Offline vinder
#1 Posted : 26 January 2006 19:56:52(UTC)
vinder
Hello
I purchased an old marklin mechanical railroad crossing from the late 50s. Their is some wiring for a light but it does not make complete sense. Their is one yellow lead which goes to the transformer and two brown leads (presumably to brown lead). Can anybody tell me where the brown leads are normally routed to in order to make the light work when the train passes.
Al
Offline Hoffmann
#2 Posted : 26 January 2006 20:55:32(UTC)
Hoffmann
Hi welcome to the Forum.
What model# is that crossing or do have Pictures
Martin
marklin-eh
Offline vinder
#3 Posted : 27 January 2006 03:01:26(UTC)
vinder
The crossing number is 7054 and it is a mechanical crossing with a little red light. Sorry I do not have any pictures.
Al
Offline Hoffmann
#4 Posted : 27 January 2006 03:24:31(UTC)
Hoffmann
Hello Al,
The Light is activated by the weight of the Train going over the crossing. Yellow goes to the Transformer and brown from the contact to the Track (ground).
Check to see if you can see the contact when you press down on the Track , the other brown wire goes from this contact to the Light.
Hope this helps.
Martin
marklin-eh
Offline vinder
#5 Posted : 27 January 2006 05:34:58(UTC)
vinder
Think I got it. A bad connection threw me for a loop. In short yellow goes to the transformer and drives the signal light. The brown wires have nothing to do with this they are used for a separate light in the guard house. Thanks for the help.
Al
This page was generated in 0.363 seconds.
