locos with MFX/ESU decoder, lighted coaches, and the brake module without transition section. I don't like my last circuit proposal myself any more. Imagine you have 50 signals on your layout: you'll get crazy with transition sections. [xx(]
This solution here sounds a little strange but is pretty simple: put the buffer capacitor on the train, not on the track. Cool
For this purpose you have to install the following circuit in the first lighted coach behind the lok:
I plan to install this circuit in my 43603 streamliner baggage car which usually rides directly behind my mfx GG-1. The baggage car is the only car in the whole consist with a ski contact. It supplies five or six 436xx lighted streamliner coaches using conductive RTS couplers. This requires to brake module to produce a total current of 0.75 amps for coach lighting plus perhaps 0.3 to 0.6 amps for the lok. Under these conditions also a regular M* brake module may throw in the towel here without loosing face.
How it works: First assume the passenger train is outside the brake section, with full digital signal available at the center rail. Then the positive pulses of the digital signal will make diode #1 conductive, and the relay will pull its contact down, thereby separating the large 1000 microfarad buffer capacitor from the digital signal. Ignore diode #2 and the 1 k resistor here. The small capacitor parallel to the relay coil (few micro farads) smoothes the relay voltage a little, so the relay will not flicker.
When the coach enters the brake section, it will find a voltage at the ski contact which is always negative, or at least which is never positive. Thus, diode #1 is closed and the relay falls back. The buffer capacitor is now electrically connected to the center rail via the ski contact and helps to maintain the negative voltage, quite similar as in a usual M* brake module. As a consequence the mfx decoder of the lok keeps on braking in spite of the additional current which the coach lighting take sfrom the brake section. The 4.7 ohms resistor is for protection of the relay contact at a short circuit.
Finally, what is diode #2 and the 1 k resistor good for ? It provides a small negative current to the buffer capacitor such that it is already charged when the relay falls back. This avoids a voltage surge when the coach enters the brake section.
Only thing that might be critical with this circuit: if you use the car an analogic AC layout the buffer capacitor is in danger if the relay fails to pull the contact down, which may happen at low voltages.
Hans Martin
Offline Lars Westerlind
#58 Posted : 27 May 2006 12:38:54(UTC)
Lars Westerlind
At last a problem with this brilliant idea [}:)]
May I thought for a while that my favourite, the relay approach letting a relay switch in DC to the whole section had been beaten.
Evidently, it hasn't been that on all accounts:
- No problems with coach lights
- Possible to do direction sensibility (not brake in backward direction)
- Possible to use other brake signals, as DCC broadcast, or reduced voltage for Deltas.
Kind regards,
Lars
Offline hmsfix
#59 Posted : 27 May 2006 16:50:12(UTC)
hmsfix
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
Lars, you are right, of course: If the relay falls back outside the brake section, e.g. due to a short voltage interrupt, the buffer capacitor will be connected and short circuit the whole section, oops[:I][:I][:I]. Also, because of lack of voltage the relay will not come up again.
For this reason I added this small 4.7 Ohms resistor in series with the buffer capacitor. So voltage across the tracks can build up even the relay has fallen back. So the relay should be able to interrupt the circuit again. I am not sure that 4.7 ohms is sufficient, but I'll test this. The circuit should be stable with respect to power surges on the tracks, naturally.
Passing a closed signal in backward direction is still a challenge. I know there is a solution working with an additional 7244 relay, also working under analogic operation.
With DCC I unfortunately have no experience. Isn't it the same as Motorola with respect to braking: constant (negative) voltage at the decoder makes it initialize brake modus ?
Hans Martin
#60 Posted : 28 May 2006 01:33:11(UTC)
Lars Westerlind
Commenting DCC only:
AFAIK DCC describes a special code for brakesignal, a kind of broadcast to any address. DCC also states that a DC signal directed so that the loco would reverse in analog operation, should stop the loco. But DCC does say that the stop should be gently, and not that light and sound should be on. But some manufactureres, mainly european (Lenz, ESU) normally do this satisfactory.
I had a bad experience with LocPilot 1; when it was run in DCC mode, the light came off, so I had to run it in Motorola instead.
Lars
Offline alibaba
#61 Posted : 05 September 2006 14:40:53(UTC)
alibaba
[size=1" face="Verdana" id="quote]quote:Originally posted by hmsfix
<br />Hi friends,
Hans Martin
Hi everybody!
I built this circuit yesterday and made some tests. It works fine with my mfx-locos, but the blinking lights are very annoying. Anybody has an idea how to fix this? I'm using mfx-Decoders 609xx and LEDs as lights.
