Offline Drongo
#1 Posted : 02 August 2009 15:21:36(UTC)
Drongo
Hi all, my cs1 won't bootup. I turn on the power and the bootup process starts, but it doesn't go past the process of the initial screen with the red stop button on, and the black square moving from side to side. Can someone please help me.
Thanks in advance,
Greg
#2 Posted : 02 August 2009 22:02:32(UTC)
What transformer are you use?
Offline Piggy
#3 Posted : 03 August 2009 01:37:52(UTC)
Piggy
Hi Greg,
Check if there rubbish such as ballast or so, squissed in between the touchscreen and the housing, at the sides. This will keep functions pressed on the keyboard, and may desturb booting. I don't think this is the problem in your case, but check it anyway. I had this problem a couple times, resulting the touchscreen not responding.
Kenneth
Offline Drongo
#4 Posted : 03 August 2009 05:07:53(UTC)
Drongo
Hi Steven,
I'm using the transformer that came with the unit. The CS1 was working before without problems - it just started to happen this way.
Offline frankie
#5 Posted : 03 August 2009 14:55:40(UTC)
frankie
You may need to reset it from the web interface, it happened to me.
Just read my topic about a scary evening.
Are you able to connect it via ethernet?
Alessandro
I have a CS1 Reloaded!
Offline frankie
#6 Posted : 03 August 2009 14:58:59(UTC)
frankie
Alessandro
This page was generated in 0.306 seconds.
