Offline dakje_Rook
#1 Posted : 11 January 2006 21:20:24(UTC)
dakje_Rook
Hi everyone,
I stumbled upon this website/forum by accident today. Must say it contains a lot of valuable information. Truly a good find Smile
I posted this question on a Dutch forum already but did not get any answers.
Would any of you be able to tell me how I should maintain the Marklin 72270 smoke generator. I trust, since one works with fluids in these things, that one has to clean a smoke generator periodically. How to do this ?
Or should I just keep using it till it does not work anymore and then replace the generator alltogether ? I've read in the manual for the 72270 that one "cannot replace the smoke tube". I trust by this the little tube inside the generator is meant. And not the generator itself ? Surely the generator can be replaced ?
My apologies if my confused's seem somewhat silly. I am new to the Märklin-world...
Kind regards to all,
Rolf (M, 32, Dutch)
Kind regards,
Rolf
(M, 32, The Netherlands)
Offline orubias
#2 Posted : 11 January 2006 21:28:43(UTC)
orubias
Welcome, Rolf.
Yes, can be cleaned. Just extract the small tube inside the center tube with a small pincer, and with a very small needle, of the size of a hair, clean it. My smoke generators comes with this cleaning kit.
And the smoke generator can be changed, of course, from outside, or opening the loco, depending on the generator model.
Band on the run
#3 Posted : 11 January 2006 21:30:32(UTC)
Ususally there is piece of metal wire that comes with smoke units, it is used to clear a clogged inner tube.. So - yes it is the "little tube" they refer to... Smile
Edit: orubias was quicker...biggrin
#4 Posted : 11 January 2006 21:40:33(UTC)
Hallo Rolf.
I stumbled upon this website/forum by accident today. Are you sure it wasn't by luck? biggrinbiggrinbiggrin
No confused too silly.
Offline hmsfix
#5 Posted : 11 January 2006 21:48:41(UTC)
hmsfix
I have installed a 72270 in a 37973 steamer 1 1/2 years ago. Never any problems or need for service, and it has been in operation very very often.
Juhan, Orubias, if I remember right there was no replacement filament tube shipped with the 72270. It should be impossible to take this little tube out of the steam generator. Well, I never tried that. Or do I confuse something ?
Removing the tube is, however, possible for the 7226 steam generator (the one used in class 01, 03, 44 and 50 steamers). This steam generator is shipped with a pincer, a replacement tube, and a cleaning wire.
Hans Martin
Offline dakje_Rook
#6 Posted : 11 January 2006 21:54:27(UTC)
dakje_Rook
[size=1" face="Verdana" id="quote]quote:Are you sure it wasn't by luck? biggrinbiggrinbiggrin
Damn, just a I was so proud of my English in that post...hehe...I stand corrected...
[size=1" face="Verdana" id="quote]quote:Ususally there is piece of metal wire that comes with smoke units, it is used to clear a clogged inner tube..
On the Marklin-site I see that the larger generator 7226 does come with such a wire. The smaller 72270 (to fit my 37540 locomotive) does not. To my suprise...
[size=1" face="Verdana" id="quote]quote:Just extract the small tube inside the center tube with a small pincer, and with a very small needle, of the size of a hair, clean it.
From this comment I gather that the inner tube can be removed. Good news. Allthough I then do not see why it cannot also be replaced. Must be Märklin-logic wink Not to be rude but are you sure the tube can also be removed in this particular model (72270) ? To prevent me from demolishing the generator when yanking at the tube.
Thank you all for the clear answers. I understand the smoke generator a lot better now. Much appreciated Smile
Kind regards,
Rolf
Kind regards,
Rolf
Offline dakje_Rook
#7 Posted : 11 January 2006 21:56:14(UTC)
dakje_Rook
[size=1" face="Verdana" id="quote]quote:It should be impossible to take this little tube out of the steam generator.
Right...I'd best hold on the yanking for now... Thank you !
Kind regards,
Rolf
Offline Gregor
#8 Posted : 11 January 2006 22:20:22(UTC)
Gregor
Why do you have to take out the tube before cleaning ? Can't you just use the hair-needle while the tube is still in the generator, and the generator still in the loc ??
Gregor
Offline franciscohg
#9 Posted : 11 January 2006 22:50:52(UTC)
franciscohg
Chile
Welcome to the forum Rolf!
#10 Posted : 11 January 2006 22:55:36(UTC)
Hi Rolf - welcome to The Forum. Have fun ... biggrin
#11 Posted : 11 January 2006 23:01:13(UTC)
Welcome to the forum dakje_Rook.
Offline stephenbb
#12 Posted : 11 January 2006 23:26:20(UTC)
stephenbb
Welcome Rolf!
Stephen(USA)
Stephen(USA)
ETE,NMRA,MEA
Offline Guus
#13 Posted : 11 January 2006 23:32:55(UTC)
Guus
Welcome to the forum Rolf Smile.Have fun.
Kind regards
Guus
Kind regards,
Guus
Offline HueyCE
#14 Posted : 12 January 2006 01:34:32(UTC)
HueyCE
Rolf- Welcome to the forum.
Gregor- You want to remove the small tube before cleaning so that all of the gunk you are cleaning from the tube doesn't fall to the bottom of the generator, which would impair the operation..
Ira
#15 Posted : 12 January 2006 07:46:06(UTC)
There is no question without answer to this forum.biggrinbiggrinbiggrin
Offline dakje_Rook
#16 Posted : 12 January 2006 09:22:27(UTC)
dakje_Rook
Thank you all for your kind reception. And from all around the globe too biggrin
I'll be doing some catching up reading here and I'll be thinking up my next question for sure !
Kind regards,
Rolf
Offline HueyCE
#17 Posted : 12 January 2006 12:50:14(UTC)
HueyCE
Any questions you have will certainly be answered by someone at this forum.
Ira
Guest (10)
This page was generated in 0.595 seconds.
