Offline renevoorburg
#1 Posted : 18 February 2006 08:18:03(UTC)
renevoorburg
Hello all,
I want to slow down trains using zener diodes. Purpose is to lower the speed so that even my longest train stops in the proper part of the shadow station, and not on the turnout...
I was wondering: does any of yoyu have experience using zener diodes (in anti serial configuration) for slowing down trains?
Or perphaps ordinary diodes (many of them, in anti parallel configuration)?
Rene
Offline Tony
#2 Posted : 18 February 2006 09:22:41(UTC)
Tony
Hi Rene
Take a look at this thread link -
https://www.marklin-user...ault.aspx?g=posts&t=3409
Regards Tony
Offline efel
#3 Posted : 18 February 2006 12:55:11(UTC)
efel
Using zener diodes for reducing track voltage allows, in all cases, to reduce the MAXIMUM loco speed. The effect on the speed of locos when the throttle is in low/medium position depends on the loco decoder, and is very small with "load regulated" decoders. There may be a little "jump" when the loco reaches again the standard track voltage. Then, it's not very "aesthetic".
But I think its use in a shadow station, in order to reduce the maximum stopping distance (if the loco is full throttle) is very effective, and mandatory in small layout.
The zener diode to be used should be carefully chosen: a too large value may lead some locos (driven at first step speed) to a stop (specially not regulated delta locos). A too small value is not very effective. It also depends on the track voltage: 19V peak with a MS feeded with the 18VA "transformer"; 22V peak when using 16V transformer + MS or CU6021.
In my case, I use 6.2V zeners (2W), in a "antiserial" configuration without any problem.
You'll find some measurements of loco currents at: https://www.marklin-user...ault.aspx?g=posts&t=2348 .
Hope this can help
Fred
Offline jorge_vilarrubi
#4 Posted : 18 February 2006 15:27:53(UTC)
jorge_vilarrubi
My solution to this problem is implemented as follows:
Use a Delta controller as a booster for feeding the station section.
Feed the Delta from brown/red connectors of an old Märklin 30VA trafo.
Output voltage can then be adjusted by varying the position of the control knob in the trafo.
Simple, cheap, effective.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline efel
#5 Posted : 18 February 2006 16:48:49(UTC)
efel
Hi Jorge,
What happens when the loco shoe shorts the 2 sections?
In case of zeners, the zeners are simply shorted, no problem.
In case of a underfeeded booster, I agree that its track voltage is in phase with the main track voltage, but nevertheless the voltage difference is about 7V, or more if the booster is largely underfeeded. And the output impedance of the CU, MS, or booster is low. Then I guess that a large current may flow between the 2 generators, leading to sprinkle on the track, or short protection activation if the shoe stays a long time between the 2 sections, or damage to the booster whose output transistors are reverse-biased (although I think they are protected?).
I have not checked that solution, and may be I 'm wrong on those points.
In any case, I must say that your proposal is quite elegant (not cheaper than zeners: 2 x 0.2 Euros per section).
Fred
#6 Posted : 18 February 2006 22:41:25(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:Originally posted by efel
<br />What happens when the loco shoe shorts the 2 sections?
I feed the Intellibox with 16V and the Delta with 15V.
No noticeable shorts and enough slowing for me.
MTW: you can use either Uhenbrock Power2 or Power3 boosters, they allow voltage regulation on the track.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
This page was generated in 0.631 seconds.
