Offline rschaffr
#1 Posted : 29 March 2006 07:04:26(UTC)
rschaffr
In my continuing quest to install RTS couplers on all my lighted coaches, i recently tried converting a 303390 bogie from a 40xx series coach to NEM pockets.
Here is the bogie before I started:
[image]http://www.sem-co.com/~rschaffr/trains/images/bogie1.jpg[/image]
Here is the bogie disassembled:
[image]http://www.sem-co.com/~rschaffr/trains/images/bogie2.jpg[/image]
Here it is with the coupler arm removed:
[image]http://www.sem-co.com/~rschaffr/trains/images/bogie3.jpg[/image]
I drilled and tapped a 2mm threaded hole in the shank for attachment of the new coupler pocket (part # 288390). Here it is with the NEM coupler installed:
[image]http://www.sem-co.com/~rschaffr/trains/images/bogie4.jpg[/image]
Another view:
[image]http://www.sem-co.com/~rschaffr/trains/images/bogie5.jpg[/image]
-Ron
thanks 1 user liked this useful post by rschaffr
Offline franciscohg
#2 Posted : 29 March 2006 07:27:36(UTC)
franciscohg
Chile
Hey, great work Ron.
It works fine?
What kind of screw did you use to fix the pocket??
Offline rschaffr
#3 Posted : 29 March 2006 08:12:05(UTC)
rschaffr
I used a 2mm diameter screw from my parts bin. Had to cut it off for length. I have since bought some 2mm x .4 x 5mm length screws for this project (I have about a dozen or more bogies to convert)
-Ron
#4 Posted : 29 March 2006 10:39:14(UTC)
Good work.Smile
Offline ulf999
#5 Posted : 29 March 2006 11:32:17(UTC)
ulf999
Good job Ron!
#6 Posted : 29 March 2006 11:34:09(UTC)
Just like an operation.biggrin
Offline jerdenberg
#7 Posted : 29 March 2006 12:52:46(UTC)
jerdenberg
Nice job!
Jeroen
Offline Guus
#8 Posted : 29 March 2006 12:57:46(UTC)
Guus
Very nice job Ron [:p].
I like your clear pictures,could do well in a how to do section.Reminds me of the old Märklin Magazine.
Kind regards
Guus
Kind regards,
Guus
Offline PierreGILLARD
#9 Posted : 29 March 2006 18:05:50(UTC)
PierreGILLARD
Nice conversion, Ron !
Pierre.
Offline stephenbb
#10 Posted : 29 March 2006 19:11:47(UTC)
stephenbb
Ron great work! your pictorial makes it look easy for us novices to give it a try.
Stephen(USA)
Stephen(USA)
ETE,NMRA,MEA
Offline Vardex
#11 Posted : 29 March 2006 22:39:38(UTC)
Vardex
Does this actually work with the shortcouplings,even in S-curves?
If it does,good idea.
Bart
Offline MärCo
#12 Posted : 29 March 2006 22:54:31(UTC)
MärCo
Why should you do this ?
Absolutly AFB-NOHAB fan ;-)
Offline rschaffr
#13 Posted : 29 March 2006 23:37:27(UTC)
rschaffr
Bart: Yes they do. (At least so far). I will report if I start having problems with them...I have only done one set so far.
MärCo: As I said, I want to install RTS current conducting couplers on all my lighted coaches. That is why.
Added: Bart: Your point is well taken. I think I will do more extensive testing on R1 curves and a variety of turnouts before I proceed.
-Ron
Offline MärCo
#14 Posted : 30 March 2006 00:15:36(UTC)
MärCo
Wire through the none glazed windows on the end of the coaches ? It can be that simple.... Furthermore, the roof of the tinplate coaches can easely be removed.
Offline rschaffr
#15 Posted : 30 March 2006 00:29:31(UTC)
rschaffr
Can't uncouple them then, plus the wire is unsightly. Plus, the whole point of this project is to make them all interchangeable. I can couple these with any other car. That is why I stopped using the Viessmann ones.
-Ron
Offline rschaffr
#16 Posted : 30 March 2006 04:16:05(UTC)
rschaffr
Ok. I coupled it with a standard close coupled car (from my Lufthansa Express set) and ran it through the gauntlet...R1 reversing (S) curves, across multiple points, even a double slip switch, and it tracked perfectly. No problems. I am pleased.
-Ron
Offline franciscohg
#17 Posted : 30 March 2006 05:08:10(UTC)
franciscohg
Chile
Great!!!!
another point on the "what to do" list
Offline db216
#18 Posted : 03 April 2006 15:14:48(UTC)
db216
Great idea ron. What brand are the coupler pockets you mentioned. They look similar to the marklin ones used on some of their locs. I'm thinking i might try
this on some later model plastic coaches that i still have.
rob.
Offline rschaffr
#19 Posted : 03 April 2006 16:13:54(UTC)
rschaffr
Rob:
They are Marklin #288390. They are the NEM pocket with a tab with a hole in it for mounting.
-Ron
Offline meina222
#20 Posted : 01 March 2007 19:11:47(UTC)
meina222
Did you detach the old coupler by breaking it off?
Offline rschaffr
#21 Posted : 01 March 2007 20:13:05(UTC)
rschaffr
Cut it off with a diamond cutting wheel on my Dremel.
-Ron
This page was generated in 0.694 seconds.
