Offline Drk996tt
#1 Posted : 04 April 2006 05:34:47(UTC)
Drk996tt
Can I use trix freight and passanger cars on C track? I like some trix new 2006 models.
Thank you in advance.
Offline HueyCE
#2 Posted : 04 April 2006 05:57:48(UTC)
HueyCE
Yes, you just need to change out the wheel sets.
Ira
Offline jerdenberg
#3 Posted : 04 April 2006 09:33:25(UTC)
jerdenberg
In addition to the different wheels, the "American" models have Kadee-like couplers. I do not know about European ones.
Jeroen
#4 Posted : 04 April 2006 13:22:46(UTC)
If you are not using contact tracks as the basis of a computer controlled layout, then do you really need to change the wheel sets??
Offline jerdenberg
#5 Posted : 04 April 2006 15:24:26(UTC)
jerdenberg
The Trix cars on my layout (RP25 wheels) do not derail, but I have the impression they "wiggle" more than their exact Märklin counterparts (45680, 45690) when traversing the long turnouts and crossing in their path.
Jeroen
Offline verheyen
#6 Posted : 04 April 2006 18:19:06(UTC)
verheyen
I have several 4 and 2 axle Trix cars in use on my c-track layout and have not had to change the wheels.
p.
Offline rschaffr
#7 Posted : 04 April 2006 18:56:01(UTC)
rschaffr
Adrian: Not really. You certainly need the AC wheels for the contact track, but they do not really do much otherwise, except provide a bridge between the tracks in case one rail is not fully connected to gound.
-Ron
#8 Posted : 04 April 2006 19:33:58(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE
<br />you just need to change out the wheel sets
Ira is right. There's AC and there's DC. That's why MARKLIN/TRIX makes AC and DC wheel sets Cool
And since most dealers change them for free - no need for screwing around ... wink
Offline PierreGILLARD
#9 Posted : 04 April 2006 20:19:57(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by jerdenberg
<br />In addition to the different wheels, the "American" models have Kadee-like couplers. I do not know about European ones.
Jeroen
That's right. But most of (serious) dealers change couplers and wheels (Märklin 320551) on request for free. Just don't forget to ask ...
Pierre.
Offline McLae
#10 Posted : 05 April 2006 00:51:40(UTC)
McLae
ACtually, there are three(3) wheel types: AC, DC, and RP25.
AC is marklin, the wheels are electrically connected. (one piece of metal) These are made specifically to Marklin's standard. (I think there is an NEM AC standard that is marklin)
DC is an NEM standard. Not quite the same as AC in axle length, but the alowable range overlaps with AC. Wheels are electrically isolated. Most non-marklin EU cars and Loks have these wheels. (Such as Roco DC) These wheels work just fine on C-track (I have lots) and K-track. May or may not work on M-track (mostly not[xx(]).
RP25 is the NMRA standard (US). The flanges are realy MUCH smaller than either AC or DC, to satisfy the pickey US modelers. Most of the Trix US caars and some Loks come with these wheels. RP25 does NOT work on marklin track switches, except on the K-track turnouts with movable frogs.
Trix usually includes the wheel type in the item description. If it says RP25, it will only run on US-type track.
I have stopped requesting that my new Roco/Brawa/Piko/... items have AC wheels. Swapping one AC wheel per car gets the train detection if I need it.
The McLae
Offline MärCo
#11 Posted : 05 April 2006 09:16:33(UTC)
MärCo
You have also the Trix 3-rail DC wheels with very thick flanges. Will not run on AC or DC tracks.
Absolutly AFB-NOHAB fan ;-)
Offline TTRExpress
#12 Posted : 06 April 2006 05:27:51(UTC)
TTRExpress
[size=1" face="Verdana" id="quote]quote:Originally posted by Drk996tt
<br />Can I use trix freight and passanger cars on C track? I like some trix new 2006 models.
TRIX wheel sets.
The DC wheel sets that come with the new TRIX items are insulated so that when you install lighting kits for 2-rail operation you will not have a short. These wheel sets should work with no problem on Marklin C-track as long as you don't install car lighting. Now that Marklin owns TRIX the wheel sets are easily interchangeable. Both Marklin and TRIX catalogues suggest the appropriate sets to go with each wagon or car. I would not use RP25 wheels unless you are operating under US standards.
