Offline lvfocus
#1 Posted : 20 December 2005 03:18:47(UTC)
lvfocus
Hi everyone.
Marklin produced an unexpensive digital set for retrofiting our old locomotives. The new 60760. In Portugal we can have this set for about half the price of the 60901. I have bought 2 of this sets and now begins my problems. To know where to aply this set.
Once again Marklin doesn't produce enough information about this product. I couldn't find any list of locomotives that can be retrofited with this decoder or even other complementary information.
If anyone has more information please let us know.
Grettings from Portugal
Luis Valente (Trying the new CS3 Plus)
Offline laalves
#2 Posted : 20 December 2005 03:20:24(UTC)
laalves
The motor parts of that set fit in all locos where the 60901 fits, since they're the same parts.
Regards from PT,
Luis
Offline franciscohg
#3 Posted : 20 December 2005 03:26:22(UTC)
franciscohg
Chile
Wich means any DCM motor....
#4 Posted : 11 February 2006 12:26:37(UTC)
Okay - I am in the middle of converting an old Delta with one of these things.. Why are the two resistors included? There is no mention in the manual that I can see?
Offline jorge_vilarrubi
#5 Posted : 11 February 2006 13:00:36(UTC)
jorge_vilarrubi
The two resistors actually are two inductors of about 3,9uH and they should go directly connected to the brushes.
Also, a couple 1nF capacitors should be connected between each one of the brushes and ground if you see some erratic behaviour of the decoder.
These instructions came with the old 6090 decoders and are still valid for these new units.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#6 Posted : 11 February 2006 13:33:56(UTC)
Thanks Jorge..
So the wiring is:
Blue wire -> inductor -> plate on the motor like in the image below?
#7 Posted : 11 February 2006 14:56:35(UTC)
Found a link with the answer to confirm Jorge's statement..
See http://www.pallund.dk/retrofitting.htm
specifically -> http://www.pallund.dk/MA...sion/finished_motor3.jpg
Why don't the instructions make it clearer?? [:(!]
#8 Posted : 11 February 2006 15:23:48(UTC)
All done..
Edited by moderator 10 January 2011 20:16:43(UTC)  | Reason: Not specified
#9 Posted : 11 February 2006 21:19:52(UTC)
jorge_vilarrubi
Looks good, Adrian.
Now you have some few parameters to adjust: address (CV1 in DCC decoders), initial speed (CV2) and inertia (CV3&4 together). I don't remember any other value to be adjusted. (I've installed only one of them so far, my decoders are all DCC controlled with an Intellibox).
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline efel
#10 Posted : 11 February 2006 22:21:09(UTC)
efel
Hi Adrian, Luis V,
Would you make some comments on the behavior of this decoder?
Is there a large inertia, as with 6090x marklin decoders, or is it more or less like the behavior of LP V2 (sensible steps in acceleration, no progressive start after a stop at signal (track not feeded)...
In the first case, it's a real bargain and I will consider it for my next loco conversion!
Fred
#11 Posted : 28 February 2006 10:12:50(UTC)
Sorry guys, I missed your questions - sometimes the Active Topic thing plays up..
I have not had a chance to fiddle with the CV settings, but I believe that it runs as well as the 37xxx high efficency series of locos... The only disclaimer is that at 7% speed (using IB) it is not smooth like C-sine...
You need to know that the there is no option for F1-F3 on this chip, but there is a way to set the F4 deceleration/acceleration delay...
I am looking for a second one to convert now...
Overall I am very happy.. Be quick - my dealer tells me that there are no more in Germany...
Offline Hemmerich
#12 Posted : 28 February 2006 20:27:31(UTC)
Hemmerich
Physically there is a f1 + f3 possibility, but they are neither specified nor supported. You'd need to cut the protection tube too which results in an immediate loss of any warranty.
Lutz
Offline frost242
#13 Posted : 22 April 2006 11:44:36(UTC)
frost242
I found this webpage while installing my decoder, it shows how to activate functions.
http://decoder.x-train.d...p?page=digipic/60760.htm
Offline Hemmerich
#14 Posted : 22 April 2006 18:32:53(UTC)
Hemmerich
Hi Thomas,
this info/page exists already since some time. The (almost) same decoder
as with 60760 is also used in other new Märklin models, for example the new V100 Fire-defense set loco (#29755) where the powered auxiliary function (f1) is used to control the blinking light on the loco roof.
Lutz
This page was generated in 0.827 seconds.
