Offline soeren
#1 Posted : 11 March 2006 10:19:45(UTC)
soeren
hi!
Have now bought a Viessmann three wing wingsignal 4502, works ok analog.
With my CS, not so !
I have followed the Viessmann manual for the wiring. Light in the signal.
I have chosen a dip switch position, which indicates 4 consecutive addresses, for instance
9-12.
In the CS I have created a signal symbol, and given it the address 9. When I confirm
I notice it uses 9 and 10. Ok, since it is a three way signal.
However NOTHING happens when I try to operate the signal...as if I have misunderstood
how to make the CS see the 5211.
Have anyone an idea of what I am doing wrong?
Søren
Offline Lars Westerlind
#2 Posted : 11 March 2006 10:52:54(UTC)
Lars Westerlind
What do you connect to E on 5211? Try red-digital from CS first to isolate the problem. Then you could have an external transformer, provided it shares ground.
Abother possibility is that you have wrong dip-switch setting. If there are settings inside the CS that could prevent the signal from getting through, I don't know.
/Lars
Offline DasBert33
#3 Posted : 11 March 2006 10:56:05(UTC)
DasBert33
I also have 2 4502s in combination with 5211s.
What I can think of to check:
- Is the 'E' bus properly connected?
- You didnt switch the 2 yellow wires?
- Try a normal (switch, simple signal) elektromagnetic device in combination with the 5211 first, or check with a voltmeter.
- If all before is good, play with the order of the 3 blue wires (green, red, yellow marked) connected to the 5211 and see whether that solves it. (I had to do this)
Bert
Edit: Lars you were first :), and ofcourse you have to verify the address.
#4 Posted : 11 March 2006 11:07:17(UTC)
I am sure DasBert33 was right to explanation to you
#5 Posted : 11 March 2006 22:35:31(UTC)
Please quote the software version of the CS (we are expecting a fix in this area).
Notwithstanding the fact that you are not getting ANY response and as suggested the addressing needs to be correct, I personally think that the accessory operation of the CS has yet to be implemented correctly. (We are also expecting route control and memory functions)
I would best equate the operation to a representation of the old 72xx blue box. It was not posible to change from any aspect to any other with a single button. When you set up a 3 or 4 aspect signal in the CS the first 2 icons equate to one address on/off (in your case 9) and the 3rd/4th to the second address (10).
Note the closest the (my) CS gets to route control (issueing 2 commands consecutively) is the 3 way turnout. BUT there is an acknowledged bug and this only works one way. i.e. to change from left branch to right branch you have to press the button twice.
This page was generated in 0.297 seconds.