Do not use TRIX Express wheel sets as the flanges on them are large and C-track cannot handle them. These wheel sets are designed for track profile height of 3.1 mm (TE fibre and super-track height), whereas C-track is 2.1 mm. If you have TRIX Express track you can operate Marklin AC and still use the standard TRIX DC wheel sets.
I operate both TRIX Express and Marklin but I keep both layouts separate from each other. You cannot operate Marklin AC wheel sets on a DC layout, but you can operate DC wheel sets on an AC layout.
As others in this forum have suggested, your dealer can change the wheels for you or you can order the wheels and do the change yourself in a few minutes.
Good luck and would be interested to know how it works out for you.
Smile
Offline HueyCE
#13 Posted : 06 April 2006 05:41:38(UTC)
HueyCE
Welcome to the forum Maurice
Ira
Offline TTRExpress
#14 Posted : 06 April 2006 15:40:42(UTC)
TTRExpress
Thanks for the greeting Ira. It is a lot of fun getting back into the hobby again after many years of storage. If anyone has TRIX questions please feel free to contact me, I am not an expert but have an extensive operating collection and information and additional resources. I know I will have Marklin questions.
#15 Posted : 06 April 2006 20:43:25(UTC)
PierreGILLARD
Thanks and welcome to the forum, Maurice.
Pierre.
Offline TTRExpress
#16 Posted : 06 April 2006 22:19:52(UTC)
TTRExpress
Thanks Pierre.
#17 Posted : 06 April 2006 23:16:06(UTC)
Welcome to The Forum and back to MRR, Maurice Smile
Have fun,
#18 Posted : 06 April 2006 23:31:45(UTC)
Hello and welcome to the forum Maurice.Smile
Offline TTRExpress
#19 Posted : 07 April 2006 05:17:18(UTC)
TTRExpress
Thanks to all who have welcomed me. It is nice to participate in friendly forums with good people.
Offline al_pignolo
#20 Posted : 24 April 2006 01:12:27(UTC)
al_pignolo
In trix catalogue there are some models (such as flatcars for truck, "rollende landstrasse" or container cars) where the set of AC wheels is not indicated. That means that you can't find AC wheels for these models? Or that the dealer will not change them for free?
Offline Hemmerich
#21 Posted : 24 April 2006 02:19:06(UTC)
Hemmerich
Hi Pietro,
Yes, you can - easily since these types of cars were/are also offered by Märklin. Every dealer should exchange the wheels for free.
Part# for the "Rollende Landstrasse" is #363360 (4,8mm, non-isolated); this applies for the usage of set #24507 on Märklin tracks
Part# for the container cars ("Taschenwagen") is #321973 (8,4mm, non-isolated); this applies for the usage of set #24504, etc. on Märklin tracks.
Just ask your dealer where you ordered the TRIX set(s) to order the corresponding number of exchange wheels (for 24507 it is "only" 56 wheels! :-)
Lutz
Offline pat
#22 Posted : 24 April 2006 02:33:30(UTC)
pat
[size=1" face="Verdana" id="quote]quote:Originally posted by TTRExpress
<br />Thanks for the greeting Ira. It is a lot of fun getting back into the hobby again after many years of storage. If anyone has TRIX questions please feel free to contact me, I am not an expert but have an extensive operating collection and information and additional resources. I know I will have Marklin questions.
Maurice welcome to the forum I have some trix express cars for show only can you tell me how old trix express is and any web stuff on the range produced
thanks
worse things happen at sea
Offline al_pignolo
#23 Posted: : 25 April 2006 23:15:17(UTC)
al_pignolo
[size=1" face="Verdana" id="quote]quote: Just ask your dealer where you ordered the TRIX set(s) to order the corresponding number of exchange wheels (for 24507 it is "only" 56 wheels! :-)
Thank you Lutz. I'll ask again to have the wheels changed for free, as you suggest... I asked it yet to my dealer but he answered it's not possible... I'll try to contact some german online dealers...
Thank you again. Regards,
Pietro
Offline Hemmerich
#24 Posted : 26 April 2006 00:09:18(UTC)
Hemmerich
I recall this problem from the heavy weight car (TRIX #24020); some dealers apparently didn't want to order the special exchange set (#305268) - even though they get reimbursed, if they get billed for those axles at all.
Lutz
Question about TRIX cars (H0-scale)
by Zora la rousse 27/02/2008 22:29:31(UTC)
Märklin vs Trix cars? (H0-scale)
by ulf999 26/01/2007 20:44:50(UTC)
This page was generated in 0.810 seconds.
