Offline rschaffr
#1 Posted : 11 December 2005 04:16:05(UTC)
rschaffr
I have been trying to figure out how to make a realistic grade crossing on a curve with my K-track. One night laying in bed in Munich (or was it Berlin, or Nurnberg?) I got an idea. Here it is:
I took a piece of thin balsa wood about the thickness of the track, and cut it to fit between the rails, leaving space for the flanges to operate:
I then painted it like the road and striped it, and placed it in the roadbed with "tacky wax"
I took a piece of Viessmann catenary wire and cut it somewhat longer than the road width, and cut off all the vertical wires except one, then soldered a lead to that one:
Then I drilled a few holes for the wire, bent the ends down to go through the roadbed, and hooked up the wire. Here is the (almost) finished product (I have some touch-up to do):
I may replace the wires with some of the black anodized new catenary from Marklin to get rid of the silver line trhough the road.
It works great.
-Ron
Offline HueyCE
#2 Posted : 11 December 2005 04:19:42(UTC)
HueyCE
Neat solution, would probably work with C-track as well. Only one problem- no crossing barrier.[:0] Better watch out or the NTSB will be on you.wink
Ira
Offline rschaffr
#3 Posted : 11 December 2005 05:04:24(UTC)
rschaffr
I have the lights for it..just haven't installed them yet. I also bought a barrier for it (Viessmann slow acting) but the actuators hang down below the platform too far and interfere with the hidden track below. I'll use them somewhere else.
-Ron
#4 Posted : 11 December 2005 10:54:29(UTC)
Excellent crossing,keep posted pict soon when barrier there.
Offline PierreGILLARD
#5 Posted : 11 December 2005 15:37:07(UTC)
PierreGILLARD
Thanks for the tip, Ron.
Pierre.
Offline viragoLDR
#6 Posted : 11 December 2005 16:11:09(UTC)
viragoLDR
- Martijn
This page was generated in 0.311 seconds.
