Joined: 06/02/2005(UTC) Posts: 1,383 Location: Darmstadt,
I would be interested in any experience when soldering K-track (22xx series), especially soldering mass contacts directly to the rails.
I always thought that soldering is only possible at the splice plates at the ends of the K-tracks. This is because the rails are made of stainless steel profile on which the usual electronics solder metal does not hold.
Recently, on a trip to the Miniatur Wunderland in Hamburg I saw that there were solderings at the rails. I suppose they use a special solder metal. Any ideas what this could be ?
Hans Martin
Joined: 08/11/2005(UTC) Posts: 3,528 Location: Mullerup, 4200 Slagelse
Hello Hans Martin. I have heard of a way, but not found it yet myself. 1_gauge tracks are also stainless, and I have tried a lot, but without succes. So please, you who know, now there are 2 of us!  Per. |
If you can dream it, you can do it! I, the copyright holder of this work, hereby release it into the public domain. This applies worldwide. In case this is not legally possible: I grant anyone the right to use this work for any purpose, without any conditions, unless such conditions are required by law.  |
Joined: 27/10/2004(UTC) Posts: 942 Location: Burney, CA
These rails can only be soldered with acid flux solder. Over time, it will corrode and cause problems. Maybe at MIWULA they have enough other maintenace on going so that they can absorb this extra effort. |
From the People's Republik of Kalifornia |
Joined: 10/02/2004(UTC) Posts: 2,162 Location: Portugal
What about electrical soldering, with no add-on metal?
Has anybody tried that?
Luis
