Offline Alberto Pedrini
#1 Posted : 30 December 2005 20:35:44(UTC)
Alberto Pedrini
Hi friends,
the last discussion about plastic left me in a dubt, after read this answer:
quote:
Originally posted by Gustavo Villa
Many roco and other locomotives have Teflon gears (no idea about this marklin ones), with good maintenance and adequate oil for Teflon they can last forever, even more than the normal marklin brass gears.
This teflon gears are completely different to the old lima pure plastic gears. "But" the big problem with non metallic gears is the lubrication, some inexperienced users use normal oil to lubricate them, this oil can disintegrate plastic, Teflon or any other resin gear in a couple of years.
So, for plastic, Teflon or any other non metallic gear you must use a non aggressive grease or special oil for this purpose.
Teflon and high quality plastic gears have been in use for many years in CD players, radio cassettes, printers, etc., their reliability is bulletproof, and their smoothness is the mayor advantage over metallic gears.
I realized that in the last year I used only a kind of oil (faller) for all my locos (lima & Roco plastic gear too).
Is it suitable for plastic and teflon?
What will happen the next years?
I'm worry [:(]
Alberto
Marklinfan Club Italia
www.marklinfan.net
Offline Davy
#2 Posted : 30 December 2005 22:08:52(UTC)
Davy
I think it will don't much harm. Because the faller oil is not acid.
So don't worry and be happy.
M-track with a CS2.
#3 Posted : 30 December 2005 22:31:07(UTC)
Alberto Pedrini
Thank you Davy
Alberto
www.marklinfan.net
Offline Gustavo Villa
#4 Posted : 01 January 2006 16:25:19(UTC)
Gustavo Villa
Chile
For roco and other brands the best solution for plastic gear is the roco grease 10905
http://catalog.lokshop.de/ROC/2004-2005/E/345.jpg
But as Davy already pointed out, faller oil should not be a problem.
#5 Posted : 01 January 2006 17:04:06(UTC)
Alberto Pedrini
Thank you Gustavo,
I'll buy it tomorrow.
Alberto
www.marklinfan.net
Offline Davy
#6 Posted : 01 January 2006 18:04:20(UTC)
Davy
Trix has also this nr 66626
M-track with a CS2.
Offline Steven86
#7 Posted : 01 January 2006 21:21:09(UTC)
Steven86
What about silicon grease? That is non agressive and should work as well. Or maybe it is too thick? Has anyone tried it on a teflon gear already?
Steven
Offline Guus
#8 Posted : 01 January 2006 21:31:51(UTC)
Guus
Here's a nice site I came across some time ago:
http://www.lokfett.com/
Kind regards
Guus
Kind regards,
Guus
#9 Posted : 01 January 2006 22:35:48(UTC)
Alberto Pedrini
Very good link, thanks Guus
Alberto
www.marklinfan.net
#10 Posted : 02 January 2006 21:24:41(UTC)
This oil is suggested by Marklin for the SVT 137 item 37770-37771.Smile
[size=1" face="Verdana" id="quote]quote:Originally posted by Davy
<br />Trix has also this nr 66626
Offline Davy
#11 Posted : 02 January 2006 22:37:06(UTC)
Davy
Stupid me. I have this oil from trix.
[8)][:o)]
M-track with a CS2.
This page was generated in 0.458 seconds.