-Alex-
#62 Posted : 06 September 2006 00:23:08(UTC)
Hi,welcome to the forum Alex.
Offline hmsfix
#63 Posted : 06 September 2006 00:23:22(UTC)
hmsfix
Hi Alex,
These flickering coach lights are annoying, indeed. Had the problem, too. If you coach lighting has LEDs, I would propose to take a capacitor of around 50 micro farad parallel to the LED circuit. Best results are if it is placed at the output of the rectifier diode which supplies the LEDs, such that the capacitor is charged to full track voltage.
I have LED lighting in my caboose car, with the very same problem in the brake sections. So I installed a 470 uF capacitor. This is perhaps a little too big, but no other capacitor available at that moment. Now the caboose has light for 2 or 3 seconds after power is switched off.
BTW, wellcome to the forum
Hans Martin
#64 Posted : 27 September 2006 02:40:00(UTC)
Hi all!
Very interesting topic!
I have been thinking of installing only the braking section in my electric locomotives, but had in some locos a space problems due to the (not longer required) capacitor.
My idea:
The locos are of course fed by the pick-up shoe, as normal. In addition, a voltage (AC or "B") is supplied to the catanary, retracting a small mono-stable relay inside the loco. "B" to the decoder is fed via the NO connector in the relay.
If the loco by a mistake leaves the catanary area (e.g. into a non-catanary sidetrack), the realy releases, connecting "B" to the decoder from the pick-up shoe via the the diode and relay NC connector, and the loco comes to a slow stop, with the functions on, as if fed by a battery.
Disadvantage: The loco must be moved away manually.
I have tested, it did not work. I used an ordinary diode, 1N4002. After reading all this I know better, and will make some more tests with a Schottky diode.
Do you have any comments?
#65 Posted : 27 September 2006 12:11:28(UTC)
With the plethora of circuits that have been posted here, I'm surprised that no one has mentioned the braking module designed by Huib Maaskant (http://www.floodland.nl/trein/info/digitaal_en_8.htm), which is a cheap alternative for Marklin's 72441 signal module (about $NZ18). I have made several of these and can report they work well, however they do require a transition section. One thing I have found is that this module seems to need a solenoid module load attached to make the signal module work. I am waiting for my Viessmann colour light signals to arrive, so thought I would just run the signal module without any attached signals. Well, I found the module would not work until I attached a C Track turnout point motor in series with the signal module. Hopefully, the colour light signals will provide a similar load (when I finally get them!!).
Other than that the modules work well. Locos with 60901 and C-Sine motors work OK, and locos and coaches remain with lights on when stopped on the braking and stop sections. If you need locos to stop when approaching from behind the signal (against the normal direction) then I guess you would just replicate the connections for the transition and braking sections to behind the signal.
Offline Zosch
#66 Posted : 18 October 2006 22:03:36(UTC)
Zosch
Hi folks,
I read all the posted mails in this topic.
I'm not a electronic master and my question is fianally is there now a final circuit, which works perfect?
For me it would be very interesting, if the transition sections are not necessary. (less work...)
It would be very nice if one of the electronic specialists in this field would draw a simple circuit for the electronic dummies like me , so that one is able to build our own signal module.
I looking forward to hear some good news
Roland
http://reichs-bahn.ch
Corresponding in English and German
Offline hmsfix
#67 Posted : 18 October 2006 22:45:05(UTC)
hmsfix
Bigdaddynz, many thanks for posting Huib Maskats break module site. I have tested this circuit some time ago, too, and I can canfirm it works fine. BTW I had no problems with it, no additional load needed. Might it be that your relay has some additional internal electromagnetic interference protection capacitors or so. This could explain your observation.
Roland, I use the following combined semaphore and brake circuit on my layout for train control.
It has the restrictions concerning passenger trains with coach lighting as indicated above. It does not require brake or stop section, and it works with analogic and digital operation (fx, mfx, ESU decoders, but not with delta, however).
You will find a more complete description of this circuit in topic https://www.marklin-user...ault.aspx?g=posts&t=4759
(see the 2nd page)
Hans Martin
Offline Zosch
#68 Posted : 19 October 2006 19:47:02(UTC)
Zosch
Dear Hans Martin,
Thank's a lot for your fast answer and for the understandable circuit.
I'll try this as soon as possible.
Have a nice time
Roland
Guest (4)
2 Pages<12
This page was generated in 0.575 seconds.
