Offline rschaffr
#1 Posted : 18 February 2006 05:47:49(UTC)
rschaffr
I just finished modifying my 3021 V200 with NEM pockets and RTS couplers, so I can light coaches from the engine power. This lok has already been modified with a loksound decoder and a 5-pole high efficiency motor.
Here is what the coupler looked like before:
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-4.jpg[/image]
a little closer:
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-5.jpg[/image]
In order to get the NEM pocket (part #344890) to fit, I had to have the skirt milled out by 3/32 inch (2,4mm) so the coupler pocket would not be pushed down by the skirt:
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-8.jpg[/image]
And the completed job:
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-6.jpg[/image]
and closer:
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-7.jpg[/image]
The final product works great.
-Ron
#2 Posted : 18 February 2006 09:52:59(UTC)
Excellent,Great job.
Offline plutoodie
#3 Posted : 18 February 2006 11:18:03(UTC)
plutoodie
Great idea to power the light in the coaches from the locbiggrin How many coaches can you power? What is the limit of the decoder?
HHJJ
Bo Jensen
Offline Guus
#4 Posted : 18 February 2006 13:54:27(UTC)
Guus
Hi Ron,
Those couplers look great,better than the original ones if I may say so.
Judging by the photo you probably used a professional mill to remove some material from the skirt didn't you?
Thanks for sharing the pictures with us.
Kind regards
Guus
Kind regards,
Guus
Offline rschaffr
#5 Posted : 18 February 2006 16:27:31(UTC)
rschaffr
Bo: No limit. The power comes though a relay in the lok that is activated by the decoder. It draws it's power from the track.
Guus: I am fortunate to have access to a professional tool and die machine shop that supports my business. The owner of the shop is also an MRR fan (and my wife's uncle).
-Ron
Offline Hoffmann
#6 Posted : 18 February 2006 19:00:48(UTC)
Hoffmann
Hello Ron,
Excellent work, I guess those current contacting Couplers from RTS
have all kinds of uses.
Martin
marklin-eh
Offline rschaffr
#7 Posted : 18 February 2006 21:32:24(UTC)
rschaffr
Martin: Yes, I love them. They are exactly what I was looking for in my quest, which went through Roco, Viessmann and a few really hairbrained homebrews.
-Ron
#8 Posted : 19 February 2006 00:17:23(UTC)
Nice job Ron. Can be difficult sometimes depending on the Loco to get the wire from the coupler to the decoder. On some Locos it is easy on others the bogie gets in the way and there is little room to drill a hole through the floor of the Loco.
With the two pole couplers you dont need the extra drag on the coach wheels.
David
Offline rschaffr
#9 Posted : 19 February 2006 01:16:47(UTC)
rschaffr
David: I really liked the Viessmann coupers. They had good contact and really smooth operation, however once converted, the lok or cars didn't couple with other Marklin stock. I was facing converting everyting, even goods wagons, to make it all compatible. When I found these, I felt that the addtional drag of the ground was worth the interoperability.
-Ron
Offline hmsfix
#10 Posted : 19 February 2006 02:11:50(UTC)
hmsfix
Ron, great work! Presently I am dealing with a quite similar problem: installing conductive couplers at my F7 to supply the lighting of my passenger coaches.
Where do you install the wires to the coupler at the motor truck ? At least at the F7 I didn't have the right idea yet.
Hans Martin
Offline rschaffr
#11 Posted : 19 February 2006 02:43:47(UTC)
rschaffr
Hans Martin:
In cases like this, I solder a thin wire (.08mm2) to the copper on the underside of the coupler and route the wire into the lok (or coach as the case may be). On coaches that are configured for the Marklin CC couplers, the RTS interface perfectly and no soldering is necessary.
[image]http://www.sem-co.com/~rschaffr/trains/images/v200-9.jpg[/image]
-Ron
This page was generated in 0.361 seconds.
