Offline gachar001
#1 Posted : 19 May 2009 00:35:45(UTC)
gachar001
India
M* recommends that the wheel bearings for all new wagons and cars be oiled before use. What is the best way to oil them?
I used the nozzle of my oil bottle to do this but too much oil gets there and creates a mess on the tracks. I have been running my newer ones without oil.
Can I use a syringe with a needle? What do you use?
Gautham
Atlanta, GA USA
Offline hemau
#2 Posted : 19 May 2009 00:48:02(UTC)
hemau
I indeed use a syringe with a needle. Just a drop on any bearing. Oiling is certainly useful.
See other threads about axles wearing through the plastic bushings in a year.
Regards, Henk
C and M track; CS1R and 2 MS
Offline dntower85
#3 Posted : 19 May 2009 00:48:34(UTC)
dntower85
the oil I use, Labelle 107, has a syringe like applicator built in.
DT
Offline perz
#4 Posted : 19 May 2009 01:46:08(UTC)
perz
I usually catch a drop of oil on a needle or a small screwdriver, and then applies it with that.
Offline ozzman
#5 Posted : 19 May 2009 02:15:36(UTC)
ozzman
I use Fleischmann oil and the bottle comes with a needle applicator. You can easily make a needle applicator by taking a wine bottle cork (after first emptying the bottle into a wine glass) and sticking a sewing needle into the cork, sharp point first. When you dip the other end into the oil the eye will pick up a little oil. An applicator like that can also be used for applying very small amounts of adhesive.
Gary
Z Scale
Online Ross
#6 Posted : 19 May 2009 02:18:16(UTC)
Ross
Hi Gautham,
In my Tips section I wrote this article on lubrication
Rolling Stock Lubrication
I hope it is of some help.
Originally posted by gachar001[/i]
<br />Hello,
Edited by user 03 January 2025 04:13:58(UTC)  | Reason: Link corrected 03-01-2025
Ross
Offline soren36
#7 Posted : 19 May 2009 05:34:09(UTC)
soren36
Gautham - Radio Shack has needle oilers that I find perfect for my models. You can put a tiny drop virtually anywhere.
A Connecticut Yankee
Offline sudibarba
#8 Posted : 19 May 2009 05:36:50(UTC)
sudibarba
The Hag oil comes with a long metal needle on it. I also have syringes with blunt tips I can use.
Eric
#9 Posted : 19 May 2009 11:42:47(UTC)
Excellent tips.
#10 Posted : 19 May 2009 16:42:46(UTC)
I drop very small on wheels bearing use the Oil 'pen'.
Offline gachar001
#11 Posted : 19 May 2009 18:45:38(UTC)
gachar001
India
Thanks everyone for your tips.
I was reminded of oiling the bearings after I saw the posts where the axels were wearing through the bushes.
Gautham
Atlanta, GA USA
Offline Caplin
#12 Posted : 19 May 2009 23:53:04(UTC)
Caplin
Home made, very cheap - most efficient tool to control the amount of oil.
Benny - Outsider and MFDWPL
Offline hemau
#13 Posted : 20 May 2009 23:11:41(UTC)
hemau
Benny, your oil dropplet is still to thick biggrinbiggrin that it does not reach the wheel flanges.
But the pictures are greatSmile
Regards, Henk
Offline Caplin
#14 Posted : 21 May 2009 01:49:54(UTC)
Caplin
Thanks Henk. The tool shown works splendid for me. I never get oil on the wheel flanges nor do I get excessive oil, but the controlled amount of oil goes direct onto the axle ends and bushes as I take advantage of the slight side movement of the axle when applying the oil. Just enough room.
The problem with various syringes I find is that you easily come to apply maybe 2 drops or more instead of only the 1 intended.
Ozzmans suggestion is very good, it goes along the same line as mine I think wink
#15 Posted : 21 May 2009 03:17:26(UTC)
I just use a bit of wire and dip it in the oil
Guest (7)
This page was generated in 0.458 seconds.
