Offline alonso231gery
#1 Posted : 28 December 2005 04:48:38(UTC)
alonso231gery
M HAS to realise that without extended uncoupling period,that track IS USELESS!!![V][xx(]
at least give us a sign that you will fix it
the former system had NO problem on that[^]
DO SOMETHING
An outsider.
Offline prc
#2 Posted : 28 December 2005 08:47:18(UTC)
prc
<br />M HAS to realise that without extended uncoupling period,that track IS USELESS!!![V][xx(]
DO SOMETHING
I assume you are refering to connecting it to the CS. One thing you can do is set the Switch Duration to the max at 2.5 seconds (2500 ms). You are right though it needs to allow on/off setting.
Paul
Granby, Ct.
USA
Offline Wissels
#3 Posted : 28 December 2005 09:33:01(UTC)
Wissels
Hello Alonso,
oke it is aa little bit frustrating, but why don't you use the other port of your K83 and it's working great, make of the uncoupler a permanent kontakt and it work's fine. I also hope Märklin is fixing the bug for the other port.
I think this the 3td thread you talk about this.
Greetings, Walter
Offline Lars Westerlind
#4 Posted : 28 December 2005 11:29:42(UTC)
Lars Westerlind
It's the CS that is useless, my uncoupling tracks work just fine. /Lars
#5 Posted : 28 December 2005 14:44:49(UTC)
alonso231gery
u r unfair Lars
An outsider.
Offline Frostie
#6 Posted : 28 December 2005 15:55:37(UTC)
Frostie
Tsk Tsk - I had my learning curve with the cs early on. That is the price of change and improvement. While the cs has some drawbacks, it has the potential to be very fatastic and much superior to anything available today.
So forward lookers will embrace the challenge and work through the frustrations to be a part of the development of CS. The others will just have to WHINE and COMPLAIN.
CS/MS Digital Era 1/2
Offline rugauger
#7 Posted : 28 December 2005 16:03:07(UTC)
rugauger
What does "CS" stand for? "Crap System" perhaps? biggrin
The answer to all questions in the universe is - no, not 42 - it's 6021... wink
Richard
#8 Posted : 28 December 2005 20:42:31(UTC)
alonso231gery
ideas like these had prevent progress of science
too good that we do not live in the dark ages
you would had burned at us at the stake
wait and see
thank you prc you are right
An outsider.
Offline Frostie
#9 Posted : 29 December 2005 01:21:54(UTC)
Frostie
I am looking at a PDF of the manual on line on page 12 of the manual (in English) you have section 4.2. The option you might need to look for is button function. Set the control to continuous and try it out.
Let me know if it works ?? I am interested in knowing. I do not have uncoupler tracks at this point in time.
Offline prc
#10 Posted : 29 December 2005 02:34:35(UTC)
prc
quote:Originally posted by Frostie
<br />I am looking at a PDF of the manual on line on page 12 of the manual (in English) you have section 4.2. The option you might need to look for is button function. Set the control to continuous and try it out.
The problem is you cannot select continuous - That feature does not work right now.
[size=3]Although, I found that if you press the uncoupler icon any number of times, say 4 on/off, the uncoupler will activate for 10 seconds (assuming you have the duration set to 2.5 seconds). If you want more time just press it more times.
Paul
Granby, Ct.
USA
This page was generated in 0.827 seconds.
